 Latest: iamzeplin
 New Today: 7
 New Yesterday: 17
 Overall: 7729
 Members: 7
 Visitors: 18
 Total: 25
Who Is Where: Members:01: brokenxj700 > Forums
02: chobber > Forums
03: dbikers > Forums
04: dwmauney > My Account
05: johno8 > Forums
06: Kylew11 > Forums
Visitors:01: My Account
15: Home
Hidden: 1
We have received 33581273page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › Just the float valves? Now this?
Just the float valves? Now this?Technical discussion ONLY for XJ Maxim/Seca...
Go to page 1, 2 Next
Gynotai 1st gear
Joined: Jul 14, 2008 Posts: 23 Location: San Jose, CA USA
Posted: Thu Aug 21, 2008 9:41 pm Post subject: Just the float valves? Now this? |
Hi.
Thanks for taking the time to read this. I have a 1981 XJ650 that was running fine until the Float Valve in cylinder #3 started to fail causing gas to drip out of the Air Filter.
I bought a Kit that had the new Float Valves and I installed them without incident.
I'm all happy getting to ride my bike again (it's been almost a week) and I look down at the engine by the Carbs and I see gas that starts on the starter and because of forward motion, worked it's back to the rear wheel.
I notice the Clutch starts to feel strange, so my first thought is "Do I have gas in the oil?" Sure enough, I look into the bubble only to see what appears to be a lot more liquid in the crankcase than before, so I take it very easy on the way home.
After taking a better look in the Window, I'm pretty sure there's gas in the oil. My question is:
What would have caused this? Did me installing new Float Valves do this? I'm hoping I'm not in for a major repair.
One other thing I should mention is when I got the bike, it didn't have an air box. I was told it was not driven this way, so I went and bought the individual air filters that attach VIA hose clamps onto the air intake of each carb. This makes the Crankcase Breather hose open on the end that usually connects into the air box. I started the engine and ran it for 30 seconds, and I noticed the air coming from the crankcase VIA the breather hose smelled strong of gas, further confirming my suspicion of gas in the oil.
Any help on this would be appreciated.
Also, I just received a Haynes Manual on the bike. Maybe I should read it!
Thanks!
Gynotai
wizard XJ Wizard
Joined: Mar 28, 2008 Posts: 3187 Location: melbourne australia
Posted: Thu Aug 21, 2008 9:45 pm Post subject: Re: Just the float valves? Now this? |
float heights need adjusting.
_________________ 4 wheels move the body-2 wheels move the soul. |
bigfitz52 XJ Wizard
Joined: Jun 27, 2008 Posts: 6782 Location: Cows'n'Pigs'n'Chickens MICH
Posted: Fri Aug 22, 2008 4:20 am Post subject: Re: Just the float valves? Now this? |
Yep. Or one (or more) may be sticking or hanging up for some reason. You said it was "running fine" was it rejetted for the pod filters? Also, if you're going to stick with the pods, the breather should get a filter too. They are available, it looks like a miniature air filter and clamps on the breather.
_________________ '81 XJ550RH Seca- Recommissioned original classic daily rider; 26K miles stock except bars, seat, shocks and SS brake lines.
'83 XJ550RK Seca- "Toxic Asset"; 9K original miles, restored, modernized and personalized (nearly stock)
Wish I hadn't sold my SR500
bill XJ Wizard
Joined: Jun 20, 2008 Posts: 2813 Location: Raleigh, NC
Posted: Fri Aug 22, 2008 5:59 am Post subject: Re: Just the float valves? Now this? |
If you had gas dripping from your air filter prior to your repair it is likely that is when the gas got in the oil. A failed needle valve will dump gas in the cylinder (lots if your petcock is bad too) and from there is goes into the engine. You need to do several things:
Verify your petcock is working properly - it is vacuum controlled - no gas should come out if the engine is not running.
Verify all your needle valves are closing properly
Verify your float heights as suggest above
Change/flush your oil to get rid of the gas. I have been there, what worked for me was I changed the filter and added some cheap 10W40 oil. Ran 10 minutes or so under NO LOAD. Remember fans to cool your engine. Then drain and change filter again - refill with your normal oil.
Lastly pay attention to Bigfitz's queries about pods and rejetting etc...
_________________ 82 XJ650J Maxim 43k miles and climbing - all stock
82 XS400J 16k miles (project bike right now)
Past rides:
66 Honda Superhawk (partial rebuild - sold in 2008)
71 Honda CB350 (sold after rebuilding engine)
81 XS850 Midnight special (never should have sold it)
| wizard wrote: |
| Yamaha Induction Control System, or in lay terms, a hole in the head. |
Gynotai 1st gear
Posted: Fri Aug 22, 2008 9:20 am Post subject: Re: Just the float valves? Now this? |
Hi.
Argh. I replaced all the float valves because of the one that failed. I had the naive assumption that all I would have to do it replace them. I hope I didn't get into more than I'm able to handle.
With regard to jetting the Carbs; nope. Didn't do any of that. All I mainly did was clean everything up. I bought the other air filters because they were $28 for the set of four, and were a lot less expensive than the air box's I was finding on eBay that were in thrashed condition.
I started reading the book last night (and I have it with me today to read more) about the technique using a piece of hose to determine the levels in the float bowls. I guess I'm going to have to guess at this. I see you have to make the adjustments VIA bending the little tab on the float bowl which means having to take the carbs off many times, and... Again; argh!
In hindsight, I should just cleaned the old ones and put them back!
If anyone has their own technique on how to do this, I'm all ears!
Thanks for reading,
Can't wait to be riding again!
Gynotai
bill XJ Wizard
Posted: Fri Aug 22, 2008 9:46 am Post subject: Re: Just the float valves? Now this? |
Check the thread on dry setting the floats. It will get you very close.Then you have to use the tube to ensure they are right.
I just did my carbs and while setting float heights I had issues with the needles sticking when first filling the bowl. Had to tap the bowls to insure they seated but no problem after that. Also while tube checking 2 hints.
2 screws should hold the bowl with no leakage and if you do get a carb to overflow and have to tap it drain some gas and let it refill. I went nuts because no matter what I did the level was high, well duh on me it had overflowed and there is no place for the gas to go. After I figured that out I had the floats set pretty quick, wasted an hour though. I'm a slow learner.
Past rides:
| wizard wrote: |
Gynotai 1st gear
Posted: Sat Aug 23, 2008 1:59 am Post subject: Re: Just the float valves? Now this? |
Hi.
Thanks for all of this information! I just went out and pulled the carbs off my bike. Would it be a good idea to change the oil before I test the newly adjusted carbs? If so, I guess I'll run the risk of contaminating it again if they're still overflowing.
I also read that the petcock is vacuum controlled and that gas shouldn't come out of the fuel line unless the engine is running? The Petcock has a diaphram on it and a smaller (second) line that connects to the intake
of one of the cylinders. Is this correct?
Thanks!
Gynotai
chacal XJ Wizard
Joined: Aug 01, 2006 Posts: 4099 Location: At My Computer
Posted: Sat Aug 23, 2008 2:21 am Post subject: Re: Just the float valves? Now this? |
Set the float heights with the carbs upside down (off the bike, obviously) at the following measurement:
from the carb body base ridge (where the gasket would sit, but without the bowl gasket in place, and NOT on the raised rib that is in that area) measure 13/16" upwards, and adjust the float so that the MOLD LINE in the float (at the end of the float, not at the pivot side of the float) is at that 13/16" height.
Then double-check with the "clear tube" method, but that 13/16" measurement should get you pretty much dead-on...........
P.S. the above information applies to Hitachi carbs only!
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
xjbikes.com/Forums/vie.../f=23.html |
Gynotai 1st gear
Posted: Mon Sep 01, 2008 9:01 pm Post subject: Re: Just the float valves? Now this? |
Hi.
After readjusting the Carb floats, I'm no longer getting and gas in my oil. Thanks to everyone who responded.
But I now have another question:
The bike rides ok. Not that hot at lower RPM's, (2K and under) and a lot of the time the bike has a high idle (2000-3000 RPM). Sometimes revving it once makes it come down to normal idle (800-1000 RPM).
What causes this?
Thanks!
Gynotai
MN-Maxims XJ Wizard
Joined: May 03, 2008 Posts: 1396 Location: Saint Paul, MN
Posted: Mon Sep 01, 2008 9:22 pm Post subject: Re: Just the float valves? Now this? |
Sticking Slides Did you do the clunk test?
_________________ 1981 XJ650H (Silver)
1982 XJ750J (Black)
1982 XJ750J (Red)
1982 XJ750J (Primer)
1982 XJ1100J (Black)
1983 XJ750K (Black)
1982 XJ1100J (Black & no second gear)
Current Project on the lift: 83 750 Maxim Air Box next. Black 1100 Second gear tranny problem |
RickCoMatic Moderator
Joined: Jun 23, 2006 Posts: 9662 Location: Massachusetts, Billerica
Posted: Mon Sep 01, 2008 9:26 pm Post subject: Re: Just the float valves? Now this? |
_________________ Rick Massey
Moderator - Tech Writer
Use LOCATION Feature.
chacal XJ Wizard
Posted: Mon Sep 01, 2008 9:27 pm Post subject: Re: Just the float valves? Now this? |
Or a vaccum leak somewhere......
85MaximXX Red Liner
Joined: May 20, 2008 Posts: 755 Location: S.W. michigan
Posted: Tue Sep 02, 2008 6:01 am Post subject: Re: Just the float valves? Now this? |
you have to remember guys he said he had pods!!! So your under 2 k you really need to add more fuel for the air flow by either bigger pilot jets or bigger pilot air jets whichever is the best option. Chacal can get you what you need and they are easy to replace although you will be taking the carbs back off. Also if you search plug chop you may get by with just tweaking your mixture screws. but very warned if they haven't been pulled and cleaned they have a tendancy for the head to strip on them. THen you are drilling on your carbs not a fun thing to do. I suggest before y ou even think about moving them put a drop of wd-40 or the like right on top of the screws for at least a day or two to help free things up.
_________________ 85' MaximX 700 26k Miles and climbing daily driver. Painted sunburst orange pearl. |
Gynotai 1st gear
Posted: Tue Sep 02, 2008 9:24 am Post subject: Re: Just the float valves? Now this? |
Hi.
I'l have toi give the "Clunk Test" a try. I thought they were free, but I'm not sure they were that free.
I took it to work this morning, and it was HARD to start! Sounds like it was starting, then right after I let the starter button go, it stopped.
I did see rebuilt ones on eBay for $150.
Keeps me thinking...
Gynotai
Gynotai 1st gear
Posted: Fri Sep 05, 2008 4:28 pm Post subject: Re: Just the float valves? Now this? |
Hi.
Does anyone have any suggestions for me with regard to the hard starting in the morning? Might that have anything to do with the Float Valves I replaced? If not, what might be the cause of that? I'm going to pull the carbs off again this weekend and if anyone has any suggestions on what to do I'm all ears.
Gynotai
