XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: HG85
New Today: 0
New Yesterday: 4
Overall: 8027
Members: 2
Visitors: 20
Total: 22
Who Is Where:
 Members:
01: gunnabuild1 > Forums
02: ken007 > Forums
 Visitors:
01: Forums
02: Archives
19: Forums
20: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
35197296
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › 1982 550 carb t-fitting fuel input
Author Message
fjpish
1st gear
1st gear
PostPosted: Mon Sep 08, 2008 5:45 am    Post subject: 1982 550 carb t-fitting fuel input Reply with quote
My Mikuni carbs leak fuel from the t-fitting input. The manual says it requires o-rings but upon removal, ther are no o-rings and it appears to be a self-sealing, rubber-coated part. I spoke with chacal and he says he's never seen o-rings here. Anyone have any experience with these. Did Yamaha change the part spec after these schematics where done? Should I be ordering the t-fitting and o-rings, now?
I appreciate any insight. Thanks!
Back to top
View user's profile
vinnie
1st gear
1st gear
PostPosted: Mon Sep 08, 2008 6:37 am    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
I developed a leak at the same connection and when I investigated, the
o-rings were worn. I replaced them and it is now O.K.
Back to top
fjpish
1st gear
1st gear
PostPosted: Mon Sep 08, 2008 7:23 am    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
vinnie, Was your t-fitting rubber-coated or was it metal or hard plastic or something? Mine whole t-fitting is rubbery and really doesn't seem like it would use o-rings. The part itself has two rings on each half that make contact with the inside of the hole.
Back to top
View user's profile
simona
2nd gear
2nd gear
PostPosted: Mon Sep 08, 2008 9:06 am    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
I think that there is an O-ring on either side of the pipe, a couple of carb sets I split have them on the T. Probably rot over time.
_________________
1981 - Seca XJ550 blue
1982 - Seca XJ550 white red
1983 - Seca XJ550 metallic grey
Back to top
View user's profile
mainexj550
4th gear
4th gear
PostPosted: Mon Sep 08, 2008 9:41 am    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
I had to replace mine due to leaking.
The one that came out had no o rings, it was coated in a rubbery compound.
I'm pretty sure the replacement I received from the Yamaha dealer was identical to the old one.
_________________
1982 xj 750 Seca 3K
Back to top
Broke_Dirty_Maxim
5th gear
5th gear
PostPosted: Mon Sep 08, 2008 10:42 am    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
I also recently replaced that tube due to leaking. The o-rings are required for the transfer tubes between the 1 and 2 and the 3 and 4 carb bodies. The T-fitting connects the 2 and 3 carbs, and does not have o-rings. The T-fitting is self sealing with the rubber coated lands. Personally, what I did, and would do if you are changing the middle tube, is to replace all the o-rings also. I figured, if the rubber tube was old enough to finally break down, so are the o-rings. Oh yeah, mine was on a 81 550 Maxim.
Back to top
View user's profile
fjpish
1st gear
1st gear
PostPosted: Mon Sep 08, 2008 11:45 am    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
OK, well I guess I'll order the t-fitting and o-rings for the other two connectors and see what I get. I really didn't plan on replacing the other o-rings, but since I've disturbed at least one set by taking off #1 & 2 from the rack, I might as well do them all. I'll probably get them from my local Yamaha dealer. Thank you all for your help.
Back to top
View user's profile
schmuckaholic
XJ Wizard
PostPosted: Mon Sep 08, 2008 12:19 pm    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
Chacal should be able to hook you up with the o-rings easily enough; I'm quoting the set of 8 because he doesn't list a set of 4. I also don't see a t-fitting in his price list.
HCP3458 OEM Mikuni fuel line Tube O-Ring, each: $ 3.50
HCP3458SET8 OEM Mikuni fuel line Tube O-Ring, set of 8: $ 26.50
HCP6880 Aftermarket Mikuni fuel line Tube O-Ring, made from a durable Buna-N rubber material, fits just like the originals at a much better price. Each: $ 1.00
HCP6880SET8 Aftermarket Mikuni fuel line Tube O-Ring, set of 8: $ 7.50
I'd be willing to wager he could get you the o-rings quicker than the dealer could order them in.
_________________
'82 XJ750J
(Thought it was borken.
Now, not so much.)
'85 XJ700XNC Maxim-X - New Toy!
Genius by birth; slacker by choice
Back to top
Broke_Dirty_Maxim
5th gear
5th gear
PostPosted: Mon Sep 08, 2008 12:37 pm    Post subject: Re: 1982 550 carb t-fitting fuel input Reply with quote
I got my replacement tube and all the o-rings, eight are listed because each transfer tube holds two o-rings on each side, from cheapcycleparts.com. Order processing is a little slow, so your order will arrive in about ten days.
Not saying anything bad about Chacal. I plan on ordering from him in the near future, but ordering these particular parts will be cheaper through cheapcycleparts.
_________________
'81 550 Maxim
Back to top
View user's profile
Display posts from previous:
Page 1 of 1
Jump to:
For Sale - early 80's XJ550 - American import.
Last post by HG85 in Sell, Trade, Swap, Wanted on Sep 03, 2010 at 08:34:58
Straight pipes
Last post by poprider in XJ Modifications on Sep 03, 2010 at 08:07:32
Will the lights work when the battery is dead?
Last post by zombiehouse in XJ Chat on Sep 03, 2010 at 07:35:52
Hey everyone
Last post by Lou627 in XJ Modifications on Sep 03, 2010 at 07:02:01
Questions questions....
Last post by Ravenz07 in General Lounge on Sep 03, 2010 at 06:07:46
Have to push start the Seca. Getting old...
Last post by likeitsmylast in XJ Chat on Sep 03, 2010 at 05:56:53
Absolutely need 100% silicone grease?
Last post by IAmMoen in XJ Chat on Sep 03, 2010 at 05:23:09
Bent clutch lever?
Last post by wizard in General Lounge on Sep 03, 2010 at 05:15:39
shaving the seat
Last post by tsmith in General Lounge on Sep 03, 2010 at 05:02:56
Two XJ650 Midnight Maxims (PART OUT) *PRICES REDUCED 50%*
Last post by vintagerice in Sell, Trade, Swap, Wanted on Sep 03, 2010 at 04:52:56
