 Latest: JimIndyV8
 New Today: 5
 New Yesterday: 6
 Overall: 8082
 Members: 14
 Visitors: 15
 Total: 29
Who Is Where: Members:01: 82maximXJ650Bobber > Forums
02: andrewlong > Forums
03: deadohiosky > Forums
04: dltaylor > Forums
05: finch > Forums
07: kornele > Forums
08: lopezfr2 > Home
09: MidniteMax > Forums
10: RECAC > Forums
11: Untaim1 > Forums
12: VanNorman6 > Forums
13: vulcan750 > Forums
14: xjdaver > Forums
12: My Account
15: My Account
Hidden: 1
We have received 35523422page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › tachometer inop
tachometer inopTechnical discussion ONLY for XJ Maxim/Seca...
snayke62 1st gear
Posted: Mon Jun 08, 2009 11:46 am Post subject: tachometer inop |
Well, hopefully my carb flooding problem is fixed. so on to the next thing. the tach doesnt work correctly. it comes up to about 1000 rps at idle. when revving it comes up some more but not accurately. this problem seemed to happen when i washed the bike for the first time a few weeks ago. i thought i remembered it working before that. it may have been a coincedence. Tach runs off one of the coils right? what other componants could be a factor- besides obviosly the tack itself.
_________________ 1983 Midnight Maxim 750 (My nightmare)
1985 Suzuki Madura GV1200 (My Baby) |
snayke62 1st gear
Posted: Mon Jun 08, 2009 1:02 pm Post subject: Re: tachometer inop |
I was researching tach parts on ebay to find that there is a tack drive and cable. apparenty this guage is mecanical and drives off the cam somwhere? I havent had a chance to look at the bike yet to see how its set up and troubleshoot it.
jamings67 5th gear
Posted: Mon Jun 08, 2009 2:13 pm Post subject: Re: tachometer inop |
Look at the front center of engine and you will see it.
_________________ First rule
Keep the shiny side up!
Last rule
BIKES
82 XJ1100J
1978 XS 750 TRIPLE
1979 GS1000E
1980 GS550E
PAST BIKES
1984 HONDA NIGHTHAWK 700
1976 KAWASAKI KZ400 |
snayke62 1st gear
Posted: Mon Jun 08, 2009 2:51 pm Post subject: Re: tachometer inop |
I found some good threads-Ill figure it out. Thanks.
TIMEtoRIDE XJ Wizard
Joined: Nov 05, 2007 Posts: 2364 Location: Clermont FL near Orlando
Posted: Mon Jun 08, 2009 2:53 pm Post subject: Re: tachometer inop |
Mechanical tach in '83?
I'm thinking spider webs inside. If it's electrical, there's another connection inside the headlight shell (I think, there was on the Seca)
Remove headlight and tank,
Pull and re-plug all related wires that have an orange and a grey.
_________________ '83 Seca 900 - - '81 Seca 750 - - '88 Venture Royale - - '84 Venture Project
2006 FJR 1300
xjbikes.com/Forums/vie...ation.html
Tire date code check:
www.xjbikes.com/Forums...vious.html |
Shannon72 4th gear
Posted: Mon Jun 08, 2009 3:01 pm Post subject: Re: tachometer inop |
Dang spiders. You would not BELIEVE how much webbing and carcasses I pulled out of my instrument cluster this weekend. Brutal!
_________________ In the immortal words of Socrates, "I drank what?"
1982 XJ550RJ, K&N 2-1 air filters, aftermarket 4-to-1 exhaust with megaphone muffler. 37k+ on the odometer
DONE: New Pirelli Sport Demon tires; new K&N 2-to-1 air filters (bike was podded when I got it); cleaned out the instrument cluster, new bulbs + LEDs for the tach and speedo; vacuum and fuel lines replaced; in-line fuel filter added; new chain and sprockets; new rear brake shoes; new clutch cable; new starter relay.
NEED TO DO: Not quite as much as before...rebuild the MC and front caliper and replace the front brakes; install an actual fuse box; eventually (when I have more room to work) clean the carbs; repaint EVERYTHING... |
ktcubed Red Liner
Joined: Oct 06, 2008 Posts: 594 Location: St. Augustine, FL
Posted: Mon Jun 08, 2009 3:03 pm Post subject: Re: tachometer inop |
Tack drive is off the front right of engine (at least on the 650), but you location may be different. It picks up the engine speed from a set of gears in side. This is transmitted to a rotating disk inside of the tach via the cable. Inside the tach, the disk (magnetic) spins inside of a "bell" (magnetic). The interaction of the two magnetic fields causes the bell to be twisted. Since the bell spin is countered by a spring, the travel is limited. The faster the spin the further the bell can pull the spring. There is no contact between the bell and the disk!
If you got water (or anything else) in the tach housing, they could interfere with the magnetic forces or spring. Wouldn't normally expect it to suddenly go bad.
Try the following. Pull the cable of and check the ends for damage, then lube it. (I use 3-in-1 oil, but any should do). Reinstall and see what happens.
If that doesn't fix her up, then pull the head cover and check that end for excess wear. (not likely).
_________________ 1982 seca 650 RJ
Done: Front and rear bearings; Braided brake lines and MC/Caliper clean/rebuild; Steering Bearings; Tank Seal; Fuel Filter; Fuse Block; Valve Adjust; Clutch Switch; Beginning Cosmetics; Seat cover; Paint started (cool green primer may be my final color); Torque fasteners and replace some; Rear brake shoes (after a delamination that locked the rear at slow speed); new tach and speedo w/ warning lights; new grips; paint; cleaned and repacked the swing arm bearings; Removed extra tail "fender"
In progress: Carbs - FL - help they just ain't right...
List: headlight change; HID?; LEDs?; Lower 1-2inches.
Finish cosmetics |
snayke62 1st gear
Posted: Mon Jun 08, 2009 3:06 pm Post subject: Re: tachometer inop |
Ill check that out. I need a new headlight anyway. I am gonna check the cable with a drill and make sure its turnig the tach sufficiently too. it maybe the transmission as well. Soon as the wife gets home to watch the rugrat, im gonna scope it out and run the hell out of it some more. i originally thought the tack ran off the coil- mechanical guages are easy.
ktcubed Red Liner
Posted: Mon Jun 08, 2009 4:14 pm Post subject: Re: tachometer inop |
Well then there are many cool after market gauges if you need them also. I just put some from MikesXS on and dumped the old and warning light thingy (now part of speedo). Next up is shrinking the head light (I think).
Finish cosmetics |
snayke62 1st gear
Posted: Mon Jun 08, 2009 6:28 pm Post subject: Re: tachometer inop |
I looked at the tach. its not mechanical. I havent taken it apart yet or checked the wiring. but would guess my guage is bad. there is a crack in the housing from PO laying the bike down. i bet water got in there and $#@% it up when i washed it. Ill keep yall posted with what i eventually find.
ktcubed Red Liner
Posted: Mon Jun 08, 2009 6:54 pm Post subject: Re: tachometer inop |
Still, plenty of cool after market gauges.
Finish cosmetics |
