XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: iamzeplin
New Today: 7
New Yesterday: 17
Overall: 7729
Members: 5
Visitors: 11
Total: 16
Who Is Where:
 Members:
01: chacal > My Private Messages
02: dwmauney > Forums
03: MiCarl > Forums
04: nickel98! > Forums
05: venlis > Forums
 Visitors:
01: My Account
06: Calendar
10: Photo Gallery
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
33578623
page views since
August 9, 2005
Forums › XJBikes Talk › General Lounge › sonic cleaners for cleaning carbs
Introduce yourself and everything else motorcycle related...
Post new topic   Reply to topic   Printer Friendly Page    Forum Index General Lounge
Author Message
cutlass79500
Red Liner
PostPosted: Fri Jan 29, 2010 2:18 pm    Post subject: sonic cleaners for cleaning carbs Reply with quote
hey everyone i wanted to get some opinions . im thinking of buying a sonic cleaner for cleaning carbs. everything i have herd has been all good will still clean them the old fashond way but i have 5 sets to do and some of them are really gumed up. I have never used them before i know some of you have if you have let me know how it did thanks
Back to top
MN-Maxims
XJ Wizard
PostPosted: Fri Jan 29, 2010 3:41 pm    Post subject: Re: sonic cleaners for cleaning carbs Reply with quote
I bought one from Harbor Frieght. I would say you would still have to run through the carb dip and then for a final cleaning use the sonic cleaner to knock more off inside. Mine has a heater in it so the simple green works really well when warm.
_________________
1981 XJ650H (Silver)
1982 XJ750J (Black)
1982 XJ750J (Red)
1982 XJ750J (Primer)
1982 XJ1100J (Black)
1983 XJ750K (Black)
1982 XJ1100J (Black & no second gear)
Current Project on the lift: 83 750 Maxim Air Box next. Black 1100 Second gear tranny problem
Back to top
cutlass79500
Red Liner
PostPosted: Fri Jan 29, 2010 4:42 pm    Post subject: Re: sonic cleaners for cleaning carbs Reply with quote
thanks i think im going to buy it. i planned on dipping the first and cleaning them the right way. but on 3 sets i have to do are on viragos the hitachi carbs on them dont have an idle jet its all unexposed and the mixture screw ajusts the flow. and they are a real p.i.t.a to get off and on you have to remove the intake boots just to get them off. i have shortcuts since ive taken so many off but still takes several hrs to remove and install them. my maxim x will be a breeze compared. Ive herd that lemon juice does a great job also in them but the acid is rough on the finish
Back to top
MN-Maxims
XJ Wizard
PostPosted: Fri Jan 29, 2010 9:13 pm    Post subject: Re: sonic cleaners for cleaning carbs Reply with quote
Actually the hot lemmon juice done right will brighten them up alittle but too long and they can turn dark grey. So I just dip them till most of the stuff is off and rinse right away.
_________________
1982 XJ750J (Black)
1982 XJ750J (Red)
1983 XJ750K (Black)
Back to top
cutlass79500
Red Liner
PostPosted: Tue Feb 09, 2010 1:11 am    Post subject: Re: sonic cleaners for cleaning carbs Reply with quote
Bought the sonic cleaner . first sprayed out all passages with gumout and cleaned them with torch tip cleaners . then dipped them. left overnight re sprayed them again blew them out . used simple green in the sonic washer . ran it 3 or 4 cycles about 20 min .unbelieveable what came out .I am very impressed altho turned the carbs a darker grey. im gonna use the baking soda blaster to make them look right again . but really does a good job made that simple green look very dirty
Ran into something ive never seen before it was a set of 40 mm hitachis off a virago . i set the float levels last time me they were apart i thought the float was sinking . The p.o some how bent the float pin in the middle it slid in fine then to compensate for the bent pin they opened up the clasp on the float so it was loose on the pin i guess it spun to the top and was enough to make the float to high and flooded out when you shut off the bike . you can bet these will be perfect before reinstalling . took about 3 hrs to take off the bike because of 1 float bowl allen screw was to close to the cyl to get it unscrewed ugh
Back to top
RickCoMatic
Moderator
PostPosted: Tue Feb 09, 2010 1:24 am    Post subject: Re: sonic cleaners for cleaning carbs Reply with quote
Use the Shank of a Pop Rivet cut to size and you got a Brandy-New Float Hinge Pin. One of them Pop Rivets is the perfect O.D.
I think its the 2nd size up. Not the small one.
_________________
Rick Massey
Moderator - Tech Writer
Use LOCATION Feature.
Back to top
cutlass79500
Red Liner
PostPosted: Tue Feb 09, 2010 1:56 am    Post subject: Re: sonic cleaners for cleaning carbs Reply with quote
great idea . im going to use the 1 and the float out of the spare set of carbs i have .im gonna rebuild them next. its gonna take a little time and patients to slowly bend the tabs on the float to fit the pin right these are to much of a pain in the but to put on and take off to take a chance of me not getting it right the first time . to be honest i think i can pull the motor faster then removing the carbs its like the bike was built around them . the chrome air cleaners has a giant tab welded to the frame with less then 1/8 in from the side and top comes over the slide diaphram cap so you have to pull the carb holders off the bike very very limited room on the inside bolts and with the carbs 1 pointing forward and the other backwards major nitghtmare give me a 4 cyl anytime
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Last post by Sanders in XJ Chat on Jul 29, 2010 at 18:48:46
it's tire time..
Tachometer is jumpy
Last post by shnuffy in XJ Chat on Jul 29, 2010 at 18:07:05
1982 xj650j parts for sale
Last post by tyler93 in Sell, Trade, Swap, Wanted on Jul 29, 2010 at 17:45:56
Cutting the Airbox, is this bad?
Last post by bkerby in XJ Chat on Jul 29, 2010 at 17:40:41
XJ Accessories and luggage
Last post by bkerby in XJ Chat on Jul 29, 2010 at 17:38:10
Speedo cable
Last post by kayaker in XJ Chat on Jul 29, 2010 at 17:29:49
my winter project 81 650 maxim
Last post by koolaid5 in XJ Modifications on Jul 29, 2010 at 17:14:26
