 Latest: iamzeplin
 New Today: 7
 New Yesterday: 17
 Overall: 7729
 Members: 9
 Visitors: 13
 Total: 22
Who Is Where: Members:01: brokenxj700 > Forums
02: dqnjuan > Forums
03: FinnogAngela > Forums
04: kirkn > Forums
05: Kylew11 > Forums
06: MojoJojo > Home
07: RefinedXJ > Forums
08: schooter > Forums
09: yeahyeah > Forums
04: Calendar
10: Home
We have received 33580181page views since August 9, 2005
Forums › XJBikes Talk › XJ Modifications › dominator headlight swap
dominator headlight swapCustom mods for XJ Maxim/Seca...
schnarr 3rd gear
Joined: Jul 07, 2008 Posts: 121 Location: kingston ontario
Posted: Fri Feb 05, 2010 9:15 am Post subject: dominator headlight swap |
quick question
81 seca with led signals
by removing the big signals and adding LED's, and by removing the headlight and fog/driving light. would i of gained enough extra power to run a dominator headlight (dual 55/60 watt bulbs)
schnarr 3rd gear
Posted: Sat Feb 06, 2010 10:13 pm Post subject: Re: dominator headlight swap |
bueller??
WesleyJN1975 Red Liner
Joined: Aug 24, 2006 Posts: 917 Location: Cherry Hill, NJ, USA
Posted: Sat Feb 06, 2010 11:00 pm Post subject: Re: dominator headlight swap |
Give it time schnarr, someone will chime in soon enough. You may want to try PMing some of the more knowledgable guys like Rickomatic, or BigFitz, or Chacal.
_________________ 1982 Maxim XJ650J
Keep the throttle wide open and the rubber on the road! |
chacal XJ Wizard
Joined: Aug 01, 2006 Posts: 4099 Location: At My Computer
Posted: Sun Feb 07, 2010 2:05 am Post subject: Re: dominator headlight swap |
Stock turn signals are 27W each (x 4), but only two operate at any one time, so that's 54W when they're on (which likely isn't too often). 54W = about 4.5 amps.
So replacing the turn signals with LED's (which have "basically" zero power consumption) will "make way" for the additional 55/60W headlight, but.......since the turns only use up wattage when they're on, you're still left with the power-draw considerations issue of when they're off.
Same issue with the stock "fog light"..........it's 35W, but only draws that wattage when it's on. And, I can't remember whether the fog light is allowed to operate when the main headlight is on either high- or low-beam setting, or whether it's a low-beam-only situation.
If the stock fog light can be operated on both high and low-beam main headlight settings, then the system is capable of 60W (main high-beam) and 35W (fog light), or a total of 95W in the lighting system.
Your two dominator lights, running at high beam, are consuming 120W, so you're still coming up 25W (about 2 amps) "short", electrically speaking. Your alternator may or may not be able to handle that load successfully, depending on your electrical system condition.
A better source of "finding" some additional wattage out of your stock system is the tail light bulbs (since they are always on), and they are 8W each (16W total draw). The license plate lamp is also an 8W "always on" draw, so replacing both of the tail-light bulbs and the license plate bulb with appropriate sized LED's will save you about 24W there, bringing your system back to "electrically equivalent" (in terms of constant load) to the stock system.
Additional electrical savings can be obtained from replacing the dash warning lights, as there are 7 of those small bulbs inside your cluster, and they are 3.4W each, a total of almost 24W in savings (only 3 of these bulbs are of the "always on" variety, though).
Be aware that replacing the tail-light bulbs with LED's, with their much lower power consumption, will likely cause you problems with the computer thinking that the bulbs are "out" and lighting the warning signal on the monitor.
You should probably give a lot of consideration to installing the dual headlights with a dedicated, relay-controlled wiring circuit all it's own, or you'll risk melting the headlight switch and gosh knows what else within the monitor that the stock headlight wiring circuit goes through!
_________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
xjbikes.com/Forums/vie.../f=23.html |
spltshft 1st gear
Posted: Sun Feb 07, 2010 3:06 am Post subject: Re: dominator headlight swap |
DUDE!
_________________ 1982 XS400 Maxim |
schnarr 3rd gear
Posted: Sun Feb 07, 2010 5:43 pm Post subject: Re: dominator headlight swap |
excellent write up thanks chacal im looking for info on wiring the headlight independently but still keeping my factory high beam switch. any infoon this or how to wire it up?
i could careless what the lcd warning crap says I'll cover them damn warning light with electrical tape lol
i'll look into 1157 led bulbs aswell for the tail light
also the fog light is on all the time with low beam
chacal XJ Wizard
Posted: Sun Feb 07, 2010 5:53 pm Post subject: Re: dominator headlight swap |
You'll need a headlight relay harness, basically it takes power directly from the battery positive terminal, and then the relay is switched on or off by the original headlight switch trigger wires (your original switch LO-HI for the headlight is what is used to "trigger" the low or high relay, and when a relay gets triggered, it then passes the 12V (battery) current "down the line" to whatever device it is controlling (in your case, the headlights).
User POLOCK has mentioned that the computer dash on the 750 Seca may interfere with the switching of the low-beam relay, in which case you need to tap off directly from the headlight switch wires, and not have those wires go through the computer system. You may wish to contact him for further info.........
schnarr 3rd gear
Posted: Wed Feb 10, 2010 9:38 am Post subject: Re: dominator headlight swap |
by tapping off wires before the computer/fish finder i would lose my high beam indicator light correct??
anybody happen to have a wireing diagram to create this circuit?
Polock XJ Wizard
Joined: Aug 13, 2006 Posts: 2444 Location: Beaver Falls, PA
Posted: Wed Feb 10, 2010 11:08 pm Post subject: Re: dominator headlight swap |
pardon the quick drawing
1 use the wires that go in the headlight plug to run the relays (black in the drawing) and you can't shut off the low beam when you switch to hi beam (the lo wire still had about 4 volts on it, enough to keep the lo relay picked up) don't know why but that's what happened
2a cuts out the speedo all together, no hi beam indicator, warning light flashes, but the headlight works as it should
2b never tried this probably same as 1
3 this might work if the brake/tail bulb could fool the speedo that it is the headlight the speedo might work normally
i just used 2a and took out the warning bulb and went for a ride
at night you WILL know when the hi beam is on, in the day it don't matter
another thing to do is run the power for the lights through the aux driving light switch (not used anymore) so you can turn off the headlight when you need the key on but don't want to kill the battery
| Description: |
| Filesize: |
25.54 KB |
| Viewed: |
1049 Time(s) |
schnarr 3rd gear
Posted: Thu Feb 11, 2010 9:35 am Post subject: Re: dominator headlight swap |
thanks polock,
you would have to wire it into a seperate switch to turn off though or else there no way to turn the headlight off right?
unless you taking your +12 from somewhere else other then direct to the battery
_________________ 81 xj750 seca
4-1 jardine exhaust
dominator head lights
LED signals and tail light
under construction |
Polock XJ Wizard
Posted: Thu Feb 11, 2010 5:55 pm Post subject: Re: dominator headlight swap |
if you had the small aux driving light you have a spare switch
hint, fill out your profile so we can get on the same page
schnarr 3rd gear
Posted: Fri Feb 12, 2010 9:57 am Post subject: Re: dominator headlight swap |
lol i always had a spare switch it never did squat though lol the aux light was just always on the switch never did anything lol
profile filled out
4-1 jardine exhaust
PainterD XJ Wizard
Joined: Jan 17, 2007 Posts: 2137 Location: St. Cloud, Minnesota
Posted: Sun Feb 21, 2010 10:42 am Post subject: Re: dominator headlight swap |
schnarr,
So did you ever get you Dominator headlights installed and working. Would like to see some photos of your mod if you can.
I'm looking into a dual headlight mod myself. Just trying to find dual filiment lights that are small enough to work without being too big and gawdy Threre are tons of smaller lights that would work, but I'd kinda like to have the high/low beam option, just because.
Let us know how things worked out for you. Thanks!
_________________ "And God looked down upon the bobber and was pleased, it did smoketh"! |
schnarr 3rd gear
Posted: Sun Feb 21, 2010 1:44 pm Post subject: Re: dominator headlight swap |
its ordered gonna start working on the harness this week most likely. keep watching my build thread to see whats new
4-1 jardine exhaust
