XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: iamzeplin
New Today: 7
New Yesterday: 17
Overall: 7729
Members: 7
Visitors: 11
Total: 18
Who Is Where:
 Members:
01: andrewlong > Forums
02: FZ808 > My Account
03: Gene > Forums
04: kirkn > Forums
05: odiosus > Forums
06: tcoop > Home
07: waldo > Forums
 Visitors:
01: Forums
02: Home
03: Calendar
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
33578073
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › XJ550 Maxim Project - Carbs finally off! -#PictureHeavy#-
Go to page Previous  1, 2
Author Message
Krashen
3rd gear
3rd gear
PostPosted: Fri Feb 05, 2010 3:11 pm    Post subject: Re: XJ550 Maxim Project -=[ Picture Heavy ]=- Reply with quote
If your carbs are still connected to the throttle i don't know how tore down your bike is.
But if its still connected there is the throttle bar that is connected to all 4 carbs right in front of the carbs try moving it with you hand up and down. if it moves up then its stuck down and if it moves down your stuck open.
_________________
Nut up or Shut up!
1982 XJ 550 Maxim (The Trooper)
15,xxx miles Running but looks terrible
Under Cunstruction to be bobbed
1982 XJ 550 Maxim (Restoring)
14,xxx miles Needs to start
Back to top
View user's profile
Grieverlust
1st gear
1st gear
PostPosted: Fri Feb 05, 2010 4:15 pm    Post subject: Re: XJ550 Maxim Project -=[ Picture Heavy ]=- Reply with quote
The bike is in the same state you see it in the photos on page one.
The old throttle cable was connected to the carbs and no Right side controls were present.
Got the new throttle handle and hooked it up and there is litterally no play in it. The cable is taught within 2-3mm of travel in the throttle handle. I will take a look and grab some pictures here for us in a second.
_________________
83' XJ550 Maxim - Project Bike
**Wanted** Roll cage for engine xj550 frame
Back to top
View user's profile
Grieverlust
1st gear
1st gear
PostPosted: Sun Feb 07, 2010 5:51 pm    Post subject: Re: XJ550 Maxim Project -=[ Picture Heavy ]=- Reply with quote
Hey Everyone,
There is definitely something stuck about the throttle. The cable moves freely but the part where it attaches near the carbs is locked. I tried to take some meaningful pictures but I dont know how helpful they will be.
Any ideas?
I ordered the wrong screws for the ignition switch. I was looking for the mounting bolts that go up through the black piece you put the key in. I ordered the larger bolts just behind it holding the metal bracket together.
Also got some new drag bars Very Happy
Thanks everyone! More to come soon.
_________________
Back to top
View user's profile
markie
Red Liner
PostPosted: Sun Feb 07, 2010 5:59 pm    Post subject: Re: XJ550 Maxim Project *Stuck Throttle* -=[ Picture Heavy ]=- Reply with quote
The throttle cable connects to a semi circular guide which opens the carb butterflies, 90 degrees. The linkage should shut and open freely (Against spring pressure). Disconnect the throttle and see if the linkage closes. There could be a mechanical reason - something like a stone or dropped washer mechanically preventing the throttles from closing.
_________________
Previous rides: Suzuki AP50, Suzuki GT250 (X2), Suzuki GT550, Honda 125T, Suzuki GT200, Honda CB500T, Yamaha RD250 Yamaha XJ 600
Back to top
bigfitz52
XJ Wizard
PostPosted: Sun Feb 07, 2010 8:23 pm    Post subject: Re: XJ550 Maxim Project *Stuck Throttle* -=[ Picture Heavy ]=- Reply with quote
More likely the throttle quadrant got caught under the fins on the back of the head when the rack went back on. Easy to do, even easier to do on the 550s (don't ask.)
Either that or the stub cable is not seated in its groove in the semi-circular guide and is caught on somethng instead.
Look under there carefully from the right; you should be able to see what's going on.
You'll need a shorter clutch cable for those bars; get a Seca 750 cable from Len it'll work great. You can re-route the extra throttle cable to go over the frame crosspiece there and have a straight shot down to the bracket.
_________________
'81 XJ550RH Seca- Recommissioned original classic daily rider; 26K miles stock except bars, seat, shocks and SS brake lines.
'83 XJ550RK Seca- "Toxic Asset"; 9K original miles, restored, modernized and personalized (nearly stock)
Wish I hadn't sold my SR500
Back to top
chacal
XJ Wizard
PostPosted: Sun Feb 07, 2010 9:24 pm    Post subject: Re: XJ550 Maxim Project *Stuck Throttle* -=[ Picture Heavy ]=- Reply with quote
"Quadrant", good word, I like it..........
_________________
Back to top
markie
Red Liner
PostPosted: Mon Feb 08, 2010 11:22 am    Post subject: Re: XJ550 Maxim Project *Stuck Throttle* -=[ Picture Heavy ]=- Reply with quote
Quadrant is a good word but brings back bad memories of a UK model Ford called a "Cortina".
The quadrant was a self adjusting plastic ratchet on the clutch pedal cable. They were cheap but a B1tch to change (Laying upside down, swearing,with a torch in your mouth and your head in the footwell)
_________________
Back to top
bigfitz52
XJ Wizard
PostPosted: Mon Feb 08, 2010 11:39 am    Post subject: Re: XJ550 Maxim Project *Stuck Throttle* -=[ Picture Heavy ]=- Reply with quote
Quadrant: From Websters: ...an arc of 90 degrees that is one quarter of a circle; a device or mechanical part shaped like or suggestive of the quadrant of a circle.
I was going for the latter...
_________________
Back to top
Grieverlust
1st gear
1st gear
PostPosted: Wed Mar 03, 2010 3:50 am    Post subject: re. XJ550 Maxim Project - Carbs finally off!-#PictureHeavy#- Reply with quote
The sun had come down on my face.. It was finally warm enough out to do some paint stripping in this part of the country... so I hopped to it Very Happy
Rolled her out on the driveway and dug deep finally. Getting ready to check valve clearances I took out the original spark plugs to see how it was running before it sat for 10 years. Here they are :
Plug 1
Plug 2
Plug 3
Plug 4
One was pretty oily. Two and four were about the same. Dark electrode and reddish core. Three was very clean. It looked like oil and gas poured out of the bike at some point based on the buildup on the swingarm and saturated air filter / box. Lets look at the carburetor now.
Of the four the first three have frozen diaphragm assemblies and the fourth moves freely.
Front
[img]Carb numbers ^(4,3,2,1)
On the inside of three there is a very solid pool of something that is rock hard and dark like oil but not liquid. Number two is by far the dirtiest on the outside.
Back
Carb numbers^(1,2,3,4)
I have about 4 of these solenoid holders that are broken that need replacement. Any ideas? Are they standard at auto stores? I am looking at a parts bike on craigslist too that will probably be profitable in the end because of the variety of small parts I need.
Do you think cracked coils is a problem? I am getting my ohmmeter back from a friend tomorrow so I will test them out and let you know.
Thats all for now. Will post more details tomorrow.
-B$
_________________
Back to top
View user's profile
bigfitz52
XJ Wizard
PostPosted: Wed Mar 03, 2010 6:35 am    Post subject: Re: XJ550 Maxim Project - Carbs finally off! -#PictureHeavy#- Reply with quote
Re: Coils-- not good, especially if the cracks go all the way through to the core. You can try flushing them out with some contact cleaner and then packing the cracks with black RTV, but I'd replace.
Re: Relay holders-- Not commonly available anywhere; never sold separately by MamaYama either. Ask chacal; or do what I do: wrap a small black zip tie around it, trim neatly and call it a day. I would say that between two bikes about half of mine are zip-tie "reinforced."
Re: Carbs-- Get your "eBay-fu" working and find another rack. Then you will have plenty of spare parts especially for the big stuff like bowls or a carb body. Be aware: The 550 Seca and 550 Maxim carbs, while the same, ARE different. They use a different needle and pilot jet but everything else is interchangeable. I got a nearly perfect set from the 'bay for $55.
_________________
Back to top
Grieverlust
1st gear
1st gear
PostPosted: Fri Apr 02, 2010 6:42 am    Post subject: Re: XJ550 Maxim Project - Carbs finally off! -#PictureHeavy# Reply with quote
I soaked the carbs and the diaphragms are all free now Very Happy
Still looking at getting a new set or a rebuild able one. This bike really needs to come together next week so I will be ordering a pile of parts this weekend. I also have my workspace back now as well Very Happy Updates soon.
_________________
Back to top
View user's profile
Display posts from previous:
Page 2 of 2
Jump to:
Last post by Sanders in XJ Chat on Jul 29, 2010 at 18:48:46
it's tire time..
Tachometer is jumpy
Last post by shnuffy in XJ Chat on Jul 29, 2010 at 18:07:05
1982 xj650j parts for sale
Last post by tyler93 in Sell, Trade, Swap, Wanted on Jul 29, 2010 at 17:45:56
Cutting the Airbox, is this bad?
Last post by bkerby in XJ Chat on Jul 29, 2010 at 17:40:41
XJ Accessories and luggage
Last post by bkerby in XJ Chat on Jul 29, 2010 at 17:38:10
Speedo cable
Last post by kayaker in XJ Chat on Jul 29, 2010 at 17:29:49
my winter project 81 650 maxim
Last post by koolaid5 in XJ Modifications on Jul 29, 2010 at 17:14:26
