XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: iamzeplin
New Today: 7
New Yesterday: 17
Overall: 7729
Members: 6
Visitors: 18
Total: 24
Who Is Where:
 Members:
01: brokenxj700 > Forums
02: dbikers > Forums
03: dwmauney > My Account
04: johno8 > Forums
06: RefinedXJ > Forums
 Visitors:
01: Calendar
08: My Account
Hidden: 1
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
33581188
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › Turn Signal Gremlin ~!
Author Message
midnitexj
1st gear
1st gear
PostPosted: Fri Mar 05, 2010 9:45 pm    Post subject: Turn Signal Gremlin ~! Reply with quote
Having an a problem with my right turn signal. Pull the signal switch to the left and it flashes fine, cancel and turn to the right side and all I hear is the relay fast clicking. Went to my Clymer Manual, not sure if I read it correctly. Thought it was a problem with the relay itself and bought a new relay from Yamaha. Still not getting power to my right turn signals. Is it the switch on the handle bar? Need some XJ experience with this one!
_________________
'83 XJ 750 Midnight Maxim
'96 Suzuki Sidekick Sport SOLD
'68 Ford 100 Lawn Tractor
Back to top
stereomind
XJ Wizard
PostPosted: Fri Mar 05, 2010 10:57 pm    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
Fast clicking and no lights = short circuit. Probably nothing wrong with the relay...
_________________
'80 650G cafe - current project - waiting on seat and paint
'81 Seca 750RH --- Mac 4-1, 53K Miles
'83 Maxim 550K --- All stock, 14K Miles, sold Sad
'84 Honda Magna V30 --- 23K miles, sold
'86 Yamaha Radian YX600 (another project)
Back to top
View user's profile ICQ Number Photo Gallery
midnitexj
1st gear
1st gear
PostPosted: Sat Mar 06, 2010 8:59 pm    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
So that means I need to look for broken wires, bad ground? Or would there be something in the switch on the bars?
_________________
Back to top
stereomind
XJ Wizard
PostPosted: Mon Mar 08, 2010 11:36 am    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
The cycling frequency on the stock flasher is affected by the load. If you hook up LED bulbs, it will not cycle at all, but if you short the wires at the turn signals, it will cycle really fast, and usually blow a fuse within a few seconds.
Most likely one of the turn signal pigtais is shorted to ground. You could try unplugging them one at a time and see if it stops cycling...
_________________
Back to top
wera90ex
2nd gear
2nd gear
PostPosted: Tue Mar 09, 2010 8:02 pm    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
Yep! what those guys said. Have you pulled off one or more of the sigs reasently?
I did, trying to install always-on lights in the front. Found out I pinched one of the wires putting the sig back on the stalk. If you've done anything with the wiring, go back and trace your steps.
If your doin' it for the first time, it ain't no sin to have to do it more than once. ...........just watch for sparks or what's smokin'.
_________________
'81 750 SECA '82 750 Seca K&N,Supertrap Ex
'81 gs 450 single shock bored to 597cc,GR650 head,89 gsxr 750 front end
'89 GS 500,bored to 555cc,11.5:1 pistons,37mm CR carbs,02 GSXR 750 front end,92 GSXR swinging arm w/ Ohlins shock,4.5 rear wheel
'94 GS 500,bored to 555cc,GR650 cams,37mm carbs,'07 GSXR 750 front end,4.5 rear wheel,Penski shock
I got more.
Back to top
View user's profile
schmuckaholic
XJ Wizard
PostPosted: Tue Mar 09, 2010 8:28 pm    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
Not to threadjack, but I've got a slightly similar problem with my 750 Max; my RH light comes on solid, but no chattering from the relay that I'm aware of.
Only thing that's been done is to move the relay when I swapped the coils, although I'm not thinking heat to be a problem.
_________________
'82 XJ750J
(Thought it was borken.
Now, not so much.)
'85 XJ700XNC Maxim-X - New Toy!
Genius by birth; slacker by choice
Back to top
Robert
Moderator
PostPosted: Wed Mar 10, 2010 12:39 am    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
Have you checked the grounds and/or the signal bulb socket Schmuck? How about the signal connections (the ones in the headlight bucket and under the rear seat).
I have fallen in love with my soda blaster for cleaning up crusty parts.
_________________
Robert
'81 XJ750RH Seca (ditto)
Past glory includes:
'86 XVZ1300 Venture Royal
'86 XT125
'84 GPz750A1 Ninja
'83 VF750F Interceptor
Back to top
schmuckaholic
XJ Wizard
PostPosted: Wed Mar 10, 2010 3:33 am    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
I have not, and I will do so.
I don't think I'd let your wife hear that if I were you. Wink
I have neither a soda blaster, nor a tiny undersized garage to stuff it in, but I'll come up with something.
_________________
'82 XJ750J
Now, not so much.)
Back to top
HogWild
1st gear
1st gear
PostPosted: Fri Mar 12, 2010 1:05 am    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
My turn signal has had the same issues. It took several steps to fix but works great now.
First take apart the left switch assembly and check the solders on the slider. 2 of 3 were disconnected on mine.
After this I was able to get a solid ON to the right indicator lights and no signal to the left lights. I used a trailer flasher where the original signal relay was. The factory is a 3 post but one of the wires does not need to be used. Can't remember which but I just bent it back and wired in the 2 post trailer flasher.
Next I had an issue a few days later with my right signals. The front would flash very fast and the rear was out. I looked at my fuses and they were flexing. After a few moments the signal fuse blew. To make a long story short the rear signal ground had come loose and appeared to be grounding out on the frame. After re-doing the connections the flashers worked like they were supposed to.
Back to top
View user's profile Visit poster's website
midnitexj
1st gear
1st gear
PostPosted: Fri Mar 12, 2010 8:39 pm    Post subject: Re: Turn Signal Gremlin ~! Reply with quote
Thanx for all the input. Will try these suggestions this weekend, and see what happens.
_________________
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Last post by johno8 in XJ Modifications on Jul 29, 2010 at 20:27:15
Stator rectifer questions
Last post by dwmauney in XJ Chat on Jul 29, 2010 at 20:25:55
81 GS = 81 XJ ???
Last post by kirkn in Other Motorcycles on Jul 29, 2010 at 20:04:55
electrics
Last post by jt1200r in XJ Chat on Jul 29, 2010 at 19:53:26
Last post by FinnogAngela in XJ Chat on Jul 29, 2010 at 19:49:43
Fork Rebuild
Last post by venlis in XJ Chat on Jul 29, 2010 at 19:44:48
Dual Discs XJ750 Seca
Last post by Zookie400 in XJ Chat on Jul 29, 2010 at 19:43:17
it's tire time..
