XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: njbobs
New Today: 8
New Yesterday: 17
Overall: 7730
Members: 6
Visitors: 17
Total: 23
Who Is Where:
 Members:
01: eightyeinstein > Forums
02: kirkn > Forums
03: Lou627 > My Private Messages
04: nickel98! > Forums
05: njbobs > Forums
06: superluckycat > My Private Messages
 Visitors:
01: Forums
16: My Account
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
33581711
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › bad fuel mileage no power
Author Message
bambam629
1st gear
1st gear
PostPosted: Thu Mar 11, 2010 5:29 pm    Post subject: bad fuel mileage no power Reply with quote
here we go my 85 maxim xj700 im getting about 50 miles on a tank of gas and im losing power i know that im only running on 1&4 just dont know why im getting spark to all four
_________________
never settle for average its as close to the bottom as the top
Back to top
View user's profile Yahoo Messenger
Lou627
6th gear
6th gear
PostPosted: Thu Mar 11, 2010 8:37 pm    Post subject: Re: bad fuel mileage no power Reply with quote
Are you sure your carbs are clean? Has it been like this since you got it?
_________________
81 xj650 maxim - Full rebuild rat chop
Back to top
PainterD
XJ Wizard
PostPosted: Fri Mar 12, 2010 6:19 am    Post subject: Re: bad fuel mileage no power Reply with quote
Old chineese saying, "Sum ting wong" comes to mind. There must be a carb issue going on in there. 50 miles to a tank full? Ya, and no power? I can't think of where to start with that one. Maybe a brake is draging? Something must be holding it back or the engine is just plain running way rich.
_________________
"And God looked down upon the bobber and was pleased, it did smoketh"!
Back to top
View user's profile
mlew
Red Liner
PostPosted: Fri Mar 12, 2010 7:45 am    Post subject: Re: bad fuel mileage no power Reply with quote
Hopefully its nothing obvious like a bad fuel leak. I bet there is black smoke comming from your exhaust, way too moch fuel burning. Pull the carbs and clean them. Pay special attention to the fuel enrichment (choke) and float height.
_________________
85 XJ700 Maxim X
82' XJ1100
82' XJ750 (gone)
80' XS1100
79 'XS1100
Back to top
View user's profile Send e-mail Photo Gallery
day7a1
5th gear
5th gear
PostPosted: Fri Mar 12, 2010 8:06 am    Post subject: Re: bad fuel mileage no power Reply with quote
Strangely enough, you answered your own question. You are getting bad mileage and poor power because you are only running on 1 & 4. Next step, figure out why you are running on 1 & 4 only. Probably not solely due to the carbs, as it would be unlikely that 2 & 3 are completely gummed up but 1 & 4 are fine. My first guess would be weak spark on 2,3.
It's possible to be getting spark but not have the cylinder fire. Before you pull your carbs, check the compression, spark plugs, coil resistance, maybe even run some seafoam through it to see if it helps. Pulling and cleaning the carbs is a big deal, and likely needs to be done, but doing it first when it could be the spark is simply bad troubleshooting.
Sorry everyone, but it seems that carb cleaning is everyone's first thought here, but how would you feel (I would feel dumb as a rock, personally) if you pulled the carbs to clean them, only to discover your bike wouldn't run because you were out of gas. There's a reason we start with the simple things first!
_________________
'82 XJ650J Maxim, Please respond to www.xjbikes.com/Forums...25804.html a poll about your gas mileage!
Back to top
View user's profile
BlackMax
4th gear
4th gear
PostPosted: Fri Mar 12, 2010 8:13 am    Post subject: Re: bad fuel mileage no power Reply with quote
could also be a plugged up air filter...........
_________________
81 550 maxim (former basketcase)
new spitfire tires
new clutch cable
new master cylinder
new grips and mirrors
new h-pipe and mufflers
Back to top
View user's profile
BlackMax
4th gear
4th gear
PostPosted: Fri Mar 12, 2010 8:14 am    Post subject: Re: bad fuel mileage no power Reply with quote
_________________
new spitfire tires
new clutch cable
new master cylinder
Back to top
View user's profile
TIMEtoRIDE
XJ Wizard
PostPosted: Fri Mar 12, 2010 9:40 am    Post subject: Re: bad fuel mileage no power Reply with quote
A plugged air filter would fowl all 4
You could double-check the coil by switching the little 2 wire connectors, and all 4 plug wires so that the 1/4 coil fires the 2/3 plugs.
This double-checks the 2/3 coil.
Then after switching the above back to normal,
try squirting just a little starting fluid into 2 and 3 while running.
Spray into the air box.
This confirms that you need to "do" the carbs.
_________________
'83 Seca 900 - - '81 Seca 750 - - '88 Venture Royale - - '84 Venture Project
2006 FJR 1300
xjbikes.com/Forums/vie...ation.html
Back to top
prock
3rd gear
3rd gear
PostPosted: Fri Mar 12, 2010 3:02 pm    Post subject: Re: bad fuel mileage no power Reply with quote
How does one spray fluid into just one cylinder? I asked how to use starter fluid a few days ago and was told to spray it into the air intake duct.
What is the air box? The housing for the air filter and intake duct?
_________________
1983 Maxim 750
Back to top
View user's profile
TIMEtoRIDE
XJ Wizard
PostPosted: Fri Mar 12, 2010 5:11 pm    Post subject: Re: bad fuel mileage no power Reply with quote
With the air filter out, try to spray into the center 2.
Sometimes you can put a carb cleaner straw into a starting fluid spray nozzle. You can also staple a small rag to a paint stir stick, soak it in gas, and wave it in front of your suspect carb inlets.
_________________
2006 FJR 1300
Back to top
bambam629
1st gear
1st gear
PostPosted: Fri Mar 12, 2010 10:50 pm    Post subject: Re: bad fuel mileage no power Reply with quote
found the problem lil more drastic than i hoped but not life ending lol intake valves were not adjusted properly up and running again thanks for the help everyone yall ride safe
_________________
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Last post by johno8 in XJ Modifications on Jul 29, 2010 at 20:27:15
Stator rectifer questions
Last post by dwmauney in XJ Chat on Jul 29, 2010 at 20:25:55
81 GS = 81 XJ ???
Last post by kirkn in Other Motorcycles on Jul 29, 2010 at 20:04:55
electrics
Last post by jt1200r in XJ Chat on Jul 29, 2010 at 19:53:26
Last post by FinnogAngela in XJ Chat on Jul 29, 2010 at 19:49:43
Fork Rebuild
Last post by venlis in XJ Chat on Jul 29, 2010 at 19:44:48
Dual Discs XJ750 Seca
Last post by Zookie400 in XJ Chat on Jul 29, 2010 at 19:43:17
it's tire time..
