 Latest: iamzeplin
 New Today: 7
 New Yesterday: 17
 Overall: 7729
 Members: 7
 Visitors: 17
 Total: 24
Who Is Where: Members:01: brokenxj700 > Forums
02: dbikers > Forums
03: dwmauney > Forums
04: FinnogAngela > Forums
05: johno8 > Forums
06: Kylew11 > Forums
07: RefinedXJ > Forums
05: Calendar
06: Home
08: My Account
We have received 33580973page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › super stuck oil filter bolt!!!!
super stuck oil filter bolt!!!!Technical discussion ONLY for XJ Maxim/Seca...
Go to page Previous 1, 2, 3 Next
Robert Moderator
Joined: Feb 06, 2006 Posts: 6663 Location: Ventura CA
Posted: Tue Jan 23, 2007 10:08 pm Post subject: Re: super stuck oil filter bolt!!!! |
Hammer and chisel worked for me PBR. I've also used a very large socket I pounded into place over the buggered head. If your very careful, you can even salvage stuck bolts with the chisel method (just gotta file down the curls). I also have use a hack saw to cut a very large slot across the head of the bolt and use an impact hammer to losen it up!
_________________ Robert
'81 XJ750RH Seca (ditto)
Past glory includes:
'86 XVZ1300 Venture Royal
'86 XT125
'84 GPz750A1 Ninja
'83 VF750F Interceptor |
pbr_street_gang 3rd gear
Joined: May 13, 2006 Posts: 89 Location: Los Angeles, CA
Posted: Tue Jan 23, 2007 10:09 pm Post subject: Re: super stuck oil filter bolt!!!! |
Thanks for all the advice. I'm off to the "tent" to work on this thing and I'll report back shortly.
_________________ 81 xj550
70's Masi track bike |
Posted: Wed Jan 24, 2007 1:54 am Post subject: Re: super stuck oil filter bolt!!!! |
Wah Wah. Failure. I think that the bolt has been sabotaged. Here's what went down. I tried to chisel it to no avail. I then dremeled off the mangled bolt head but, couldn't get in closer to get the larger washer part off. With the bolt off I could get the bolt extractor way in there. I tapped it in a little and hooked up a 1/2 inch impact drill and nothing. It spun out from the extractor. So I'm feeling totally beaten. I'm going to see if I have the strength to hack away at it again tomorrow. I really feel like somebody put something crazy on it because, it's practically seamless from where the larger washer part of the bolt fits on to the filter. I guess if there's a way to completely rip out the bolt that's the point I'm at now.
Thanks for all the help. Maybe this thread helped some other people get some stuck stuff lose.
woot Moderator
Joined: Jan 05, 2006 Posts: 1252 Location: 44.777479/-63.676489
Posted: Wed Jan 24, 2007 5:44 am Post subject: Re: super stuck oil filter bolt!!!! |
You don't have the same extractor that Ace and I have... next time try one of those as they are considerably better. Now you are as far as you are you pretty much will have to cut the whole bolt head off - this will let the filter housing off, which in turn will take some of the preasure off of the filter bolt.
Good luck, woot
_________________ Halifax, Nova Scotia, Canada
2000 CBR 600
1981 XJ650 Maxim (SOLD)
1995 ZX600r Ninja (SOLD) |
Travis-Mc 2nd gear
Posted: Thu Jan 25, 2007 10:47 am Post subject: Re: super stuck oil filter bolt!!!! |
I would have taken the sawzall to it by now.. haha.. just cut the whole filter housing right in half and buy a new one on ebay..
woot Moderator
Hvnbnd XJ Wizard
Joined: Apr 25, 2006 Posts: 1155 Location: Wht Mtns, Arizona
Posted: Thu Jan 25, 2007 11:38 am Post subject: Re: super stuck oil filter bolt!!!! |
As was said before, if you can grind drill saw file the rest of the bolt head off you can slip off the filter housing. Then you can unscrew the bolt out of the case with a pipe wrench.
_________________ If it's worth fixin, it's worth fixin right!!
1985 XJ700N Maxim
1982 1100 Goldwing (History!!!)
Wish I still had my 1952 125 Harley Hummer |
Posted: Thu Jan 25, 2007 1:19 pm Post subject: Re: super stuck oil filter bolt!!!! |
I got it out!!!!!
Hey ya'll thanks again for the help. I got it out by cutting off the larger washer part of the bolt and the filter slipped right off and the bolt came out. Now it looks like my filter cover is a little jacked up and the new bolt might not seal well to the cover. So I'm going to be looking for a new filter cover and probably posting a new topic about that.
MacMcMacmac Red Liner
Joined: Jan 06, 2006 Posts: 591 Location: Ottawa, Canada
Posted: Thu Jan 25, 2007 10:08 pm Post subject: Re: super stuck oil filter bolt!!!! |
If you are going to pay for another filter cover, why not save yourself some grief and go the spin-on filter adapter route? No more stuck covers, ever!
See the sticky topics on top of the main forum page.
Hvnbnd XJ Wizard
Posted: Thu Jan 25, 2007 10:10 pm Post subject: Re: super stuck oil filter bolt!!!! |
That's what I'd do if I were where youre at.
Probably cost about the same and filters would be easier to come by.
1985 XJ700N Maxim
Posted: Thu Jan 25, 2007 11:12 pm Post subject: Re: super stuck oil filter bolt!!!! |
Sounds cool. thanks for the tip. I'll check it out.
Charlie_1985 Gear grinder
Joined: Jan 24, 2007 Posts: 6 Location: Moncton NB Canada
Posted: Mon Jan 29, 2007 9:10 pm Post subject: Re: super stuck oil filter bolt!!!! |
get a friend with a welding unit to weld a nut on your bolt then just take it off, the heat will also help taking the bolt off, that's what I did, worked great!
Hvnbnd XJ Wizard
Posted: Tue Jan 30, 2007 1:53 am Post subject: Re: super stuck oil filter bolt!!!! |
You could try one of these bolts
cgi.ebay.com/ebaymotor...2937QQrdZ1
Or better yet, here's the whole thing & at a really decent price!!!
cgi.ebay.com/B246-85-Y...dZViewItem
Good Luck
1985 XJ700N Maxim
Posted: Tue Jan 30, 2007 2:06 am Post subject: Re: super stuck oil filter bolt!!!! |
Thanks guys. I got a new bolt and I'll have the new cover by saturday. Then I'll be back on the road.
Tony66 1st gear
Posted: Sun Jul 01, 2007 11:21 am Post subject: Re: super stuck oil filter bolt!!!! |
I've been fighting the dammed oil filter cover bolt for over two hours when I realized that I can't be the only person having this problem. I take some small measure of comfort knowing I'm not the only one who's run into this. So far I've managed to strip the bolt head using wrenches, sockets, and vice grips. My new set of Sears damaged bolt head sockets don't do much good either. They bite well enough, but the bolt stays put while they just gouge in deeper. I'm going to try a small monkey wrench next, but if that fails I'll have to break the bolt off with a chisel. Am I correct in assuming that the washer is actually part of the bolt head? I can't really tell for sure. Should I be placing the chisel between the head and the washer, or behind the washer next to the cover?
