XJBikes.com
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: thedesolatewest
New Today: 5
New Yesterday: 16
Overall: 6472
Members: 4
Visitors: 8
Total: 12
Who Is Where:
 Members:
01: assassinx1 > Forums
02: csmith67467 > Forums
03: MiCarl > Forums
04: mrmustangman357 > Forums
 Visitors:
01: Forums
04: Home
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
26606317
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › Jets or...? HELP!!!!
Go to page Previous  1, 2, 3
Author Message
chacal
XJ Wizard
PostPosted: Thu Mar 06, 2008 10:11 am    Post subject: Re: Jets or...? HELP!!!! Reply with quote
Khornet....you've got a private mail awaiting you!
_________________
Back to top
khornet
1st gear
1st gear
PostPosted: Thu Mar 06, 2008 8:32 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
gotcha Thanks Len!
I just went thru them all. I picked up a $.40 medical syringe at walmart that fits nicely in that brass tube and allowed me to inject carb cleaner down thru that tube/jet. I pulled all the "starter sets" and I saw the cleaner freely flowing thru each. I put it all back together, reinstalled the carbs and it appears I've now made some great progress. It's still not perfect but the bike mostly idles now without the choke and is much more responsive to the throttle.
I still haven't connected up the airbox yet, but this is very encouraging. I'm now trying to figure out how I'm going to get those airbox connectors in there. so I've got a "real world " test. I think a good long soak in some hot water is the start, so they will at least be more pliable to work in that cramp space.
_________________
81 Seca XJ550RH 15K miles
82 Seca XJ550RJ 3K original miles
Back to top
View user's profile
MiCarl
XJ Wizard
PostPosted: Thu Mar 06, 2008 8:48 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
Not sure how your clutch cable is routed, but on my 650 it is almost impossible to get the intake boot for #3 in from the right side because the clutch cable blocks access. Much easier to do it from the left.
I do them 3, 2, 1 from the left then #4 from the right.
_________________
1982 XJ 650 Maxim - SOLD Sad
1989 XVZ1300 Venture Royale
Back to top
khornet
1st gear
1st gear
PostPosted: Thu Mar 06, 2008 8:50 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
shouldn't be an issue, the cable isn't even close.
_________________
Back to top
View user's profile
RickCoMatic
Moderator
PostPosted: Thu Mar 06, 2008 10:25 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
Hook-up the two inside ones first.
Do the two outside ones last.
Make a tool that you can use to "Shoe Horn" the Boots over the Intake necks if they don't just fold-back and flop right into place.
Use the locating tab on the outside diameter of the Boot to line it up right to get them on the way they came off.
Make sure the tool you make doesn't have a sharp edge that will slice the Boot.
_________________
Rick Massey
Moderator - Tech Writer
Use LOCATION Feature.
Back to top
khornet
1st gear
1st gear
PostPosted: Thu Mar 06, 2008 10:34 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
Already Done! took about 15 minutes of Mr Circus Rubber hands to get all those airbox boots installed.
Now it runs even a bit better but still revving high and not coming down immediately (but least it does eventually come down now). still idles at @1200rpm nicely which it never would do before.
I'll give it a fresh tank of new premium gas, some Seafoam, and then I'm going to ride it a bit to see if it gets better. If not I'll take yet ANOTHER look at those slides and break out the polish.
_________________
Back to top
View user's profile
RickCoMatic
Moderator
PostPosted: Fri Mar 07, 2008 11:23 am    Post subject: Re: Jets or...? HELP!!!! Reply with quote
12-Hundred isn't Idle.
12-Hundred is just off-idle and you are probably bringing-in some Main Jet Fuel.
Try adjusting the Idle Adjustment Rod, below and between the 2 & 3 Carb to reduce RPM's to below 11-Hundred.
1,050 should be the High-side of Idle. 900 being really good and dependent on Pilot Mixture Air~Fuel alone.
If the Idle Adjustment Rod will not adjust-out the High revving Idle, you may have to undo the Throttle Cable Slack adjuster at the Throttle Perch to slack-0ff the Cable slightly. There should be a little slack in the Cable to allow the Throttle Butterfly's to close.
It sounds like you are close to being where the Bike needs to be. Bear in mind that the Final adjustments are determined by actually looking at individual Plugs after the Bike has been run some.
When you get ready to make >Tweak< adjustments ... the Tweaking is a VERY SLIGHT movement of the Pilot Mixture Screw.
Since the P-M-Screws are ultra fine threaded ... you may only need to Enrich or Lean-out an individual Screw with a slight movement.
This SLIGHT Movement is measured in degrees. Not anything in fractions.
You should inspect the Plug.
Determine if that Plug's color is too Dark or Light and make the adjustment accordingly.
When determining if the Mixture is too Lean, you have to take a close look at the Ceramic Tip surrounding the Plug's Base Electrode.
The Ceramic will be colored from the Combustion.
If the Plug is looking CLEAN ... a Lean condition is happening.
Too Lean will overheat that Ceramic and cause it to deteriorate.
The Ceramic will also begin to show hairline fractures from the stress of the hole being too Lean.
Too Rich is obvious. The Plug will be dark with unburned Fuel stain.
You should Tweak the Pilot Mixture Screw of that Cylinder until the Plug is Tanned or a light Brown.
Don't be persuaded by how well the Bike will run in a slightly LEAN configuration to leave it Lean.
Too lean is a HOT Mixture that will soon take its toll on the Engine; causing the gases to be too hot and subjecting the Valves, Seats, Piston Crown, Cylinder Hole and Cylinder Head to higher temperatures than Normal.
You look to achieve a coloration of the Plugs that is Light Brown.
Within this window of find tuning is a narrow window of differing performance.
Lean: Faster acceleration, crisp throttle and engine braking.
Rich: Smooth application of power, smooth acceleration and engine coasting when the throttles are closed.
_________________
Rick Massey
Back to top
khornet
1st gear
1st gear
PostPosted: Fri Mar 07, 2008 1:26 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
WOO HOOOO!!!!! IT's ALIVE!!!!!!
Started her up today and let it run to operating tempeture. I noticed I now had good throttle response, although running at 4K rpm. Made me think the idle speed was just way out of whack so I cranked it down and it's now running great! Idling normally at 1K with no choke.
Time for fine tuning. I'll pickup one of those colortune plugs and a Carbtune for sycn'ing them all. Between the two bikes I'll get my money out of both. (I've already got my YICS tool). Probably need the valve adjustment tool while I'm at it.
I can't thank you guys here on this forum enough for your comments and giving me the confidence to jump in on this and resolving the issue!
Len I still owe you a call and you'll be hearing from me in the next few days.
_________________
Back to top
View user's profile
Jim_Vess
5th gear
5th gear
PostPosted: Fri Mar 07, 2008 5:06 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
Idle spec for the 550 is 1200rpm.
This is according to the Clymer's manual.
_________________
2005 Yamaha YZF-R6
1981 Yamaha XJ550RH Seca
Back to top
khornet
1st gear
1st gear
PostPosted: Fri Mar 07, 2008 6:07 pm    Post subject: Re: Jets or...? HELP!!!! Reply with quote
I've got her idling comfortably at 1K without any further tuning.
_________________
Back to top
View user's profile
Display posts from previous:
Page 3 of 3
Jump to:
blew the dust off the bike today
Last post by assassinx1 in XJ Modifications on Mar 11, 2010 at 03:40:40
grips
Last post by bkerby in XJ Chat on Mar 11, 2010 at 03:36:35
Diaphragm Questions
Last post by Polock in XJ Chat on Mar 11, 2010 at 03:33:58
magnetic decals
Last post by bkerby in General Lounge on Mar 11, 2010 at 03:33:32
master cylinder
Last post by Polock in Sell, Trade, Swap, Wanted on Mar 11, 2010 at 03:26:30
OK call me a numpty if you like.
Last post by razz1969 in General Lounge on Mar 11, 2010 at 03:16:43
Fuel drip from pet(edited)
Last post by Hillsy in XJ Chat on Mar 11, 2010 at 03:14:19
1983 XJ750 rear end problem...
Last post by Hillsy in XJ Chat on Mar 11, 2010 at 03:10:37
750 alternator seal & o-ring questions
Last post by ski84 in XJ Chat on Mar 11, 2010 at 02:56:23
having problems keeping it running
Last post by csmith67467 in Other Motorcycles on Mar 11, 2010 at 02:55:05
