 Latest: iamzeplin
 New Today: 7
 New Yesterday: 17
 Overall: 7729
 Members: 6
 Visitors: 14
 Total: 20
Who Is Where: Members:01: chacal > My Private Messages
02: hogfiddles > Forums
03: MiCarl > Forums
04: tcoop > Forums
05: venlis > Forums
06: xjdaver > My Private Messages
Visitors:01: Photo Gallery
We have received 33578723page views since August 9, 2005
Forums › XJBikes Talk › Other Motorcycles › Hey question about 1982 XJ750
Hey question about 1982 XJ750Technical discussion for NON XJ motorcycles..
Tang Biker wannabe
Posted: Sun May 18, 2008 9:39 pm Post subject: Hey question about 1982 XJ750 |
Ok so there is a 1982 XJ750 for sale around my place for $600obo
and i was wondering how reliable is the transmission
i've heard some ppl says when it craps out it can't be fixed?
dunno would love to hear some opinions about this kind of bike
i currently have a 1997 GS500E
samsr Red Liner
Joined: Jul 13, 2006 Posts: 605 Location: Colorado Springs
Posted: Sun May 18, 2008 10:17 pm Post subject: Re: Hey question about 1982 XJ750 |
I had an 82xj750. I never had an issue with the trans. As long as you shift a resonable foot you shouldn't have a problem. Some people have had issues with the plastic guide coming apart and lodging itself/gumming up the tranny but thats about it. I liked my 750 pretty well.
_________________ 1982 XJ750J maxim Sold (sniff, sniff)
1985 xj700
stock, but very polished, 9500 miles on the ticker
Dark blue pearl in color
National Cycle wind screen
operating 6000 feet in elevation, next to gods country. Rocky Mountains |
Tang Biker wannabe
Posted: Sun May 18, 2008 10:58 pm Post subject: Re: Hey question about 1982 XJ750 |
hmm sweet
Robert Moderator
Joined: Feb 06, 2006 Posts: 6663 Location: Ventura CA
Posted: Mon May 19, 2008 8:24 am Post subject: Re: Hey question about 1982 XJ750 |
Tang, your sources are misinformed. The transmissions are very reliable. There is an issue with bikes that have been sitting for a while. The starter chain guide dries out and the plastic pieces break off and fall onto the transmission gears, locking them up. The repair is not impossible but requires the removal of the engine to do it right. It's a $20 part. I've had to pull my engine and do this repair so I'd say it isn't impossible. If you like what you see and the compression is 120 psi give or take, it sounds like a decent deal.
_________________ Robert
'81 XJ750RH Seca (ditto)
Past glory includes:
'86 XVZ1300 Venture Royal
'86 XT125
'84 GPz750A1 Ninja
'83 VF750F Interceptor |
Fode140 3rd gear
Joined: May 01, 2008 Posts: 82 Location: Wauconda, Illinois
Posted: Mon May 19, 2008 1:16 pm Post subject: Re: Hey question about 1982 XJ750 |
I agree, sounds like maybe some of your sources heard one story and applied it as a foregone conclusion to happen to ALL XJ's. I had an '81 Seca that I had bought in about '00 or '01 with 17,000 miles on the clock. It had sat without even being started for OVER 10 YEARS! Paid $250 for it, cleaned the carbs, sealed the tank, changed all of the fluids and had the brakes bled and new tires put on, and over the next four years put another 17,000 trouble free miles on top of the original 17,000! The most serious problem I had you ask? A (I think) $23 clutch cable that took me about five minutes to change at around 30,000 miles! Ended up selling it with just over 34,000 on it. Maybe I was lucky since mine had sat for so many years without starting, but proved it's reliablilty enough for me to buy my '83 "full dresser" Seca!
_________________ '83 XJ750 Seca "dresser" (in pieces)
Past rides:
'81 XJ750RH Seca (shouldn't have sold it!)
'84 Honda VF1100S Sabre (GLAD I sold it)
'05 V-Max Anniversary Edition (it was fun!) |
bigellis Biker wannabe
MN-Maxims XJ Wizard
Joined: May 03, 2008 Posts: 1396 Location: Saint Paul, MN
Posted: Sun May 25, 2008 10:14 pm Post subject: Re: Hey question about 1982 XJ750 |
I have three 750 Maxims, None of mine have ever had any trans problems, I have had the same problems they all have like Fuse box problem where your just switch to something more reliable. Fork seals, Carb cleaning, Valve adjustments, Just routine maintenance. My 650 is a none YICS so it is alittle easier to Carb Sync. The 1100 has has clutch issues but I will have some aftermarket springs to install. That should help the slipping problem. If the compression is good and the bike is in good condition it should run along time with alittle TLC. Good Luck.
_________________ 1981 XJ650H (Silver)
1982 XJ750J (Black)
1982 XJ750J (Red)
1982 XJ750J (Primer)
1982 XJ1100J (Black)
1983 XJ750K (Black)
1982 XJ1100J (Black & no second gear)
Current Project on the lift: 83 750 Maxim Air Box next. Black 1100 Second gear tranny problem |
samsr Red Liner
Posted: Sun May 25, 2008 10:15 pm Post subject: Re: Hey question about 1982 XJ750 |
"please help I have got a 1984 virago 700 and when you pull it into gear and relese the clutch it does nothing"
"Bigellis" you may get better luck if you put this post under the other motorcycle threads. That being said. Check youe cable adjustment. It may be way to tight. Can you feel it bump into gear when you put it into gear?
1985 xj700
