XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: iamzeplin
New Today: 7
New Yesterday: 17
Overall: 7729
Members: 8
Visitors: 20
Total: 28
Who Is Where:
 Members:
01: andrewlong > Forums
02: brokenxj700 > Forums
03: dwmauney > Forums
04: FinnogAngela > Forums
05: johno8 > Forums
06: Kylew11 > Forums
07: Plumber > Forums
08: RefinedXJ > Forums
 Visitors:
01: Forums
02: Calendar
05: My Account
06: Home
10: Calendar
14: Home
19: Forums
20: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
33580914
page views since
August 9, 2005
Forums › XJBikes Marketplace › Sell, Trade, Swap, Wanted › Need coils
Need coils
Anything for sale or trade...
Post new topic   Reply to topic   Printer Friendly Page    Forum Index Sell, Trade, Swap, Wanted
Author Message
igormothra
1st gear
1st gear
PostPosted: Sun Jun 29, 2008 4:09 pm    Post subject: Need coils Reply with quote
I would like to replace the coils on my 900 seca anyone know where to get new ones? My local dealer isn't so local and they don't seem to want to be bothered with anything this old
Back to top
View user's profile
Anthony14
Red Liner
PostPosted: Sun Jun 29, 2008 4:41 pm    Post subject: Re: Need coils Reply with quote
Chacal has some.
Get the Dyna ones HCP245 for $119.00 for 2
and the leads and caps for $18.00.
When mine go that's what I am getting:D.
_________________
1981 XJ550 chopper. And my first bike:D - in the process of being sold Sad
Back to top
RickCoMatic
Moderator
PostPosted: Sun Jun 29, 2008 5:05 pm    Post subject: Re: Need coils Reply with quote
I'm having the Same Problem with my 900. Coils. Or so I thought!
Actually, the problem was the wires.
Since the wires are part of the Coil ... you naturally suspect that replacing the whole Coil is necessary.
Not so.
You can do some light surgery to the Coil and replace the wires with new high-performance wiring.
(Just go to a junk yard and rip yourself a couple off a BMW or Audi).
_________________
Rick Massey
Moderator - Tech Writer
Use LOCATION Feature.
Back to top
igormothra
1st gear
1st gear
PostPosted: Sun Jun 29, 2008 6:07 pm    Post subject: Re: Need coils Reply with quote
I have a decent spark coming through, so I probably could get away with just replacing the wires... how light of surgery is it? before I go tearing into the coils....
_________________
83 XJ900 SECA
Back to top
View user's profile
chacal
XJ Wizard
PostPosted: Sun Jun 29, 2008 7:24 pm    Post subject: Re: Need coils Reply with quote
I also offer some spark plug wire SPLICERS that allow you to easily remove most of the plug wire from the original coils and replace them with new wire:
Spark Plug Wire Splicer:
pw1) Aftermarket NGK-brand SPARK PLUG WIRE SPLICER. This handy little device allows you to cut off a bad original plug wire and splice in a replacement piece, which is really handy, since the plug wires on the original factory coils are basically non-replacable......so if a plug wire goes bad, the whole coil is basically junk! Not real clever factory engineering, but there you have it.
This splicer allows you to extend or replace a damaged or bad plug wire, just like you would splice into a piece of electrical wire. Watertight, screw-on design is made from a high-impact plastic material and adds no resistance (0 ohms) to the circuit. Very handy and practical solution!
HCP2789 In-Line Plug Wire Splice, fits up to 8mm plug wire. Each:
$ 6.00
HCP2789SET4 In-Line Plug Wire Splice, fits up to 8mm plug wire, set of 4:
$ 20.00
_________________
Back to top
RickCoMatic
Moderator
PostPosted: Sun Jun 29, 2008 10:11 pm    Post subject: Re: Need coils Reply with quote
Not all that bad of a job.
Can be messy with plastic shavings all over the place.
Last time I did it, I used my ShopVac hose kept close to the Dremel cutting bit and just vacuumed-up the flying plastic.
Got most of it.
You grind-away the Coil Case on a straight line following the Wire.
Eventually, you see the wire.
Use the bit and expose the wire.
Cut it back to where the wire ends.
Then, relieve the space surrounding the wire.
Once enough of the wire is exposed ... you can twist the wire and break it loose.
The wire pulls-off a pin that looks like a nail head which is the High Power Supply.
Wipe down the new wire with some ArmorAll and it will be easily pushed-in through the undisturbed opening at the front of the Case.
I stripped the wire and soldered the connection.
Stock is just a Press-on fit.
I filled the cavity with 5-Minute Epoxy after the connection was made.
A little Dremel Sanding Disc to shape the cured Epoxy.
A little hand sanding-down.
Rattle can touch-up and your are good-to-go!
_________________
Rick Massey
Back to top
Robert
Moderator
PostPosted: Mon Jun 30, 2008 8:17 am    Post subject: Re: Need coils Reply with quote
^^^^This is all provided the primary windings check out good. If one of them is burned out, the coil is junk. Be advised, in the 5 sets I have tested only one of them had this condition, the rest had high resistance readings on the secondary lines. For $12 in spark plug wire, I fixed 4 1/2 sets of coils in the manner Rick described. Good luck and test those coils before you condem or repair them.
_________________
Robert
'81 XJ750RH Seca (ditto)
Past glory includes:
'86 XVZ1300 Venture Royal
'86 XT125
'84 GPz750A1 Ninja
'83 VF750F Interceptor
Back to top
blackflagmn
Gear grinder
PostPosted: Mon Jun 30, 2008 9:24 am    Post subject: Re: Need coils Reply with quote
I may have to do this with at least one of my coils eventually, any chances someone can provide some pictures next time you end up doing this procedure? I'm a visual person, so reading the description just isn't as helpful as seeing a picture. Thanks!
Back to top
Robert
Moderator
PostPosted: Tue Jul 01, 2008 8:26 am    Post subject: Re: Need coils Reply with quote
Check out Rick's post, he has some good photos and you can find more in our How-To/Self-Help link section.
_________________
Robert
'86 XT125
'84 GPz750A1 Ninja
Back to top
blackflagmn
Gear grinder
PostPosted: Tue Jul 01, 2008 10:01 am    Post subject: Re: Need coils Reply with quote
After 15 minutes of searching I still can't find pics of this procedure anywhere, they're not in Ricks gallery, and I can't find any how to's for this topic. Can someone provide me a link to where this coil procedure is documented with pictures please?
Back to top
RickCoMatic
Moderator
PostPosted: Tue Jul 01, 2008 10:10 am    Post subject: Re: Need coils Reply with quote
I'll try to put-up another picture this evening.
I have to wait 'til the car gets home and get my camera out of the trunk.
_________________
Rick Massey
Back to top
Robert
Moderator
PostPosted: Tue Jul 01, 2008 12:45 pm    Post subject: Re: Need coils Reply with quote
Look under the links section, DITY thread, bottom of the page.
_________________
Robert
'86 XT125
'84 GPz750A1 Ninja
Back to top
blackflagmn
Gear grinder
PostPosted: Tue Jul 01, 2008 2:28 pm    Post subject: Re: Need coils Reply with quote
Great, found the right section now, thanks! My bike has been running ok, but occasionally it seems like the #1 cylinder isn't firing as the exhaust doesn't warm up on that pipe, the shop I took it to a while ago said that they thought the coil for 1 and 3 was possibly going bad. I'm guessing it's just a small break in the wire that can be fixed with new wires. Now I'll be able to test and repair it myself. Nice writeup, and thanks for pointing me in the right direction.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
81 GS = 81 XJ ???
Last post by kirkn in Other Motorcycles on Jul 29, 2010 at 20:04:55
electrics
Last post by jt1200r in XJ Chat on Jul 29, 2010 at 19:53:26
Last post by FinnogAngela in XJ Chat on Jul 29, 2010 at 19:49:43
Fork Rebuild
Last post by venlis in XJ Chat on Jul 29, 2010 at 19:44:48
Dual Discs XJ750 Seca
Last post by Zookie400 in XJ Chat on Jul 29, 2010 at 19:43:17
Stator rectifer questions
Last post by dwmauney in XJ Chat on Jul 29, 2010 at 19:39:30
it's tire time..
