Suddenly I have running issues
Discussion in 'XJ Technical Chat' started by SnoSheriff, Jul 17, 2006.
  1. SnoSheriff
    MB, CAN
    On Friday on the way home I stop and fill up my bike. When I got home I parked it and it wasn't used all weekend.
    This morning I go to start the bike and all of a sudden it’s having starting issues. Eventually got it started with the full choke (as always) while cranking and giving full throttle. I could smell the fuel. Rich, flooding? Once it started, it wouldn’t idle and it felt like it wasn’t running on all 4 cylinders. I had to play with the throttle to warm it up.
    Once I started riding, it didn’t feel right and I didn’t have the power band I usually have. So, after about a mile I turned around and the beast would not go. RPMs would not rise and eventually it died. Again after some cranking and full throttle it eventually started and I managed to limp it back home.
    Test plan:
    1. Check and replace the spark plugs. They are old and could use replacing.
    2. Check the compression. I know my brother in-law had similar issue with this 2 stroke Titan and his piston had a hole in it. It’s a simple test so why not do it.
    3. Install clear inline filter before the petcock. This way I’ll see if fuel is flowing.
    I think I have petcock issues so it may be flooding it. I believe I've been running it on “Prime”. I’ll take a picture and post it here to verify. Any other suggestions?
  2. woot
    woot Active Member
    Flooding on prime could be a stuck float too...
    I'd drain the float bowls as well - into a clear/clean container - let it sit so the water has time to seperate... be interesting to see if you just got unlucky and had a bit of crap go through.
  3. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    When I 1st got my bike, I had to build the carbs (also replaced the needle and seatsand foat bowl gaskets)
    I couldn't get gas to the carbs and found out about the PRIME position on the petcock. (that got me plenty of gas thru the filter) 8O
    Well that bike ran pretty good but I left it in prime, and 2 days later when I got home from work there was a big puddle of gas under my bike (couple of gals. = about $6.00-$7.00 worth of gas just going to waste in the oil and on the ground.) :evil:
    I spoke to a friend who knows Yamahas and he told me that the needle and seats on these bikes were never meant to hold the head pressure of the gas in the tank and that PRIME as we now know was only for filling the float bowls.
    I would suspect that you have areally flooded engine, probably the oil too, did it ruin the needle valve rubbers? You'll have to pull it apart to find that out. :(
    After going thru my carbs for about the 3rd time I ended up with #3 cylinder really rich I could pull the plug and see gas mist coming out the plug hole.
    The way I knew which cylinders were giving me trouble was 1) start the engine and while it was idiling quickly touching the exhaust pipes at the heads to see that they were all evenly heating.... when the other 3 were so hot that I didn't dare touch them I noticed that #3 was only a little warm.
    2) I then did the color tune test and found that #3 only had spark and that the plug was soaked when I pulled it. :cry:
    I found that I had at least 1 malfunctioning needle and seat assy. possibly 2
    what a pain in the..... :oops:
    That petcock is really necessary, it's the only sure way to shut off the gas to your carbs. If you need a kit I'll send you the website for one but you probably know where to get it already.
    Good luck
  4. Hvnbnd
    St. Johns, Arizona
    I should have mentioned that if you tap on your float bowls sometimes you can free up a float that is stuck open!??
    I also suggest that you check your oil for gas contamination as it seems that that is the 1st place the gas will go when a float is stuck open.
    (usually a float that is stuck is because of a particle between the needle and seat but it can be because of mechanical problems too)
  5. SnoSheriff
    MB, CAN
    This spring I used Seafoam in my bike so I’m thinking the bowls were clean as the bike performed very well until now. After work I’m picking up new set of spark plugs. The XJ manual calls for BPR7ES (NGK) so that’s what I’ll get. My drain screws are toast on the carb bowls so I can’t drain the carbs that easily. I guess I’ll have to remove the bowls to do that. So far I had no need to get into the carb work on my Maxim so this will be my first time. Here are some questions before I get started:
    1. What kind of gasket is there on the bowls? Is it just paper gaskets?
    2. What’s an easy test for flooded engine? Soaked plugs?
    3. If my float(s) are stuck open: Will the fuel flow into the crank case and will I be able to see it in through the oil glass window?
    4. How do I check for oil contamination?
    5. Tapping/hitting question. What do I use to ‘tap/hit’ the carb bowls? Hit a socket extension against carb bowl or something?
    6. Cylinder numbers: What is the cylinders numbering sequence? Left (kick stand side) to right (battery side), 1 through 4?
    I was going to check our Links vendors for that. Which vendor did you get them from?
  6. Hvnbnd
    St. Johns, Arizona
    The float bowl gasket is a brown medium paper (you should be able to make the gasket but I bought mine with the new needle and seats)
    Soaked plugs or black soot on plugs are fairly reliable indicators.
    The fuel will go into the engine and to check you can simply pull the filler cap off and smell in the hole to see if you smell gas in the oil, if you get gas in the oil it will simply look like you have plenty of oil in the sight glass but really it will be overfilled and the gas breaks down the oil.
    I tap with the handle of a 3/8" drive ratchet or extension (for #2 & #3) but be careful not to break anything because it is soft metal.
    Cylinders are 1 thru 4 left side (sitting on bike) to right
    http://cgi.ebay.com/ebaymotors/ws/eBayI ... 4649437543
    link to petcock kit $23.50
    http://cgi.ebay.com/ebaymotors/YAMAHA-X ... dZViewItem
    link to needle & seat valves under $40 he can also sell you the gaskets, even though he's in New Zeland he got it to me in 3 days!!!!
    Hope that helps. Good Luck.
  7. SnoSheriff
    MB, CAN
    Ok, after some testing tonight here are the results.
    1. Oil scent test – I removed the oil cap and the oil has a strong fuel scent. Oil level glass shows full past the top of the glass (more then it should as I didn’t overfill) so I’m guessing the fuel leaked into the crank case.
    2. I replaced the spark plugs. How do they look in these pictures?
    3. Compression tests seem fine: cylinder #1 = 125 PSI, cylinder #2 = 130 PSI, cylinder #3 = 125 PSI, cylinder #4 = 125 PSI
    4. Petcock – See attached the picture. This is the position the bike has been running till this problem started. Is this set to ‘Prime’? After spark plug replacement the bike started fairly easy. As a test I switched the petcock to point from ‘prime’ to ‘on’ and the bike remained running in my garage. The pipe temp test using my hand showed that #1 cylinder pipe is not as hot as the other. It seemed to idle and it revved fine. So, I took it down the street for a spin. After about .5 mile it started sputtering and loosing power. While riding I flipped back to ‘prime’ and the bike came around and but again it started acting up. I limped it back home.
    So, I think I have a petcock issue here. What do you guys think? Other comments/suggestions?
  8. Robert
    Your compression is fine, your oil is shot, replace it. As for the petcock, yes, your in prime, turn it! Your sooty sparklers are a good question. I'm going to suggest they may be due, in part, to the prime setting issue. Check the new ones at the end of the week and see how things shape up.
  9. magolo
    magolo Member
    Portugal
    Its my opinion but i wouldnt run the bike with the oil as it is. The engine may get more hot than normal and that oil/fuel misture may ruin some rubber seals.
    I think
  10. SnoSheriff
    MB, CAN
    I only did the test drive using the oil/gas mixture. Oil change and more petcock testing to be done tonight.
  11. Hvnbnd
    St. Johns, Arizona
    The petcock was definatly set to prime. As everyone else said you need to set it to run.
    I am not sure what effect that might have had on the needle valves over a period of time?
    Your sparkplugs say that your running rich.. see the black sooty electrodes. It looks like they are all the same so this isnt just one carb...
    I'd definatly check the petcock youll need a couple of foot of fuel line and a small open top container.
    Tank on or off the bike, connect the fuel line to the petcock (in place of the regular fuel line)
    with the petcock in run there should be no leakage of fuel into the container,
    With the petcock in prime there should be free flow,
    if this is the condition then you should look to your vacuum line to check its integrity, was it connected correctly on both ends is the hose broken?
    If everything looks OK so far you need to try putting some vacuum on the vacuum line to see if the petcock opens in the run postion, if it does then it's ok, but does the fuel stop running when the vacuum is released?
    anyway you have probably figured out the rest...
    I suspect that your oil is so fuel contaminated that it is causing a rich condition when the engine gets hot as the gas vapors are cooking off of the oil in the crankcase and being vented into the airfilter and into the carbs in addition to the gas you are normally using thru the carbs.
    BE SURE to CHANGE THAT OIL, and the filter.
    Yes that oil will harm your engine, maybe not immediatly but your oil is not lubricating properly and an engine that revs like these do needs it's oil to be in good shape to protect your engine.
    So..,. change the oil and filter,
    change out those old plugs,
    and fix that petcock and dont run it in PRIME.
    If it still runs rich then the carb repairs begin....
    GOOD LUCK
  12. Hvnbnd
    St. Johns, Arizona
    You know Sno I didn't look to see but I'm not sure if you bike has a vacuum actuated petcock so if it doesn't then forget the trouble shooting like I described. You'll just have to operate it by hand to test!?
  13. Danilo
    Danilo Member
    Vancouver canada
    Petcocks often fail... especially on Decades old Motos :)
    Your Carb Float valves should be Neoprene tipped.. If not.. replace them with such.. The rubbery ones are a whole different quality than metal tipped things. IF your petcock is Vacuum type (it dosen't look like one) then A rebuild kit is available If ..manual You really must turn it on and off manually... every single time. a Nuisance but fool proof. prevention, besides that was the designed intent.
    Hopefully you haven't been running Premix in your crankcase for too long or your bearings would/could be wiped (seriously damaged).. Leading the pore old Moto directly to the Scrap yard.
    Just like people: when Aged, maintenance requirements double or triple.
    G'luck..
  14. Hvnbnd
    St. Johns, Arizona
    Hey Snow
    You will let us know what it was wont you?
    Hoping you do.
  15. SnoSheriff
    MB, CAN
    Oh, you'll hear back from me. I probably will have sometime tomorrow to do some testing. If needed I want to order the parts on Monday...
  16. SnoSheriff
    MB, CAN
    I think I got it fixed. My carbs are gravity fed with a vacuum line. I pulled the vacuum tube off the petcock and noticed that it’s sealed right near the petcock. That’s why I always had to run in “Pri’me. I put a clear vacuum tube on the petcock, I disconnected the fuel line from the petcock and hooked up a temporary line to do some tests. I used an empty beer bottle as my fuel drain container.
    In ‘Pri’me the fuel drained into the bottle as I suspected. In ‘Res’ and ‘On’ it was not draining. When I sucked on the vacuum line the fuel flowed when the petcock was in ‘Res’ and ‘On’ position. I replaced the old oil and the old oil filter. I went for a 6 mile test ride and the bike ran like a champ. I got to work this morning and again not a problem. Now, I’m riding it in ‘On’ position.
    I kept the clear vacuum line on the bike until I get a new fuel line. When riding I notice some very small amount of fuel in the vacuum line. Maybe that’s why the previous owner had a sealed vacuum hose on the bike? Why is there some fuel in the vacuum line and is this harmful to the bike?
  17. Hired_Goon
    Hired_Goon Member
    Oz
    I wouldn't worry too much about fuel in the vacuum line. It will just go into the inlet and get burned up. However if it is flowing down the line then the diaphragm may be split.
    The diaphragm can let a little fuel thru under vacuum thru a very tiny vent hole in the diaphragm that allows it to go back and forth.
  18. SnoSheriff
    MB, CAN
    My bike started to run a bit uneven and it feels like I have uneven pickup and loss of power in low RPMs. Cylinder #1 exhaust pipe is running a lot cooler then the rest. What may cause this? I have to pull the plugs to see their conditions. I’m wondering if the leaking fuel though my vacuum line has something to do with this? As a start I'm thinking on running some Seafoam through it.
  19. srinath
    srinath Member
    Charlotte NC by way of Bay area CA
    No that isn't quite right ... fuel into vacuum line will shut out that 1 cyl, unless you get the rpm's up ... where it will burn well and suddenly you have a 4 cyl ... or in the recent case where this happened ... a 2 cyl ... it was a GS500.
    Cool.
    Srinath.
  20. Hvnbnd
    St. Johns, Arizona
    Sno if your still leaking gas thru the vacuum line... I'd say you still have a petcock issue!? srinath seems to have something there. that could also run into your cylinders and thru the rings and into your oil.... here we go again.
