Forgive me I have Farkled...solved a problem too
Discussion in 'XJ Modifications' started by bigfitz52, Feb 13, 2009.
  1. bigfitz52
    The Problem: Really hard to dig my wristwatch out of the sleeve of my Tourmaster at freeway speed; and a 63 mile commute (kinda nice to know what time it is...)
    The Solution:
    Mounted it to a spare "dashboard" clip-on trim piece thing:
    And it clips right on. The beauty of it is I can switch it between my two Secas in seconds since it just snaps on.
    Formotion makes all sorts of cool stuff including $10,000 Matt Hotch wristwatches. The clock is one of their "stick on" series specifically for motorcycles, the larger sized ones. http://www.formotionproducts.com/ Really a high-quality product.
  2. xulf13
    xulf13 Member
    Franklinton, NC USA
    Hey, that looks really good in there bigfitz52. Hmmmm. I was in that same situation yesterday on I85. Made it to work 4 min late. Thanks for the tip.
  3. 600ccmicrob1
    600ccmicrob1 Member
    South Central PA
    cool, I might need to get one of those
  4. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    that, l like. wish my maxim had a lock on the ignition cylinder. just a kinda nice feature.
  5. xj650ss
    xj650ss Member
    Calgary, Alberta
    are you sure it doesn't my max doesn't say lock and sometimes it's a little stiff to lock but it is there, i find if i push the key down and let it go first it turns easier, just wondering
    Shaun
  6. wamaxim
    wamaxim Active Member
    Vancouver, USA
    BFitz, did you get the electroluminescent model? I work night shift and in the winter it's dark out both directions. If you have the e-luninescent model do you have to turn the backlight on or is it on all the time? I would like to have a thermometer too. Neat neat stuff.
    Wamaxim
  7. bill
    bill Active Member
    Raleigh, NC
    I have a $3 advance auto LCD. I tried it there Fitz and my house key got in the way. I stuck mine to the tach Does not cover it at all and it is easily viewed. I wish I could see it at night though. I'll try and get a pic
  8. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    The PO mounted one to the handlebars. It does come in handy to know what time it is while riding.
    Fitz, your clock looks great on key/ignition cover.
  9. alaskazzr
    alaskazzr Member
    Anchorage Alaska
    Very classy looking.
  10. bigfitz52
    I was REALLY impressed by the quality. I like how it very closely matches the instruments. Check out their website.
    I did change one thing: it came with a slighly undersized circle of double sided 3M FOAM as in 1/8" thick FOAM double-sided tape on the back. I replaced that with 3M automotive weatherstripping mounting tape (also foam, a lot thinner, and stickier) trimmed more closely to shape.
    (Plus I got a toolbox decal--I'm a "cheap date.")
  11. kd5uzz
    kd5uzz Member
    And just today I was thinking about the symbolism of not having a clock on a motorcycle...it is more about the ride then being stressed out about getting somewhere...
  12. wamaxim
    Vancouver, USA
    Not if you're late for work! Bfitz has the perfect setup. A clock for the commute days and with a simple twist of the wrist the clock is gone!
  13. flash1259
    flash1259 Member
    W.R. Wisconsin
    WOW bigfitz you really care about what time it is when you are riding? not me its ride until my azz gets sore.. lol
  14. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Cheaper than buying a 900 Seca.
