carb cleaning tool
Discussion in 'XJ Technical Chat' started by Polock, Apr 30, 2009.
  1. Polock
    just a little mod to the little red pipe from your carb cleaner
    no way i could explain this so we'll do some pictures, use a sharp knife
    if your lucky the point will fit the hole in the bottom of the float bowl tight enough not to leak at all, sometimes it will hold pressure in the little red tube
    watch out for blow back when you take it out
    now you've got some pressure to blow it clear and maybe not get carb cleaner in your face, don't look down the hole :eek:
    personally i use brake cleaner.....it's cheaper
  2. cole9900
    cole9900 Member
    North Texas
    That's pretty darn clever! Will have to remember that one.
  3. bill
    bill Active Member
    Raleigh, NC
    I missed this post - great trick. Thanks
  4. joshua
    joshua Member
    Lake Worth
    Wow great tool idea,thanks for the tip,literally........he he he
