XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: iamzeplin
New Today: 7
New Yesterday: 17
Overall: 7729
Members: 8
Visitors: 13
Total: 21
Who Is Where:
 Members:
01: brokenxj700 > Forums
02: dqnjuan > Forums
03: FinnogAngela > Forums
04: kirkn > Forums
05: Kylew11 > Forums
06: MojoJojo > Home
07: RefinedXJ > Forums
08: yeahyeah > Forums
 Visitors:
01: Forums
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
33580166
page views since
August 9, 2005
Forums › XJBikes Talk › XJ Chat › Cam chain adjustment
Go to page Previous  1, 2
Author Message
XJ1100
3rd gear
3rd gear
PostPosted: Wed Sep 06, 2006 1:04 pm    Post subject: Re: Cam chain adjustment Reply with quote
Well, I don't really like the idea of RTV on an adjustable part to keep it from leaking. I won't be able to adjust it the way it is and I'd have to keep gooping it up to keep it from leaking.
If I could find the whole adjuster assembly, I'd just swap the whole thing, adjust it, and be done with it.
Anyone know where parts like this can be found semi-easily?
Back to top
2fast
1st gear
1st gear
PostPosted: Wed Sep 06, 2006 8:37 pm    Post subject: Re: Cam chain adjustment Reply with quote
My 78 XS11 has some RTV on the end of the adjuster that has been there for many years to stop a slow seep. Works fine, don't worry about it.
BTW, good to see another MN member. I was just up there last week to run Hwy 1 from Ely to the north shore. Great ride. You might want to check out www.xs11.com/ for more info and some excellent tech advice.
Back to top
View user's profile
Hired_Goon
Red Liner
PostPosted: Wed Sep 06, 2006 10:40 pm    Post subject: Re: Cam chain adjustment Reply with quote
It's not threaded. It's just a little plastic plug that stops dirt getting into the plunger/shaft area. It just pushes in. If a new one is available the I wouldn't expect it to cost more than a buck.
If new is not available then I'm sure something could be found/made to replace it. Try a rubber place who have cap ends for tube type furniture. Around 15mm diameter I think.
_________________
1981 XJ550RH
1978 XS1100E
1978 XS1100F
1980 XS1100G
90 DR250
81 XL250S
2004 CTX200
Jet/Mod Calculator
Speed/Gear Calc
Back to top
View user's profile Visit poster's website
XJ1100
3rd gear
3rd gear
PostPosted: Thu Sep 07, 2006 8:00 am    Post subject: Re: Cam chain adjustment Reply with quote
Thanks for all the advice. I really need to adjust the cam chain, but I'm afraid to take off all the RTV and find out it leaks really bad.
I'm sure there's a better fix for the leak than filling it with RTV. If anyone has any parts laying around, I'd be interested. Drop me a line here or e-mail me.
2fast, I've done the Hwy 1 trip a few times. It's a great little ride on a nice day. I'm on XS11.com too, but they're geared more toward XS bikes. I like it here where people mainly deal in the XJ's.
Anyway, thanks again for all the replies. Much appreciated!
Back to top
Hired_Goon
Red Liner
PostPosted: Thu Sep 07, 2006 10:48 pm    Post subject: Re: Cam chain adjustment Reply with quote
You won't know what the problem is till you scrape that goop off. If the plastic cap is still undr there then it's an easy fix. Just knock it out and put a light coat of rtv in there before replacing the cap. Also check the rubber o-ring under the locknut. Apart from that the only other leak source is the face gasket.
If it was me I'd take it off and give it a good clean. One danger of cam chain tensioners is overtightening them and having the housing split. DAMHIKT. PO might have done this and put RTV over the crack. If this is the case then get a replacement pronto as the tensioner will be floating around, not locked in position.
_________________
1981 XJ550RH
1978 XS1100E
1978 XS1100F
1980 XS1100G
90 DR250
81 XL250S
2004 CTX200
Jet/Mod Calculator
Speed/Gear Calc
Back to top
vmaxdlx
Biker wannabe
PostPosted: Fri Sep 15, 2006 9:52 am    Post subject: Re: Cam chain adjustment Reply with quote
Does anyone know it the 85 XJ700 is a manual tentioner or automatic?
Back to top
View user's profile
MN-Maxims
XJ Wizard
PostPosted: Tue May 19, 2009 7:52 pm    Post subject: Re: Cam chain adjustment Reply with quote
I just found this thread and found it to be exactly what I needed to do to my #1 1100. The valve train was making some noise and I had just checked the valve clearance and it was still noisey. I did the adjustment and now no noise. It also seems to run better. Not sure if the chain is loose if it retards the valve timing. Just one more little thing done to make my bike run better.
Seems like there are a few who are asking about valve train noise these last few weeks. Maybe they should check there tentioners to see if their chains are loose and making that noise.
_________________
1981 XJ650H (Silver)
1982 XJ750J (Black)
1982 XJ750J (Red)
1982 XJ750J (Primer)
1982 XJ1100J (Black)
1983 XJ750K (Black)
1982 XJ1100J (Black & no second gear)
Current Project on the lift: 83 750 Maxim Air Box next. Black 1100 Second gear tranny problem
Back to top
ronha13
2nd gear
2nd gear
PostPosted: Tue Sep 29, 2009 5:42 am    Post subject: Re: Cam chain adjustment Reply with quote
BlueMaxim wrote:
Let it be known that we welcome idots who don't know how to use the search engine! So welcome aboard. However: I am the biggest idiot on the forum and donot wish for any competition Smile
In my previous post I stated that my search results said "Post Not Found"
Turns out I was clicking the wrong search button...
I humbly accept my spot in the idiot line!
Embarassed
_________________
1985 Yamaha Maxim XJ700 airhead.
18,500 miles when purchased last fall. (500.00)
Currently has 25,200 and climbing.
Modifications...
Windscreen. (po installed)
Highway bar footrest (po installed - I modified)
Luggage rack/backrest (got from Hunterhicks)
Future projects...
New paint job.
Engine guards. ~pm me if you have some~
Replace mirrors.
Replace mufflers. ~pm me if you have some~
Back to top
View user's profile Visit poster's website Yahoo Messenger Photo Gallery
olyamdp
Biker wannabe
PostPosted: Wed Nov 04, 2009 8:28 pm    Post subject: Re: Cam chain adjustment Reply with quote
Just picked up my new (old 1982) yam xj 650.
The rattle near the front of the engine makes me wonder about the tightness of the chain.
Is this a manual or hydraulic adjuster?
Thanks for any help.
olyamdp
Back to top
Display posts from previous:
Page 2 of 2
Jump to:
electrics
Last post by jt1200r in XJ Chat on Jul 29, 2010 at 19:53:26
Last post by FinnogAngela in XJ Chat on Jul 29, 2010 at 19:49:43
Fork Rebuild
Last post by venlis in XJ Chat on Jul 29, 2010 at 19:44:48
Dual Discs XJ750 Seca
Last post by Zookie400 in XJ Chat on Jul 29, 2010 at 19:43:17
Stator rectifer questions
Last post by dwmauney in XJ Chat on Jul 29, 2010 at 19:39:30
81 GS = 81 XJ ???
Last post by mlew in Other Motorcycles on Jul 29, 2010 at 19:34:08
it's tire time..
