gas tanks
Discussion in 'XJ Technical Chat' started by bobberaha, Aug 22, 2009.
  1. bobberaha
    bobberaha Member
    Kentland IN
    Can anyone tell me if a xj550 tank will fit a xj750 maxim.
  2. helmet
    helmet Member
    On 2 wheels... just lost my hat.
    what years?
  3. bobberaha
    bobberaha Member
    Kentland IN
    I'm sorry let me give you the full story. I bought an 82 xj 750 maxim that a guy tried to make a bobber out of. He took off the original tank and replaced it with a harley sportster tank. Needless to say I don't like the tank and would like to replace with something more original. The tank I found is off of a 82 xj550. Thanks
  4. helmet
    helmet Member
    should be the same. one of the guys with older XJ's can probably chime in to verify
  5. Deadulus
    Deadulus Member
    Dufur, Oregon
    I think it will, but I believe it is more like the size of the 650...which is one reason I got a 750 tank...larger capacity
  6. chacal
    550 tanks won't fit the 650/750 frames properly.............distance between the front and rear mounting points is different........
  7. bobberaha
    bobberaha Member
    Kentland IN
    Thanks for your help guys.
