FZ600 front on my Maxim
Discussion in 'XJ Modifications' started by Bane, Dec 3, 2009.
  1. Bane
    Bane Member
    Fargo, ND
    Here is the finished product of an '86 FZ 600 front end on my '82 Maxim. Dual front rotors and an improved dampening system in the forks. New front tire size is 16 inches. There has been no noticeable change in handling and I have rode ove 3,000 miles since installing. Including my trip through Bear Tooth Pass. There is virtually no fork dive, even in heavy braking with a passenger. I'm diggin' it and highly recommend such a switch.
  2. Bane
    Bane Member
    Fargo, ND
    It was a fairly straight forward switch. Also notice my new pegs...they are from a 2005 Suzuki Boulevard M109R. I had to drill out the pin holes about 1/16 of an inch but they look and feel great.
  3. Bane
    Bane Member
    Fargo, ND
    Here's the 3rd pic that didn't show.
  4. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    You cant see the front or the pegs...
    What new dampening system did you use
  5. dwcopple
    dwcopple Active Member
    bay city, michigan
    he already said, an FZ600 front end. its internal.
  6. Bane
    Bane Member
    Fargo, ND
    That is true, the dampening system is an internal valve that the Maxim forks did not have.
  7. poprider
    poprider Member
    Seattle, WA
    dirty little thing!
    Take a pressure washer to it!
  8. Bane
    Bane Member
    Fargo, ND
    She's dirty cause she's my daily. Didn't park it until December first. Snow and ice on the ground now.
  9. schooter
    wow that front rim actually kinda matches too, instead of 5x2 swirly spokes it has 3x2 spokes, which goes pretty good... where did you get the front end and how much
  10. poprider
    poprider Member
    Seattle, WA
    I rode my bike today with ice on the ground!
    :p
  11. Bane
    Bane Member
    Fargo, ND
    I actually got the front end set up from a friend who was gonna throw it out. I replaced the fork springs, seals, wheel bearings, and brake pads. I have seen them on Craig's list and such for as low as $75. it didn't come with a master cylinder so I used the master cylinder and line splitter from a 750 Maxim. Bolted right up. Yeah the rim matched pretty good. If it would have been really different I wouldn't have done it. I like function but I also like form. As far as riding with ice on the ground...Not really mty thing. I will ride in any temp but with onlt two wheels, ice becomes quite unfriendly. I have thought about it though.
  12. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Could you please put up a couple close up pics of those M109R foot pegs? Thanks.
  13. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Old post but curious, did you slide the fz forks right into the max trees or swap the whole tree from the fz?
  14. mechanicalmadness
    mechanicalmadness Member
    ^^^^^^ Kind of curious about that myself. Looks like hes running the stock tree but maybe some fit up details ;). Also Bane due to the mounting location of the front axle did you actually loose an inch from the overall wheel base?
  15. BillB
    BillB Active Member
    Tulsa Oklahoma
    i love the bigger front tire tough look
