my winter project 81 650 maxim
Discussion in 'XJ Modifications' started by iwingameover, Dec 7, 2009.
  1. iwingameover
    iwingameover Active Member
    I got a start on my project tonight. Been planning for a while. Thought I'd share here. Be patient on the updates. Cash is in short supply and I'll do things as possible.
    First, here's where I'm starting:
    Front
    Side
    Muffler was temporary after the other one fell off.
    My plans:
    Forward controls
    Fenders similar to the old indian style fenders. I've ordered trailer fenders to hack up for this.
    I've got a 750 tank for it.
    4-2 custom exhaust
    Tractor seat:
    I need to pick a paint color eventually and I'm really going back and forth on that. Leaning toward a gunmetal metallic as I like the steel/metal look.
    Anyway comments are welcome and maybe I'll inspire someone. I've gotten plenty of my inspiration off of this website.
  2. iwingameover
  3. iwingameover
    Quick update.
    Trailer fenders came in. I plan to split them down the middle, then use the radiused edges for the front and the sharper corners for the back.
    Side skirt blanks:
  4. 3784rider
    3784rider New Member
    New Zealand
    dude those seats are comfy,get it sand blast for the better paint finish.. :)
  5. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Is that a 4-1 exhaust, i see you want 4-2 if you are willing to sell I may be interested.
  6. iwingameover
    Street it is a 4-1. It's not in great shape and has a reducer welded to the collector. I can get you a better pic in the next couple days. I was planning to cut the head mating ends off the pipes and use those to fabricate my own from there back.
    Seat has been cleaned already. I used a wire wheel on it. Took some time but it's cleaned up and covered in WD-40 to keep it from turning back until I pick paint.
  7. vintagerice
    vintagerice Member
    New Hampshire
    Looks like you got a real nice bike to work with. Nice and clean and straight forward. Would love to hear about your progress with the forward controls when you get there.
    Test drove a Harley with them and really liked it.
    Rob
  8. iwingameover
    Yeah I rode her all summer. Just looking to make it look nicer, a bit different and more comfortable to me. I'm 6'4 so the standard controls are a little too close to the seat for longer rides.
  9. iwingameover
    Wanted to post an update...
    Not much to update I'm afraid. I took the stock foot controls, pegs, and peg brackets off. Almost have my forward control design ironed out. Then I'll get the pieces ordered for that. I'll post a CAD image tomorrow after it's done.
    Pegs, brackets, crash bars, etc are all for sale now.
  10. iwingameover
    Ok so here's some progress.
    Forward controls drawing almost complete
    I can share the CAD file if anyone is interested. Eventually I'll have a fully dimensioned plan with materials list.
    Rear fender starting to take shape. The right side had to be notched for the airbox.
    View from the rear. Fender fitted a little better. Tractor seat sitting on top.
  11. streetmaster
    streetmaster Member
    Nice project, but why such a wide seat? I guess its ok if thats what your into, myself for my 80 XJ650 project, im thinking about a much narrower seat. Must have somthing to do with function over form.
  12. iwingameover
    It fits my wide seat. I found the factory one uncomfortable on longer rides. Hopefully this will be better.
  13. schooter
    cool man! This is alot like a build I want to do sometime
    tractor seat, trailer fender, foward controls, and then 4-4 exhaust with like 4 8 inch stacks and rain stoppers on each one... then paint it john deere green
    Also, I dont know if its possible, but I think an exposed drive shaft would be awesome
  14. iwingameover
    Schooter sounds like you should just cut two wheels off a tractor.
    Don't think you could expose the driveshaft on these.
  15. Plumber
    Plumber Member
    Wales
    you really can
  16. Plumber
    Plumber Member
    Wales
    you'll have to cut down the seat though or you won't be able to put your feet down
  17. iwingameover
    I've given that some thought. I'm going to see how it works out when it's mounted. I'm pretty tall so maybe I'll be ok.
  18. Plumber
    Plumber Member
    Wales
    i have been there, tried and tested, there are two options
    1. Remove your thighs
    2. Cut down the seat
  19. streetbrawler750
    Minnesota
    Did you expose the driveshaft to put a fatter tire on the back, or looks?
  20. Plumber
    Plumber Member
    Wales
    I just don't see the point of going to all the effort of hartailing thn leaving in the swinging arm, and it means i'll be able to swap in virago wheels on the next build
