 Latest: njbobs
 New Today: 8
 New Yesterday: 17
 Overall: 7730
 Members: 8
 Visitors: 11
 Total: 19
Who Is Where: Members:01: dwmauney > Forums
02: eightyeinstein > Forums
03: kirkn > Forums
04: Kylew11 > Forums
05: Lou627 > My Private Messages
06: nickel98! > Forums
07: njbobs > Forums
08: ZaGhost > Forums
We have received 33581859page views since August 9, 2005
Forums › XJBikes Talk › XJ Modifications › Shorter center stand on a lower bike?
Shorter center stand on a lower bike?Custom mods for XJ Maxim/Seca...
kciv 1st gear
Posted: Mon Jan 25, 2010 7:33 am Post subject: Shorter center stand on a lower bike? |
I lowered my bike 3.5”. I am barely man enough to get it on the center stand. Anyone have pictures of a modified center stand? Looking at it, it appears that I can drill new attachment holes down a 1” or 2” and cut off the tops the same amount. Does this work?
TIMEtoRIDE XJ Wizard
Joined: Nov 05, 2007 Posts: 2298 Location: Clermont FL near Orlando
Posted: Mon Jan 25, 2010 10:31 am Post subject: Re: Shorter center stand on a lower bike? |
I wouldn't move the hinge area, I would remove the stand and shorten it, re-weld it. But for now, there is an easy way, get some 2X4 and 1X8 scraps and make 2 little ramps that are 3" high. Drive the bike onto the blocks and put the stand down. Add a convenient rope to the front block and snatch it out.
_________________ '83 Seca 900 - - '81 Seca 750 - - '88 Venture Royale - - '84 Venture Project
2006 FJR 1300
xjbikes.com/Forums/vie...ation.html |
kciv 1st gear
Posted: Sat Feb 06, 2010 6:16 pm Post subject: Re: Shorter center stand on a lower bike? |
I shortened the kick stand about 2" which was perfect for a 3 1/2" drop. I took the 2" out of the straight part nearest the pivot. I saved the clip and hooked the spring on the arm groove and on the lever arm. So much for the no-start with the kick stand down. I will look for a shorter spring and and try to re hook up. This will be the hard part (fitting the spring).
I shortened the center stand about 3" which was also just about right. rear wheel is about 2" off the ground. The center stand was easier to shorten than the kick stand.
1. Cut off the lever arm (where your foot steps down). Cut at the weld so that you can weld it back on later.
2. Cut off the feet leaving about 1/8" of tubing. Make this cut parallel to the ground.
3. Cut about 3" off the legs. Make this cut parallel to the cut at the feet.
Cut off a little more or a little less to prep for the feet.
4. Weld on the feet.
5. Weld on the lever arm.
6. Grind and paint to please.
7. Bolt it up and attach the original spring.
Posted: Sat Feb 06, 2010 7:03 pm Post subject: Re: Shorter center stand on a lower bike? |
You should post pics of your work, if you can.
2006 FJR 1300
skillet Red Liner
Posted: Sat Feb 06, 2010 10:56 pm Post subject: Re: Shorter center stand on a lower bike? |
Good post kciv  !!!
skillet
_________________ '81 XJ750 seca
We all come here naked, screaming and covered in blood. If you're careful....it doesn't have to end there!
You keep saying PSYCHO like it's a bad thing. |
