are these clutches comparable
Discussion in 'XJ Technical Chat' started by cromp, Mar 10, 2010.
  1. cromp
    cromp New Member
    Philadelphia, PA
    I have an 81 xj550 i need to replace the clutch, could i replace it using one off of an 1982 yamaha xj650 turbo seca or are they different
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    nope, completely different motors.
    for what it's worth, a new set of friction plates and springs is usually enough to r&r a clutch... neither is expensive or hard to get.
  3. bigfitz52
    The 550/600 clutch is a completely different animal than the bigger bikes.
    Better to simply replace the worn components than try to use a pre-owned unit.
  4. cromp
    cromp New Member
    Philadelphia, PA
    Ok thanks
