When braking....
Discussion in 'XJ Technical Chat' started by KrS14, Mar 10, 2010.
  1. KrS14
    KrS14 Active Member
    St Marys, Ontario
    When braking the bike almost dies out, but then recovers. Only happens when braking.
    Too rich?
    Plugs are a nice tan..... at 5 turns out lol
  2. KrS14
    KrS14 Active Member
    St Marys, Ontario
    wow 11 days and not one response....
  3. bigfitz52
    Float levels?
    Or is it electrical, as in brake light switch/wiring shorting?
  4. seaguy
    seaguy Member
    Coastal,AL
    I'm stumped
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Definitely not electrical, float levels are on the low side actually. Thanx for chiming in tho guys :)
    It doesn't just die like i hit the kill switch, the RPM's just go WAY down, enough that it will stop. If i goose the throttle it'll recover. Like it has to clear itself out.
  6. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    5 turns out is to much, that is the problem.
  7. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    Only time I've encountered something like that was on cold mornings running with the choke still on. So my guess would be running too rich, 5 turns? seems excessive,
  8. KrS14
    KrS14 Active Member
    St Marys, Ontario
    K awesome guys, i'll recheck and truple check my plug chops some more when it gets warm again, maybe i've got em a bit far out :)
  9. Thrasher
    Thrasher Member
    If you are doing a plug chop for the main jet, the air mixture screw does not come in to play. Only at idle.
