BROKEN THROTTLE CABLE
Discussion in 'XJ Technical Chat' started by photosbyjd2, Mar 11, 2010.
  1. photosbyjd2
    photosbyjd2 New Member
    GLENDALE,CA
  2. razz1969
    razz1969 Active Member
    Cleveland, Tx
  3. PainterD
    It would probably work if it has the correct ends on it and the length is compatible. I would assume most of the XJs use the same cable.
    Either chacal or over the counter at your local motorcycle shop; there must be at least one or two of those nearby based on your location.
