flushing fork tubes
Discussion in 'XJ Technical Chat' started by skillet, Mar 19, 2010.
  1. skillet
    skillet Active Member
    SW TN
    I was gonna change out oil seals in my forks. Thinking about using PB Blaster to flush them out. Any pros or cons to this idea???
    skillet
  2. BlackMax
    BlackMax Member
    Brampton Ontario
    I used brake cleaner,it evaporates fast and gets rid of the sludge in the bottom.I let mine soak for awhile(they were really bad)
  3. bigfitz52
    I vote Brake & Contact cleaner over PB Blaster. Blaster contains oil you don't want to leave behind to pollute the fork oil.
  4. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    +1 on the brake clean your going to replace all the rubbers in there anyway so there's nothing to damage.(some brake cleaners will eat rubber the good ones do atleast)
  5. Polock
    why don't you start out with kerosene till you get them clean then use your brake clean to rinse out the kerosene
    ya might save a few bucks
  6. skillet
    SW TN
    Thanks everyone!!!
    skillet
  7. Ross1bd
    Ross1bd Member
    Syracuse, NY
    skillet[/QUOTE]
    Resurrecting this thread. If kerosene will work, then is leftover Seafoam adequate? Plus, in terms of today's out-of-pocket dollars, free?
    Speaking of free, or at least cheap, (like the idiot I too frequently seem to be, with these machines), wanted to flush the forks on my recently acquired XJ900, while waiting for the caliper paint to get here.
    Took the rubber fork cap off and saw what I thought was a busted tube cap. While looking for a hex key tool I meandered over to XS11.com.
    Figured that no combination of cultures could figure out how to save some money while effectively solving a motorcycle than a bunch of Brits, some Scots and a few Yanks for good luck.
    Someone talked about buying his tool on Ebay, a couple discussed Motion-Pro's version (don't care for their valve tool, myself) and then one gentleman mentioned using a bolt head with a couple of nuts tightened together for the wrench to turn. They differed on the size needed, 15mm, 17 or 21.
    So, before going to the Despot, I took a picture with a tape measure across the gap and then used the always reliable tool. Put my finger into the space and used that to size bolts - 17mm.
    Cost of the bolt plus two nuts (didn't include the threadlocker, already had the tube, $2.41 including tax. Not as inexpensive as leftover Seafoam, but still pretty cheap.
  8. k-moe
    Seafoam is mainly Naptha, and will work fine to clean out the tubes.
