gas spewing outta the airbox
Discussion in 'XJ Technical Chat' started by katrina, Mar 22, 2010.
  1. katrina
    katrina New Member
    My friend has an 81 xj550 maxim...
    It is spewing gas outta the airbox, he cleaned the carbs, they look brand new inside. He can ride it and no gas but once he stops and it sits at an idol it starts.
    ANY IDEAS?
  2. Altus
    Altus Active Member
    London, Ontario
    You've got one of two options:
    1 - the tank is leaking at the very back making it look like it's coming from the airbox.... not tremendously likely
    2 - carbs aren't clean enough yet -- he's got a stuck float in one of the carbs, fuel backs up into the throats then backflows into the airbox.
  3. day7a1
    day7a1 Member
    San Diego, CA
    Altus, could this happen if the floats were set wrong?
  4. adrian1
    adrian1 Active Member
    Most definately! Also , If it leaks with the motor not running, the petcock will also need attention!
    Furthermore, its quite possible the oil is now diluted with petrol and should be changed before starting the bike again (after the above is sorted of course)
