Tyre Age
Discussion in 'XJ Technical Chat' started by cds1984, Apr 25, 2010.
  1. cds1984
    cds1984 Active Member
    Perth, Western Australia
    I felt a bit of rear slippage pulling out of some corners today on the first decent test ride since putting this bike together.
    I was hoping it was my paranoia but after looking at the rear tire (just hit 200 fresh kms since putting it back together on this existing tyre) I'm thinking it should go.
    The thing I was wondering was about the manufacture production batch stamp.
    Bridgestone say the last 4 numbers signify the weeks(2 digit) then the year(2 digit) and 6 years is getting old. I can't find whether Pirelli follow the same rule but if they do... does this mean this tyre is, how old?!
    Anyone know whether the production stamp coding is universal?
    At least I took the brake shoe advice and put new shoes in.
  2. mlew
    I can only see 3 digits in the pic 081, what is the last one? Most tires use the 4 digit where the first two are the week and the last two are the year, unless they were made before 2000 then there are 3 digits.
  3. MiCarl
    The U.S. Department Of Transportation (DOT) required beginning in 2000 any motor vehicle tire sold in the U.S. must have a standardized four digit date code. The first two digits signify the week of manufacture and the second the last two digits of the year.
    Before 2000 there was no standard and each manufacturer used their own proprietary codes (at least in the U.S.).
    Since that tire has a DOT compliance mark and a three digit date code it was manufactured prior to Jan. 1, 2000.
  4. streetmaster
    streetmaster Member
    I dont think i could bring myself to install or run a tire that was made before Y2k, shoot mine were made in 06 on the bike i just purchaced and dont even look as good as yours. Still working on mine though but i will have fresh meat on mine to start out with.
    Yeah a bike that is 30yrs old like my 80 XJ650 is getting a good check up before i hit the ground running. :idea:
  5. bigfitz52
    In answer to your original question, it's not QUITE as bad as you first thought; the little triangle after the 3-digit code indicates 1990's instead of 1980's, so it's a tire from the 08th week of 1991.
    The pre-2000 code was WWY (two digit week, then the year of the decade.) The triangle was added to differentiate between the 80s and 90s and then switched to four-digit date coding after 2000.
    Any tire with either NO date code or any three-digit date code is TOO OLD.
    Six years max.
  6. lopezfr2
    lopezfr2 Member
    Point Loma, San Diego, CA
    forget the date code, just look at the tire its thrashed. probably because you're using US only tires in australia...
  7. MiCarl
    You can use US tires in Australia, but you have to mount the tires with the arrow turning backwards. It's caused by the same phenomenon that makes the water in the toilet swirl the opposite direction. :D
  8. cds1984
    Great to know about the date codes, thanks and *Phew* I'm glad the tyre is only 18 years and 8 months old instead of 29 years and 4 months, I was starting to become concerned!
    and Yes we do ride our bikes facing backwards here :p
  9. TIMEtoRIDE
    If you think about it, the water swirls the same direction- - you're just looking at it from underneath !!
  10. cds1984
    Fixed!
    Metzler Lasertec 120/90-18
    New rubber looks good! and better when all that wax is gone.
  11. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    cds, good call! I am glad you got rid of the old tire. It's just not worth the risk
  12. kpcart
    kpcart New Member
    hi cds1984, i have recently bought and xj750p ex wa police bike, and i feel the slippage on rear tire like you noticed, and i think my tires are old, but still have a bit of grip on them. is it still safe to ride on a tire if it is 7 years old but has plenty of grip from not much usage? Also having never bought tires for a bike, can you recommend anywhere cheap in Perth? i live in Midland.
  13. mlew
    Looks much better, ride safe.
  14. bigfitz52
    It's not a good idea. These bike use tubeless tires, you're taking a chance on a blowout which will almost certainly destroy the rim at the very least if it doesn't wreck you.
  15. cds1984
    Hi Kpcart,
    One thing I came to realise after doing the tyres is that the slippage was caused by the swingarm bearings being totally shot.
    In essence the whole backend was moving about and it feels like the tyre is slipping instead.
    Put the bike on the centre stand and sit down on the floor behind the bike, then try to wiggle the wheel left and right or in a twisting motion... if it has play then you probably have the same problem.
    I'm just doing another 750P, with a 900 engine, and the swingarm bearings in that one were totally dry with one side rusted up and mangled (the bearing cage that is) so I think its a common fault at this age. It was a bit of a battle changing those ones I have to tell you.
    Swingarm bearings 2 x 30203 from BSC bearings
    Swingarm seals 2 x 25x40x7 from BSC bearings work but originals are 25x40x5 from Cullys Yamaha
    I bought my tyres from the Bike Doctor(Aka Bike tyre city) on Scarborough Beach road and I got a new front and rear fitted for $408.90... which hurt a bit but after the swingarm rebuild I feel fairly stuck to the road nowadays.
  16. darkfibre
    darkfibre Member
    Perth, Australia
    I replace mine that were 10 years old. Old tyres do go hard and provide less grip. Went to tyres for bikes in Vic Park $150 for the front $165 for the rear.
    Bridgestone BT45
  17. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    ...another thing with brand new tires is don't take any corners hard until you've got a few k's or miles on them.
    Buddy of mine had new tires put on his 78 Honda 750, brought the wheels home, bolted them on the bike, got to the end of his driveway, gassed it, spun out, wrecked the left side of the bike and was on crutches for three months. New tires are slick, so take it easy, scuff them with sand paper.
    He is an experienced rider, but got carried away (literally).
    A lot of people think that a new set of tires are safe, they're not until they are broken in.
  18. gennro
    gennro Member
    hhhhhhhhhhhhhhhhhhhh
    Good info there I have new D404s and was taking a corner on asphalt. My rear tire started to slide at 15mph with a little power on it.
    Also quick question I have some bridgestone tires that were made in 09 with lots of tread left. They have some small cracking like dry rot around where the tire meets the rim. Should this be safe or not? The tires are on a 1993 Honda 750 Nighthawk I bought a few days ago.
  19. bigfitz52
    You sure they were made in '09 (in which case they're barely two years old) and not 1999?
  20. gennro
    gennro Member
  21. Bushy
    Bushy Active Member
    cds'.. did you get this combo' .. i have them, found i can use up all th front and want a lil' bit more but not all th rear, what r your findings?
  22. cds1984
    Hi Bushy,
    same as mine... one thing i have found is that the ones i bought are both getting cracks on the side walls which is damn disappointing.
    I have my bike under cover but there is a bit of either morning or afternoon sun which hits the bike depending on where I park it... but still!
    I will be trying a different brand next time if i can find one to fit.
    Here is a picture of the same tyres in this thread that were replaced... not even 2 years ago.
    I sent an email to the supplier(bike tyre city) and received no response so I rang and was told that they were waiting to here from the distributor and not to hold my breath as it probably is environmental(ozone, UV etc), that was march 18th so... two months back and still no come back.
    Damn shame but after a bit of googling i see that it is a normal issue with Metzler tyres... even still I won't be buying them again if I can help it.
    Other than that... they stick to the ground great!
  23. Bushy
    Bushy Active Member
    No cracks in mine and they've been on about th same time as yours. I'm basically happy with them but will try a different front next time tho. No idea what at th moment.
  24. Maxim-X
    Just out of curiosity, do you put any type of tire dressing on the sidewalls to make them look shiny and new? From the pics it looks like there is some kind of application as they look "oily" instead of the plain old rubber sidewall. I've heard some things like that can promote rubber deterioration (sp)
    Just a guess.
  25. MN-Maxims
    Wow those tires are less than two years old. That would really upset me spending some hard earned cash and have that happen so soon. I hope the place you got those from will do something for you. If not put a post in the vendor review so no one else buys from them.
  26. cds1984
    I actually didn't put anything on them at all until the cracks appeared.
    So before the pics they looked nice and dry and non shiny, the cracks kinda looked worse so the armourall must have plumped up the rubber a little bit.
    So in short... apparently we have a big ass hole in the ozone layer over my house.... lol
    If you do a google search on "metzler cracks in sidewall" you will see what i mean about it being pretty damn common.
    I do run inner tubes and there is quite a few layers in the sidewalls but still... not nice I agree.
    PS: (I just sent another email to the supplier... i have the feeling I'll get blown off but you never know! *fingers crossed*)
  27. cds1984
    A follow-up on the Metzler cracked side-walls.
    Sent a reminder email to bike tyre city and they got back to me straight away. They asked me come down so they could do a tread depth measurement or measure the tread and let them know how much was left. So, just to keep it simple I went down for them to measure at the shop.
    After dealing with the distributor they were told that the tyres would be replaced so they popped on 2 new tyres for me Yesterday! so about 2 weeks went by from the second email.
    I wasn't expecting new tyres but I have to say you can't beat that sort of service at the end of the day.
    Now that I'm paranoid about rubber perishing I'll have to only ride at night and store the bike under a tarp in a cool, dark place!
  28. Maxim-X
    ...and don't forget to wrap them in "Glad Wrap", it'll keep 'em fresher, longer! :twisted: :twisted: :twisted:
  29. cds1984
    Bit of an update...
    Finally ran out of tread on the rear Metzler and switched to a Dunlop Arrowmax GT601 120/90 18 from Bike Tyre City a few weeks back.
    Front Metzler will be going for a couple more years at least by the looks of it.
    The bike actually felt a bit taller in the rear when I rode off, I guess it technically is but I didn't think I'd notice.
    So far I have to say I prefer it over the Metzler but that could just be that it looks like a chunky sexy new tyre too!
    Found this site also, which is pretty nifty.
    http://motorcycletirereviews.com/
    So I guess the Metzler lasted 4 years around the city. Not too shabby.
