? about the grade of gas to use in the 80 XJ650
Discussion in 'XJ Technical Chat' started by streetmaster, Jun 2, 2010.
  1. streetmaster
    streetmaster Member
    Just poken around with this and that, and came across the Vehicle Emissions Control info sticker inside one of the sidecovers for my bike.
    For gasoline grade it states that im to use Regular (Leaded) Research Octane 91 min.
    Since the only grade i can get thiese days is unleaded, am i to add additives to the gas each time i fuel the bike?
  2. MiCarl
    It'll be just fine with unleaded.
    If you're in North America you can run it on regular 87 octane. In North America we use Pump Octane Number (PON) as opposed to Research Octane Number (RON) which is used everywhere else and is referenced on your sticker. 91 RON ~ 86 PON.
  3. Vedalkin
    Vedalkin Member
    So, I've been going overboard by running 93 octane in mine since I got it?
  4. streetmaster
    streetmaster Member
    Ok cool, thanx
  5. BillB
    BillB Active Member
    Tulsa Oklahoma
    My 1982 Manual says to run 91%.
  6. RickCoMatic
    I think the correct answer is:
    "Depends upon where you live!"
    Here, in the Cradle of Liberty, New England ... The Regular Gasoline gets diluted with Ethanol. The sticker they put on the pump says: "9 to 12 Percent".
    I try not to run that stuff.
    I swear it makes my Bike knock.
    So, I pop for "The Good Stuff" , ... with the rationale a combination of Nike and L'Oreal.
    Just do it.
    Because I'm worth it.
  7. parts
    parts Member
    prescott valley az
    Mine doesn't like the 87. maybe it's just in my head :oops: , or the high
    altitude, or the 10% year round ethenol. I dont know, but I run
    91.
    And to make things worse-I could swear (and often do :wink: :lol: ), that I
    get better milage by at leased 5-10 miles per tank full from
    the higher priced fuel at texaco (chevron). And it seems to
    run just a tad smoother.
    Now that that price is going down I can return to "the good stuff".
    Now for those of you who will say "fuel is fuel", Thats only true
    of the gasoline componants. The better fuels have high quality
    detergents and other additives designed to eliminate the need to spend
    money on nicely bottled crap.
  8. snowwy66
    snowwy66 Member
    Salt Lake City, Utah
    you'll find just about every owner manual for every vehicle pretty much recommends 91 octance.
  9. racermazda
    racermazda New Member
    Spokane, Wa
    My bike runs best on 87. Unless you have pre-detonation your just spending more money. The bigger thing in my opinion is the quality of the gas supplier. Texaco/cheveron and shell (dont know about other major companies) run additives, but the worst time i had was when i got water in my gas from a mom and pop store with leaky tanks.
  10. shnuffy
    shnuffy Member
    Guelph, Ontario
    Let's just avoid BP.
  11. k.joel.porter
    k.joel.porter Member
    Wilmington, DE
    lol! what happens when you mix BP and Gulf, then? :lol:
  12. TIMEtoRIDE
    That's a crude joke - - :p
  13. k.joel.porter
    Wilmington, DE
    I know, too bad my sense of humor couldn't be more refined :wink:
  14. carbineken
    carbineken Member
    Wagoner, OK
    Mine doesn't seem to care too much about the octane level, but it does run better on non-ethanol gas, which is getting harder to come by around here.
  15. shnuffy
    shnuffy Member
    Guelph, Ontario
    May contain 10% seawater.
  16. jdoggsc
    jdoggsc Member
    Phoenix, AZ
    +1.
    Higher octane ratings are prescribed for sports cars that have much higher compression, or for cars with turbochargers. Octane just slows the combustion down a little so the gas doesn't prematurely ignite. If you run low-octane gas in a sports car, you'll get predetonation/spark knock and it'll kill your engine. If you don't have high compression, and you're not getting knock, then you're just wasting your money paying for more octane to slow down the detonation when you don't need to. you're just wasting your money and should just stick to the low-grade. It's not any dirtier, and the higher-grade isn't any good for giving your bike a special "treat" every now and then, like I used to think. it's just more expensive for you. within a few hundred feet of sea level, 87 octane is the minimum. here in the rocky mountains where i am (1 mile above sea level) the minimum octane is 85. the compression in these engines isn't high enough to warrant using mid-grade or high-grade gas.
  17. snowwy66
    snowwy66 Member
    looks like ethanol is making a comeback. although WHY is beyond me. 10 years ago we had one county running it in the winter as an experiment. they thought the air would be cleaner. but all it did was destroy the fuel system by eating away anything that was rubber. and worsened performance for anyone that used it.
    lots of people were doing some traveling to the next county to have the non stuff. LOL.
    i was a mechanic back then. just for curiosity i filled my tank and did an emissions test. needless to say the readings were much higher. almost to the point of fail. and the car really ran crappy.
    ethanol would also explain the expensive gasoline we buy. considering that the price of crude oil dropped 30 percent in the past month.
  18. MiCarl
    Think Green Lobby and Farm Lobby in cahoots.
  19. day7a1
    day7a1 Member
    San Diego, CA
    There's a NEW TYPE OF GASOLINE here in California.
    I accidentally put this stuff in my engine the other day. I'll see about the gas mileage, but so far it seems to start and run just fine. I just did a tune up, and it was running a little lopey with regular gas. Today it ran smooth as silk and started up pretty good too.
    Now, don't get me wrong, I'm not ready to attribute these good effects to this new gas formulation, but I'm willing to do some experiments!
  20. day7a1
    day7a1 Member
    San Diego, CA
    Oh, and you guys should really stop. Catastrophes and jokes mix together like oil and water.
  21. jdpesz
    jdpesz Member
    Stanwood, Wa
    Mine runs nicely on 89 octane.
  22. grit
    grit New Member
    Upstate NY
    Thanks for the info and clarification of what's described in the old manual.
    And very amusing BP snark repartee.
  23. cutlass79500
    lawrenceville georgia
    i aggree with most on here if your motorcycle runs good on 87 with no knocking thats what i would run. sometime you have to run higher. timing carbon buildup ect. i love it when you hear people say i put 100 octane and it runs so much better i guess its the smell of the race gas especially when it makes less power then pump gas
  24. Jotr
    Jotr Member
    Ottawa, ON, Canada
    i've only ever put 91+ in the bikes....figure the smaller engine would do better with it...but a few of the posts got me thinking. Perhaps will try a few tanks of 87 to see if there is any difference....but for $13 +/- CDN per fill up for 91+...assumed the additives @ some of the stations here would help clean out the old girl.
    On my trip from Ottawa to Parry Sound (976km round trip) was getting bout 5.6L/100km. Filled up with 265km on the trip and crammed 15L into it. Curious if the lower octane would see any delta to that.
  25. RickCoMatic
    I think it depends on where you live.
    If you live in New England in the Summer, ... they jerk-around the Mix of Regular and load it with all the Ethanol the Law permits.
    The discussion will break-down like this:
    Some guys will say only use Regular.
    Some guys will explain how gas gets rated.
    Some guys will say using anything other than Regular is a waste of money.
    My rationale is based on the illusion I'll go faster if I use high-test.
    And, ... every time I leave my driveway to go visit my sister I try to trim a little time off the trip.
    The tank only holds a few gallons.
  26. shnuffy
    shnuffy Member
    Guelph, Ontario
    I've been thinking about creating a "gasback." It's a lined backpack filled with a couple more gallons of gasoline and a hose to the carbs.
    Probably get another 100 miles out of it.
  27. snowwy66
    snowwy66 Member
    every now and then when gas gets expensive, the news does stories to help people save money. 87 and 91 have absolutely no benefits over running 85. unless you ghave a high compression engine.
    BUT. some california cars will flip the check engine light if you use lower then 91.
    as for regular gasoline. there no such thing anymore. least not in the sense that it once existed. unleaded is specially formulated to still have the lubrication qualities of the leaded additive that regular gasoline had. so it's safe for the older cars.
    WITHOUT the added benefit of lead causing carbon building resulting in lousy performance.
