For Sale XJ PARTS FOR SALE---FOR ALL MAXIM, SECA, AND TURBO MODELS
Discussion in 'For Sale, Trade/Swap, Wanted' started by chacal, Nov 10, 2006.
  1. chacal
    Al2023, ItsAMetric, Franz and 4 others like this.
  2. PainterD
    Re: MAXIM PARTS FOR SALE
    deleted
  3. chacal
    ...deleted to save space.
    Eric bernstein likes this.
  4. chacal
  5. kalani
    kalani New Member
    spokane, wa
    will the seca header pipes fit my 86 700 maxim? will it affect the center stand or the oil filter access? thanks,
    kalani
  6. chacal
    PainterD and Kalani----PM's waiting for you in your inbox!
  7. Cannonjr23
    Cannonjr23 Member
    peterborough ontario canada
    b3) Used YAMAHA side emblems available for XJ650 Maxim tank, both RH and LH sides, okay condition, original gold has worn off but has been re-painted with a flat, brushed gold paint (not shiny). $5/pair + shipping.
    very interested if they are still available!
    DoubleTigerLefty likes this.
  8. chacal
    Hi Cannonjr, I still have them, but I noticed that one of them has a crack all the way through the last "A" letter.....very noticable. Superglue may dimish it a bit. Let me know.
  9. Alive
    Alive Active Member
    Queensland, Australia
    Would you consider shipping the ignition and fuel cap to New Zealand? If so what would shipping cost?
  10. nnyxmfan
    nnyxmfan Member
    deleted
  11. chacal
    Alive and Nnyxmfan, you've both got mail!
  12. chacal
  13. chacal
  14. XJJeff
    XJJeff Member
    <a href="http://maps.google.com/maps?q=88.583765+4
    Hey chacal you by chance have a brake light switch that would fit my 80 maxim?
  15. chacal
    Hey Jeff, sorry no help on that piece. How did the tank turn out?
  16. XJJeff
    XJJeff Member
    I've posted pics in my gallery of it on the bike. Thanks again chacal. You da man.
  17. chacal
    Hi Jeff, thanks! I might have a starter switch if you find that yours is beyond repair........
  18. XJJeff
    XJJeff Member
    I did a crank case flush and and oil change this morning and cleaned the oil sender unit while it was empty of oil and thats what was keeping it from starting.
  19. chacal
    Good job. I just got my spin-on oil filter adapter plate and will be installing it next week, it's nice!
  20. chacal
    deleted to save sapce....see new list below!
  21. 7-13
    7-13 Member
    New Hampshire USA
    Asking for a friend, he's looking for the side emblems for an 82 XJ650. He need the ones that are on the side covers..... both sides if possible.
  22. Cannonjr23
    Cannonjr23 Member
    interested in c and possibly d as long as they would fit a 550, dont imagine they would be difrent? unless i am mistaken?
    where abouts are you located so i can estimate shipping
  23. chacal
    Hey Cannonjr, I don't know whether they'll fit a 550, the XJCD says they are different part numbers, but as to whether they'll interchange or not, you'll have to ask around and see if anyone else has tried this......
  24. Cannonjr23
    Cannonjr23 Member
    thanks Chacal! i will look into it!
  25. lasaber
    lasaber New Member
    Spring Hill Florida
    looking for exhaust 1982 750 maxim
  26. chacal
    Sorry guys, no help on a 550 or 750 exhaust!
  27. cjm55
    cjm55 New Member
    PM sent
  28. Wags83750
    Wags83750 New Member
    Las Vegas
    I'm looking for the aluminum heat sink flange that holds the exhaust pipe to the head(and the 2 bolts). Steve ('83 750 Maxim)
  29. chacal
    Sorry wags, no help on the exhaust ring nut for your 750.
  30. chacal
    deleted to save space......see new list on 3-31-2007 post!
  31. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Chacal,
    i am looking for the exhaust crossover for a 4-2 exhaust for a 82' XJ650 Maxim. If you have one or can get one, how much for product and shipping to 08068? Thanks a bunch.
  32. chacal
    deleted to save space......see below.
  33. chacal
    deleted to save space! :D
  34. chacal
    New updated list below!
  35. 82XJ650RJ
    82XJ650RJ New Member
    San Diego, CA USA
    chacal,
    I have a 82 XJ650RJ.
    Do you have float needles for the Hitachi HSC32? price?
    Cheers!
    Paul
  36. cruzerjd
    cruzerjd Member
    Eugene, Oregon
    Chacal, I need a pair of Air mixture screws, as mine are stripped. I would also be interested in the air mixture tool so I don't foul up anything else. Please let me know if you can help, and prices too. I usually use Paypal. Jon (cruzerjd)
  37. chacal
    Hi guys, sorry for the delay in answering, was out of town for the holidays.
    Float Needles:
    a) HCP870 float Needle and needle Retaining Clip only:
    $ 7.00 each
    $ 26.00 set of 4
    b) HCP872 carb bottom end rebuild kit, contains the float Needle,
    needle Retaining Clip, needle Seat, and needle seat Washer:
    $ 9.00 each
    $ 35.00 set of 4
    c) HCP1 same set as above but also contains the bowl-to-carb body
    gasket and the idle mixture screw block-off cap:
    $ 17.00 each
    $ 65.00 set of 4
    Air Mixture Tool:
    v) Idle Mixture Screw Tool for proper removal/adjustment.....I've had this specially made so you won't be buggering up the head on these rather fragile screws. An exact-width blade is recessed up into a shrouded cover that sits down over the screw, completely and properly capturing the screw head slot....this design not only eliminates stripping out the idle mixture screw slot, but also allows for very fine adjustment of the screw when fine-tuning the carbs (when using a colortune plug, etc.). Knurled top handle provides for a positive grip and 1/4-turn increments are marked for a visual indication of turns. A very neat little tool and it'll last a lifetime or two.
    $ 12.95 + shipping.
    Air Mixture Screw:
    HCP17A hitachi HSC32 idle mixture screw (used, not stripped, good head slot) $ 12.00 each + shipping.
  38. chacal
    whoops, double post!
  39. chacal
    New updated lists below! :D
  40. PghXJ
    PghXJ Member
    Pittsburgh PA
    I would like an oil filter o-ring (the big one for the housing) and a carb cleaning tool set...man sized.
    PM me with details.
  41. chacal
  42. chacal
  43. PghXJ
    PghXJ Member
    Pittsburgh PA
    Thanks for the fast shipping!
    :D
  44. chacal
  45. PghXJ
    PghXJ Member
    Pittsburgh PA
    Not to be a total tard, but can you separate a list of what you have for Mikuni from what you have for Hitachi carbs? I am confused. I would like to see the Mikuni carb list as there may be things I would like to replace on my XJ550's carbs...such as the hardware that is stripped (drain screws, bowl screws, heat shield screws).
    Post it or PM me.
    Thanks...
  46. chacal
    Hey PGH.....well, right now I don't have much in the way of Mikuni specific items. Just what is listed, which is basically carb bowl gaskets, float needle repair kits, and sad to say....that's about it! Although I have a couple of used sets of Mikuni carbs around here, I just haven't had the time to sit down with them and figure out all the available and interchangable parts to them.
    So, parts for Mikuni carbs will come----eventually. If anyone that knows a bit about them and can give me some pointers on them (as far as interchangability between the various XJ models that used them) that would be a great help. I'm pretty sure that some of the hardware pieces (for example, carb hat screws, etc.) actually interchanges between Hitachi and Mikuni carbs---God knows that I've "eyeballed" them more times than I care to think about!----but until I actually put micrometer, caliper, thread gauge, and research book time to them, I'd rather not guess. I'm sure that you would prefer I not guess either!
    So to all you Mik guys out there, be aware that I'm thinking about you and feel your pain.......I'll get it done as soon as I can, thank for your patience and any help you can lend!
  47. jchimovitz
    jchimovitz New Member
    Oak Park, MI
    How can I order 4 HCP885 #40 PILOT FUEL JET?
  48. chacal
    Jchimovitz---you have a PM with all the info!
  49. chacal
  50. chacal
    Deleted to save space! Please see page 9 of this thread for all of the latest parts listings, thanks!
