leaking gas??
Discussion in 'Other Motorcycles' started by xj650ss, Jun 25, 2010.
  1. xj650ss
    xj650ss Member
    Calgary, Alberta
    I rode to work and back no problem today and parked my bike in the garage like I always do, four hours later my wife comes in and tells me that the garage smells like gas!! So I check it out and sure enough my bike is leaking gas but it's coming out of the carb on only the # 4 carb the highest one when the bike is on the side stand, and it's leaking through the air filter!? any idea's why this is suddenly a problem??
    Shaun
  2. wizard
    float needle sticking / not shutting off, remove & pollish seat, or better still replace.
  3. cutlass79500
    lawrenceville georgia
    or it has a peice of trash in it
  4. brcree
    brcree New Member
    Put a inline fuel filter in after carb needle seats are clean. I get mine from ebay for about 3 bucks. :wink:
  5. Polock
    the fuel petcok is leaking, the fuel should stop when the vacuum goes away
  6. cutlass79500
    even if the petcock works properly when there is something wrong with the needle and seat all the fuel in the line will drain thru the carb with the bad needle and seat
  7. Polock
    ALL the fuel in the line can't drain, maybe 1/2 of it if #4 is leaking
    the float bowl should hold that much
    if he pulls off the fuel line there should be no seepage at the valve
    and the oil shouldn't smell like gas
  8. cutlass79500
    all the fuel in the line higher then that needle will drain of coarse its not going to drain the other carbs. if the oil smells like gas would definately think there was a problem with the petcock also.but definately a problem with the needle and seat i would pull the plug on that cyl before trying to start and turn it over a few times to get the gas out of the cyl before it hydrolics. and keep the plug or anything that might spark away from that cyl while turning it over better safe then sorry
  9. xj650ss
    xj650ss Member
    Calgary, Alberta
    you were bang on polock the petcock would release the vacuum so the fuel kept running free problem solved after it filled my case with gas!! now an oil change and back on the road if it ever stops raining
    Shaun
