Cracked Frame
Discussion in 'XJ Technical Chat' started by ol_750, Jul 4, 2010.
  1. ol_750
    ol_750 Member
    Newcastle Australia
    Hi All
    Was wondering if anyone had come across crackes in their frame just behind the seat latches.? :?
    I have 3 XJs & 2 are cracked in the same area. :roll:
  2. Polock
    someone must have had a BIG lady on the back :)
  3. ol_750
    ol_750 Member
    Newcastle Australia
    :lol: :lol:
    Dont know about that .... but one of them had racks etc bolted on the back :roll:
  4. ol_750
    ol_750 Member
    Newcastle Australia
    8O
    Just had a good look at the third frame , it was buried in the back of the shed.
    I has been repaired in the same spot as the other 2 have cracked ... just behind the seat catches.
    :? :? So I have 3 cracked frames & no one else has ??? :oops: weird :roll:
  5. adrian1
    adrian1 Active Member
    this is quite common...2 outta my 3 had cracks there. Surprisingly enough many owners are unaware....the first giveaway is your rack movement. Check yours arter you've read this! :)
  6. ol_750
    ol_750 Member
    Newcastle Australia
    :mrgreen:
    I was begining to think I was a bit crazy
    I can see it's a fatigue crack but couldn't beleive noone else had come across it
    :D Thanks for confiming my sanity , Adrian1.
    What part of Oz are you from?
    Cheers Andrew
  7. ol_750
    ol_750 Member
    Newcastle Australia
    I have got some solid bar about 100mm (4inch) long turned down to fit inside the frame tube & will be getting the frames Tig welded & will probable get a strenghtening piece welde underneath as well.
  8. adrian1
    Canberra Mate! Max 9 degrees today and hail here earlier....
  9. ol_750
    ol_750 Member
    Newcastle Australia
    High teens here but very windy still got a good ride in though
    Cheers
  10. ol_750
    ol_750 Member
    Newcastle Australia
    Was cleaning up my 750RL frame & have found another crack in the frame in the triangle section of the frame just below the shocky mount.
    Must be time to get the crack testing spray out & go over the whole frame
    :roll:
  11. quikcobra
    quikcobra Member
    Orlando Fl.
    I'll go check mine next time im free during the day. Could end up pretty bad if not fixed. We had a similar issue with the 06 Gsx-R's (600-750's) the front of the frame was cracking at the weld, But it accually broke apart. So you can imagine if its not taken care of how bad it could get.
  12. wizard
    Not so bad if the crack is aft of the shock mount.
    Low 20s here, sweet as.....
  13. ol_750
    ol_750 Member
    Newcastle Australia
    Took some pics of what I found so far...
  14. waldo
    waldo Member
    San Jose, Ca. 95125
    Any idea on the miles on these bikes?
  15. TIMEtoRIDE
    Must be all those dirt roads ?? :p
  16. ol_750
    ol_750 Member
    Newcastle Australia
    8) Been chaseing lots of Roos & dingos , Its around 150,000km (90,000miles)
    I have broken a top shocky mount on this bike too... on a tar road too
    :lol:
  17. RickCoMatic
    The Frame on my 900 fatigue cracked at the upper weld where the Kick Stander was attached to the Frame.
    Required extensive repairs to reinforce that section of the frame.
