Can I fix my spark plug wire?
Discussion in 'XJ Technical Chat' started by chrispick, Jul 19, 2010.
  1. chrispick
    chrispick New Member
    Nothern Jersey
    How's it going guys..
    This is my first post to the site, and i just want to say how helpful everyone has been in the other topics which i have used to learn quite a bit about my bike. (1985 xj700)
    Anyway, I have severed my spark plug wire to cylinder 1. I was just wondering if anyone knew if i could fix it in some way or am i stuck with buying a new ignition assembly for my bike.
    Any information would be great.
    WHERE was it severed? If close enough to the end, it can be cut off and the end simply screwed back on.
    If not, it COULD be spliced and then heat-shrink wrapped as a temporary measure;
    Otherwise you do Dremel surgery on the coil or replace it (one coil=two cylinders.)
    The plug wires are molded into the coils.
  3. chrispick
    Nothern Jersey
    It is severed flush with the top of the plug cap. Is this close enough to cut and screw back in? if so could you elaborate on that a little bit more, i don't quite understand how that would work.
  4. RickCoMatic
    Investigate the NGK Spark Plug Wire Splice.
  5. bigfitz52
