no spark man no spark
Discussion in 'XJ Technical Chat' started by runnerboy, Jul 30, 2010.
  1. runnerboy
    runnerboy Member
    walnut creek, east bay, california
    hello fellas just got my self a project a week ago 80 650 maxim, pretty good for 150$ clean the carb this morning hooked up the car battery to the starter got pretty good compression, but the bike came with a dead battery and its dead as in just gone. no park when the starter is turning, what should i check next. PS: where is the oil filler bolt on this bike. [​IMG]
  2. runnerboy
    runnerboy Member
    oh yeah just wanna say im a total motorcycle newbie, so hope all you fellow xj veterans can help a brother out thanks.
  3. iwingameover
    iwingameover Active Member
    Got a manual?
    Got a multimeter?
    You're going to need both.
    You need to trace the ignition circuit and find out what's bad. I'd start with checking connections for corrosion since the headlight is missing.
    Your oil filter bolt is 12mm dead center in the front of the motor right above the 19mm drain plug.
  4. runnerboy
    runnerboy Member
    yeah i got a manual but no miltimeter
  5. runnerboy
    runnerboy Member
    you should be able to test sparks by just ground the spark to the block and check for spark when you turn the starter motor right?
  6. RickCoMatic
    You can leave the Plug in and just use another spare, loose Plug.
    Pull the Plug Cap.
    Put-in the Spare Plug.
    Ground it to the Head.
    Crank and look for Spark.
  7. Orange-n-Black
    Yes but it's a lot more fun using wet hands. LOL Welcome to the site!
  8. runnerboy
    runnerboy Member
    lol yeah i'll tell my brother to try that.
  9. iwingameover
    you can check for spark as Rick mentioned. If you have none a multimeter will really be needed to find out why.
    You can get a digital one at a harbor freight for $6 or an autoparts store for around $20.
  10. runnerboy
    runnerboy Member
    yeah just did what rick said all 4 sparkplugs no spark, they dont look too bad but they are pretty black, what would cause all spark to go out, wiring? distributor?
  11. bigfitz52
    -wiring (just going by the photo.)
    -fusebox
    -SAFETY circuit (safety relay, neutral switch, clutch switch, sidestand switch and sidestand relay if so equipped.)
    -weak battery
    The oil filler is on the top of the clutch housing on the RH side of the bike; there is an oil level window on the lower portion of the same cover.
    There is no distributor. Your bike has TCI ignition, and each coil fires two plugs.
  12. runnerboy
    runnerboy Member
    yeah i guess i should strip down all the wires to check if they are good, im going to get a multimeter to check if all the components are working if i find out how to do that first.
  13. runnerboy
    runnerboy Member
    Does the service manual tells you how to use the multimeter to check for faulty components?
  14. bigfitz52
    Yes. The factory book is better at it but the answer is yes.
  15. sledchuck
    sledchuck New Member
    finger lakes,ny
    hey, i have same prob everything checks out except secondary resisstence on both coils i have none. primary is 2.5 also the guy before me took fuse box out and hooked everything together,would that burn out tci or coils any sugg would be great thanks 81 550
  16. runnerboy
    runnerboy Member
    i will take some pictures tomorrow because i dont really know anything about motorcycle maybe you guys can see the problems better than i can
  17. RickCoMatic
    You have to check the Secondary Resistance at the End of the Spark Plug Wire ---> Without Plug Caps.
    Push the Probes up into the Spark Plug Wires.
  18. iwingameover
    Also if you add your location to your account details or just post where you are someone maybe close by to help you.
  19. runnerboy
    runnerboy Member
    thx done.
  20. runnerboy
    runnerboy Member
    is there any key items i should check i know i gotta ckeck the pick up coils but i dont think power is going through the coils what would cause that?
  21. RickCoMatic
    Go to:
    Square One.
    Meter or Test Light.
    +12V at Main & Ign Fuse ... Y/N
    No ... Test Batt and Fuse Panel
    Yes ... +12V at RED Wire to Ign Switch
    >> Open Headlight Bucket ... Disconnect Ign. Sw. Pigtail ... Test RED Wire on Harness for +12 V
    RED Wire +12V ... Y/N
    No ... Short between Fuse Panel and Pigtail
    Yes ... Jumper - Red & Brown & Blue Wire All-3 > Together.
    Listen & Feel for Relay to Close. Y/N
    Y ... Try to Start Bike
    N ... Bad Relay
    (Y -- Bike Starts = Bad Ign. Sw.)
    (N-- No Start = Ign Sw or Relay Bad <> Test Both.
    Y -- Relay Closes / No Start
    Test for +12V at Coils and Solenoid
  22. runnerboy
    runnerboy Member
    just tested the coils, the red and black for both coils read 2.5ohms and the spark plugs all read 11.5k ohms, does that seems all right? if so what other problem could cause no spark since the coils are working, maybe i should get a battery first.
  23. RickCoMatic
    Your Coils Spec-out correctly.
    Now, you need to find-out why they aren't firing.
    NO Spark usually points to an OPEN Relay or Switch with the Safety Circuitry.
    The Sidestand "sticks"
    The Clutch "jams"
    You can pull the Safety Relay and try it ...
    The Bike must be in Neutral to start.
  24. runnerboy
    runnerboy Member
    does the sidekick stand needs to be up in order for the bike to start? and where can i find the safety relay, and when you say "pull" you mean just remove it or just jump it with a wire.
  25. RickCoMatic
    I think its right behind the Turn Signal Canceling Unit.
    No jumpers.
    Just Unplug it and be in Neutral.
    Try it and see if it pops.
  26. skeeter
    skeeter Member
    Iron Mountain, MI
    i don't think your sidestand switch would be causing your problems. a faulty sidestand switch will cause the bike to die once you put it in gear.
    as long as you're in neutral, the sidestand switch plays no role.
    a search for "safety circuit bypass" might get you in the right direction . . .
    but before i start bypassing safety circuits, i'd check for a bad connection somewhere.
    i'd be highly suspect of the fuse panel as they're prone to going bad in these bikes.
    found a pretty thorough ignition troubleshooting guide here: ignition trouble shooting
  27. runnerboy
    runnerboy Member
    yeah going to wally world tomorrow to get a battery 35 bux!!!:) and gonna remove the safety relay just because i think its not going to help the bike anyway, will keep you guys updated, btw thank you all so much for help me
  28. RickCoMatic
    Don't remove the Safety Ralay.
    Seems like an innocent thing to do, ... right?
    You stall it ... you need to shift into NEUTRAL to restart it!
    Try doing that with some angry skinhead needing a fix, sweating the load, laying on the horn, cursing you over a PA System, late for his swearing-in, initiation and induction tattooing to the Underground Nazi Party,
  29. runnerboy
    runnerboy Member
    lol wow i dont really know how the safety relay works, so if u can explain it to me that be great.
  30. wizard
    That safety switch allows you to start the bike in gear by pulling the clutch lever.
  31. runnerboy
    runnerboy Member
    wow did not know that, this changes everything, keeping it
  32. runnerboy
    runnerboy Member
    due to lack of money and school starting the project is on hold for now, but i will try to work on it on the weekends as much as i can, one day this will be a kick ass bobber
