No front brake pressure after fluid flush.
Discussion in 'Hangout Lounge' started by BillB, Oct 22, 2010.
  1. BillB
    BillB Active Member
    Tulsa Oklahoma
    I flushed the brake fluid out ... Unplugged the intake hole on the master cylinder for obvious reasons ( dirty brake fluid ).
    NOW I can not get it pressure to build pressure.
    Sure I tried pumping it up and holding and releasing the caliper drain 5 times.
    I read on here to bungee chord the front brake handle over night and it'll fix it.
    Do I do that with the lid on or off?
    I'd sure like to ride it to poker tonight if anyone knows anything else.
  2. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Take the Caliper off.
    Pump up the brake until the caliper barely slides up on the rotor.
    Attach.
    Then try pulling the brake.
    Worked for me after I rebuilt my calipers
    -Chris
  3. BillB
    BillB Active Member
    Tulsa Oklahoma
    Im on it.
  4. BillB
    BillB Active Member
    Tulsa Oklahoma
    It worked SLkid. I assume I can just bleed em out and it'll stiffen up more.
  5. RickCoMatic
    Before you do anything ...
    Level the Brake Master
    Take-off the Cover
    Remove the Rubber Gasket and Diaphragm.
    Fill the Master Cylinder ... Half-full.
    Operate the Brake Lever and OBSERVE the Inside of the Reservoir.
    IF Brake Fluid --> "Fountains-Up" from the Cylinder Replenishment Orifice
    (A tiny Drilled Port into the Cylinder at the Bottom of the Reservoir)
    "Fountains-Up" ... like a miniature Old Faithful ... when you squeeze the Brake Lever ...
    STOP trying the Bleed the Brakes.
    You'll never get Hydraulic Pressure back.
    Your Master Cylinder NEEDS to be Rebuilt.
    The Hydraulic Seals are shot.
    Install a Rebuild Kit.
  6. SLKid
    SLKid Active Member
    Glad it worked. Stumped me for a while until i just.. tried it. Now she brakes fine, a little squeaking when Rotor is hot and brake is applied, so I think I might just sand the edges of the pads again
    Rebuild kits are fairly inexpensive. Couldnt hurt
    -Chris
  7. BillB
    BillB Active Member
    Tulsa Oklahoma
    It got me riding again and that is the whole idea.
    I bought this thing to RIDE when the weather is nice.
    I have all winter to rebuild portions of the bike that are not perfect.
  8. jdpesz
    jdpesz Member
    Stanwood, Wa
    If your bike still has the original rubber brake lines, you might want to consider adding steel braided brake lines to your winter replacement list. It made a big difference on mine. Chacal has them.
