 Latest: iamzeplin
 New Today: 7
 New Yesterday: 17
 Overall: 7729
 Members: 6
 Visitors: 24
 Total: 30
Who Is Where: Members:01: dwmauney > Forums
02: FinnogAngela > Forums
03: mlew > Forums
04: shnuffy > Forums
05: tibor > Forums
06: Zookie400 > Forums
03: Calendar
04: Home
13: Calendar
16: Calendar
17: My Account
18: Calendar
19: Forums
20: Home
21: Forums
22: Forums
23: Calendar
24: Calendar
We have received 33579147page views since August 9, 2005
Forums › XJBikes Talk › XJ FAQ Suggestions › Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey
Clean Your Own Carb's - The Whole 9 Yards - by: Rick MasseyFAQ technical writeup. Available to all for discussion
Go to page Previous 1, 2, 3, 4, 5, 6, 7 Next
Chuckster 1st gear
Joined: Feb 08, 2007 Posts: 12 Location: Atlanta, Georgia
Posted: Thu Feb 22, 2007 8:14 am Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
Rick, any advice to me on my first attempt. Should I do all the bottoms one at a time and then do the tops one at a time? Or should I do a bottom and then a top and repeat on down the line? Also, right to left first or left to right or it doesn't matter? Thanks for your insight (and instructions).
I picked up a set of $30 carb screws from Tim on this forum (thanks Tim); but I hate to have to buy a carb rebuild kit too. My goal on this deal was to buy this bike for $350 and get it running. I hope by just cleaning these carbs I can at least get it to run. I finally got the rack off last night after cursing the air filter boots for quite some time. I finally had to get a hair dryer to soften up the rubber boots so I could get the boots out.
My budget for my project is $500 and I will have close to that when I get a battery. The bike is pretty rough so I've pretty much stripped her down to her underwear. Lots of cosmetic work to do. But I enjoy tinkering so that's why I got it. I probably won't keep this one, but I've grown fond of it and will probably get another nicer example after I'm done with this one.
I have a 2001 Kawasaki Vulcan 1500 Classic that I ride most of the time. But there's nothing wrong with it! So I got this one to have something to work on. Bought a manual and I'm having fun. Thanks for your knowledge you've shared here.
RickCoMatic Moderator
Joined: Jun 23, 2006 Posts: 9662 Location: Massachusetts, Billerica
Posted: Thu Feb 22, 2007 1:35 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
Since most of the real "Tough" cleaning is going to happen on the LOWER ends of the Carbs ... go ahead and do all four of the Float Bowl Ends, first.
Just be sure to keep the parts of each one separate from the other. Don't rush. A real clean set of carbs is a joy to get back on the bike and tune-up nice.
_________________ Rick Massey
Moderator - Tech Writer
Use LOCATION Feature.
Fraps Red Liner
Joined: May 08, 2006 Posts: 706 Location: Kitchener, Ontario, Canada
Posted: Thu Mar 08, 2007 11:32 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
What do some of you use for cleaning carbs? Aside from actual disassembly of the carbs - screwdrivers, drill bits etc that has been covered all above, what do you use to clean them.
A big can of carb cleaner is a given.
Scotch brite pads? Diamond files? Old toothbrush? Hones?
I'm sure lots of you who have cleaned carbs have some dos and don'ts to share when it comes to cleaning agents and comsumables.
_________________ 82 XJ650RJ Seca ~23k kms - My daily rider
82 XJ650LJ Seca Turbo ~42k kms - My daily project |
Posted: Fri Mar 09, 2007 12:04 am Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
I heard a little birdy say, that he knew a guy, who had sticky fingers, the day he went-in to see the Dental Hygienist.
The nice, stainless steel, cleaning and scraping instruments, on the tray, disappeared when he went back to get his sunglasses.
Dremel wire wheel, steel wool, Exacto blades and Point ... If she ain't home ... I heard some guy uses the Pot Scrubbing setting on the dishwasher.
"Not me, though ... I wouldn't ever, honest honey, no ... I didn't, that's crazy!"
Fraps Red Liner
Posted: Fri Mar 09, 2007 9:11 am Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
Dental picks then. Usually available at your local surplus store. I worked as a Tool and Die apprentice many years ago - a lot of the guys I worked with would just ask their dentist for the old picks instead of having them throw them out. Apparently, many were happy to oblige.
Alive Red Liner
Joined: Dec 04, 2006 Posts: 925 Location: Auckland, NZ
Posted: Fri Mar 09, 2007 3:13 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Mas |
Hey Rick,
Why is is so important to put the same parts back in the carb they came out of?
I have to swap some bits around, what are the do's and don'ts for swapping parts in carbs?
Cheers
_________________ 1983 XJ900RK Fully Restored,
1981 XS1100 Midnight Special (slow restoration underway) |
Fraps Red Liner
Posted: Fri Mar 09, 2007 4:01 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
When you say "wire wheel" do you mean the little brass wire brushes you can get for a dremel? What do you use that for? Same question for the exacto knife blades?
Posted: Fri Mar 09, 2007 4:52 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
I've had emulsion tubes to clean ... worse than the one that was in that picture, the other day.
Chucked a wire wheel in the drill and put the drill in the vice and went to town on that puppy.
When you have to deal with gross neglect ... you need everything short of a Nuclear weapon.
losifer 2nd gear
Joined: Aug 16, 2006 Posts: 69 Location: Minneapolis, MN
Posted: Thu Mar 22, 2007 4:15 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Mas |
| RickCoMatic wrote: |
| but, I KNOW there's got to be a Carb Speciality Outlet ... I hope someone else chimes-in to tell you where to get jets. |
I'm a couple months late, but:
www.motorcyclecarbs.com -- I managed to find replacement pilot mixture screws (I've got a stuck and stripped one). Not everything is listed on the website, but they are friendly and respond to emails.
_________________ 1985 XJ700N Maxim, 16k miles |
Alive Red Liner
Posted: Mon Mar 26, 2007 4:00 am Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Mas |
You still looking for photo's Rick?
I now have a bit of a collection of both Hitachi and Mukuni pics.
Posted: Mon Mar 26, 2007 8:54 am Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
Yes ... we still need pictures. But, I haven't learned how to manage them on this new computer ... yet.
But, I'm glad you do have shots that will match text. That we do need.
Alive Red Liner
Alive Red Liner
yamahamaxim1982 2nd gear
Posted: Wed Apr 11, 2007 8:29 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
i got a 82 xj750 maxim and i want to soke the carbs is there ruber gaskets seals on the butter flys or is it safe to soke the carbs just take off the ruber parts i see and know about.do you thing soking is a must or spray carb cleaner is ok.thank you ivan.
Posted: Wed Apr 11, 2007 8:42 pm Post subject: Re: Clean Your Own Carb's - The Whole 9 Yards - by: Rick Massey |
Don't soak them until you have determined if the Cleaner will be harmful to Rubber Parts.
You'll have to get that information off the label of the Carb Cleaning Product.
