TOOLS NEEDED:
* time.
* patience.
* paper, pen, and a notebook.
* ZIP-LOCK BAGGIES OF VARIOUS SIZES.
* a clean, semi-uncluttered, well-lit and well-ventilated area to work in.
* a strong flashlight.
* a magnifying glass.
* a digital-cam would be a huge bonus.
* haynes or clymer workshop manual.
* yamaha service manual.
* xjbikes.com threads already bookmarked.
* paper towels and shop rags.
* access to ultrasonic cleaner.
* access to tumbler or glass-bead blaster.
* Flat & phillips head screwdrivers, various sizes. JIS phillips-drive screwdrivers should be used.
* wire tube brushes, various sizes, for cleaning internal passages.
* brass & steel wire toothbrushes, for cleaning the outside surfaces.
* mini, mini-plus, or man-sized passage cleaning wires set.
* Engraving pen or punch to mark carb bodies, bowls, throttle shafts, etc. Ink won't do, even "sharpie" style permanent ink markers, since carb dip and spray cleaners will
remove them.
* Hammer.
* METRIC open-end wrench and socket assortment
* pry bar or soft mallet.
* channel locks, vise grips, pliers---needlenose and otherwise.
* dental picks.
* mini drill bit for carb bowl starter jet cleaning.
* e-z outs and/or LH drill bits.
* small pencil torch or a heat gun.
* vise.
* drill & drill bits.
* float height ruler or gauge.
* fuel level sight tube.
* a 6" or 12" bubble level.
* a carb rack Alignment Plate, necessary as you re-assemble the individual
carbs together and tighten the upper and lower rack bar screws. The four
carbs must be placed on a perfectly flat surface as the screws are tightened or mis-alignment will occur, and life gets really un-fun if that occurs.........
* 100% silicone grease. Any petroleum-based grease will attack rubber.
* anti-seize fluid.
* semi-permanent (purple) thread locker fluid.
* brake or carb cleaner (and lots of it).
* carb dip or access to it.
* Fine sandpaper, automotive paint grade, 400-, 600-, 800-, 1000+ grit.
* restoration paints and coatings, if you are so inclined to do such detailing.
* synch sticks.
* YICS block-off tool, if your bike is has a YICS passage.
* YICS port passage cleaning tool, if your bike is has a YICS passage.
* gun brushes or similar.
* gun cleaner or similar.
* colortune plug.
PARTS NEEDED:
Carb rebuild:
* throttle shaft seals (if you split the
carbs from the rack).
* fuel supply tube o-rings (if you split the
* float needle seat rebuild kit (seat, needle, clip, seat washer).
* bowl gaskets.
* idle mixture washers & o-rings, screws if damaged.
* jets, if damaged or incorrectly sized.
* carb bowl fuel drain screws.
* new replacement carb hardware (screws, etc.)---now is the time to upgrade to stainless steel and/or allen-head fasteners if so desired!
www.xjbikes.com/Forums...14692.html
