HEAD PIPE GASKETS yes you have them and how to remove w/pics
Discussion in 'XJ DIY How-To Instructions' started by bigfitz52, Jan 9, 2011.
  1. bigfitz52
    Since I had my spare cylinder head up on the bench to do the thing about the valve shim tool, I figured I'd do a quick piece on something that gets asked quite often:
    HEAD PIPE- TO- HEAD EXHAUST GASKETS:
    They quite often get well-hammered in, to the point where it's hard to tell they even exist; these are pretty bad but I've seen worse:
    (pay no attention to all the wasps' nests in between the fins, they got cleaned out afterward.)
    I jam a pointed awl into them to break them free; you can use a small sharp cold chisel or even the tip of a box knife blade; just dig into the gasket not the head itself.
    Once you dig into and distort them, they pop right out:
    Then it's a matter of cleaning up the ports; I used a shop towel with Brake cleaner on it for these pics; these aren't carbs or brakes so surgically clean isn't necessary, you just need a good seat for the seals.
    Then fit your new seals, either OEM:
    Or aftermarket:
    I find that a small spot of anti-sieze compound will help to "stick" them in place until you can get the pipes mated up into position. Be sure to use anti-sieze on the pipe retaining studs as well, of course.
    HOLD the pipe snug against the head, trapping the seal in its proper position, while you snug up the nuts holding the collar.
    Tighten the head pipe nuts to the specified torque for your bike evenly, one side at a time, as you "squish" the new seals for the first time.
    NEXT TIME: Getting the blasted old seals out of the collector box or mufflers (and proper fittng of new seals.)
    As always; comments, corrections or suggestions are always welcome.
    Cheers--- Fitz
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I have 4 into 1 header pipes and had to double up on the gaskets to get a good seal. Just food for thought. Good work as always Fitz.
  3. BillB
    BillB Active Member
    Tulsa Oklahoma
    LIKE!!!!
    Thanks again Fitz.
  4. GFB85
    GFB85 New Member
    Kincardine, Ontario
    I just pulled my headers off last night, and theres an awful lot carbon build up. If I go and clean those, should I worry if any fall back inside? I was just going to arm myself with a shopvac and a scraper and tread carefully. Is it absolutely essential nothing gets back inside?
    G
  5. bigfitz52
    If you use a shop vac, nothing's going to get back inside; but if you're talking a couple of carbon crumbs, don't sweat it, they'll blow right out as soon as you fire it up.
  6. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    You wouldn't happen to be using the MAC 4-into-1 system would you? I'm afraid to try just the 1 set then have them squished down and need to put a second pair in. Or does that not matter?
  7. KA1J
    KA1J Member
    Groton, CT
    Thanks for another great tidbit!
  8. lostboy
    Yes it was an old set of Mac 4 into one. Even on my new set I doubled up on the gaskets.
  9. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Sigh... still waiting for the good old USPS to get my MAC into Canada...
    grrrr....
  10. HirsuitHeathen
    South Jersey
    Well I installed my MAC 4-into-1 and ended up only needing one gasket for each head pipe. Only got to here it run on 2 cylinders can't wait to get my new coil and really hear it.
  11. RickCoMatic
    sethoneal7 likes this.
  12. mtnbikecrazy55
    hey fitz, did you ever do a write up on the exhaust to muffler gaskets?
    Thanks!!
  13. bigfitz52
    In the works.
  14. oscarkilo
    oscarkilo Member
    Canada
    Sweet
  15. Finn
    Finn New Member
    Denmark
    Hi, great write-up, Fitz :)
    Got these aftermarket gaskets
    Is there a proper way to orient them (which side facing where) - or doesn´t it matter, as long as all four are installed the same way?
    Regards, Finn
  16. thumperstorm
    thumperstorm New Member
    Minnesota
    I need to get new exhaust gaskets since I need to remove my 4 into 1 exhaust to get to my oil filter. I'm confused about what gaskets I need. Some places say the gasket is a round copper ring and others, like bigfritz's picture, show them to be flat ones that seem to be made of gasket material. For a '82 750 Maxim.
  17. chacal
    OEM gaskets are copper, aftermarket are some type of high-temp synthetic material............
    thumperstorm likes this.
  18. thumperstorm
    Minnesota
    Thank you.
  19. Franz
    Franz Well-Known Member
    Scotland UK.
    Thank you Fritz. Some aftermarket copper seals off ebay have a fold if that is the right way to describe it. The side of the seal without the fold must go against the exhaust port otherwise the hot gasses can open the seal and cause a leak. What are the solutions if one of the exhaust studs break flush with the cylinder head?
  20. Franz
    Scotland UK.
    Will the original XJ 900f downpipes work with Jama silencers? My Jama headers are okay just now but I will need to replace them later.
  21. k-moe
    @Franz Both of your questions should go into a thread about YOUR machine please.
  22. Franz
    Scotland UK.
    Thanks k-moe how do I do that thanks.
  23. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Go to the Technical or Modifications section of the forum. Click the "Post New Thread" button. Come up with a clever title, perhaps including the type of xj, and describe your problem. Geniuses will be with you shortly...
  24. Franz
    Scotland UK.
    Thanks MattiThundrrr
  25. Furman
    Furman Member
    Windham, ME
    Did Fitz ever pen an article on removing old collector/crossover and muffler gaskets? I’m currently dealing with them on my ‘83 Maxim: going to try soaking them with Liquid Wrench overnight and then prying at them with a thin flathead or razor blades tomorrow. Anyone have any tips or tricks? Thank you!
  26. Timbox
    Wisconsin, Tomah
    That sounds like the right thing to do. If you have a pick tool with a bend in it to get behind the gasket that would help. If you have a heat gun that might help as well. I don't think I have had any that were ever that stuck. Did PO put RTV or something behind them?
  27. XJ550H
    XJ550H Well-Known Member
    I think he is talking about the collector and the joint gaskets for muffler to collector or head pipes to collector
  28. Timbox
    Wisconsin, Tomah
    XJ55H you are correct, I guess I missed that first time around I read it from the beginning too...
    Unless you have a good solvent for the old gaskets I would think a wire brush and then a dremel with a wire brush end would do it. Take a old knife and get rid of most of the gasket first and work from there. Years and years of grime...having them blasted would to it too, depending how stable the condition of the collector is.
  29. Furman
    Furman Member
    Windham, ME
    Thank you both: I ended up having pretty good luck using a pair of flathead screw drivers, a smaller one to start them a medium size one, as chisels to separate the old gaskets from the inside of the pipe. The key was to not destroy the gaskets in the process, because the more they deteriorate the more they become cruddy fibrous metal messes (I got better at it as I went).
    I did soak them in a penetrating fluid over night and then again in the morning before tackling it this afternoon. I can’t say for certain if it actually helped but I can’t imagine it hurt, either.
  30. jag3
    jag3 Member
    Daytona Beach, FL
    Which side of the aftermarket exhaust gasket goes towards the engine, Green or White? Gaskets purchased from Chacal, (xj4ever). Thanks. 20201012_224240.jpg
  31. k-moe
    It doesn't matter.
  32. jag3
    jag3 Member
    Daytona Beach, FL
    Thanks. Just wanted to be sure and didn't see an answer above.
  33. DaygloDavid
    DaygloDavid Active Member
    North Yorkshire (UK)
    Following a repair to one of the OEM header pipes on my 1980 XJ650 4K0 (UK), needed to replace all four cylinder head exhaust gaskets. The Yamaha OEM ones are £9.54 each, Wemoto do copper or aluminium fibre for £1.81 each. I chose to use the copper ones, worked a treat.
