CAN ANYONE MAKE THESE BIKES TAKE A CORNER?
Discussion in 'XJ Modifications' started by HeWentForItSir, Jan 19, 2011.
Will PODS make my bike handle better?
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
  1. HeWentForItSir
    HeWentForItSir New Member
    I apologize for yelling at you. This is a subject that has been on my mind since the first time I made that fateful lean in to a twisty bit. I know its an old bike, I know its a shaft drive but come on. Someone has to have attempted to make one of these things go round a turn with out it bucking and rocking foreword and back with a little wiggle just to upset your confidence.
    I have new rubber, changed the oil in the shocks, checked my tire pressure, rebuilt the bearings front and back, checked buchings. Im beginning to understand why i see so many Bobber projects on here. These bikes apparently cant go around a corner.
    Yet, I seem to still think otherwise...I like this bike a lot and would like to keep it, I just want to feel like I can actually avoid a car pulling out in front of me(my father went down and almost died on his '01 Electroglide a year ago because of this very thing). Does anyone have any suggestions to make this thing handle better?
    Its a 82 XJ750 Maxim with 19k on it.
    Yes, I am a cautious and smart rider, I don't feel bad for the kids that die while doing 100+mph wheelies in downtown traffic...
    Upgrade the front fork springs, it helps immensely. So will a set of modern, compression AND rebound damping-adjustable shocks to help limit the driveshaft "jacking."
  3. grinder
    grinder Member
    norfolk,uk
    i cant say for sure,coz ive never ridden 1 of them,but they r similar to my xj600.i dont think either of them will ever go round corners like they are on rails.it aint what they were designed to do.if u want a bike that handles like that,i fear u need to be looking at a newer sports bike.personally tho,i love the fact that mine bucks buckles and weaves round corners.if makes me feel faster.i have a honda 500 shadow aswell,i can get the exhausts down and to the point where it lifts the rear wheel which makes her slide.its all over the show,its fun,but most importantly,it makes me sooooo wide,even gsxrs darent pass till we hit a straight.i say get used to it moving about,it will improve you as a rider,and enjoy it!!!
  4. cutlass79500
    lawrenceville georgia
    like fitz said definitely change the springs and shocks. 28 years old 20k miles its time im sure the front springs are sacked out and the dampening on the rear is not there any more. Will help a lot Its never going to be a sport bike but it will be remarkably better
  5. Mikko
    Mikko Member
    Finland
    What springs and shocks would be recommended?
    Spring and shock recommendations would be different between an XJ550 and the 750 Maxim he's struggling with.
    I can't give any specific recommendations for the 750; I can for the 550s. Let's not hijack the guy's thread; getting a shaftie to handle is a whole different ballgame.
    If you want my recommendations (and what I personally used) for a 550R, then start a new thread and I'll jump in (once I get home and can look up your answers.)
  7. TIMEtoRIDE
    I'm pulling apart my Seca 750 front forks for a rebuild, was thinking of adding one inch spacers, adding a little thicker oil, and just a little more of it. These 3 changes should stiffen up the front end for basically free.
  8. wizard
    My 900 handles pretty well, just sometimes I get the feeling the front wheel is trying to skip out, (all new rubber)
  9. kevineleven
    kevineleven Member
    Columbus, Ohio
    Put pods on it.
  10. gary_emac
    gary_emac New Member
    Essex, England
    Never had any problems with my 93 xj900. Though I think stiffer front springs and some new rear shocks should help.
  11. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    First few times I rode mine after restoration I was blaming the rubber for what must have been slippage around tight corners but after new rubber I had the same problem.
    Turned out to be the swingarm bearings were shot, one area I neglected when restoring, and now with them done cornering is just brilliant... like a real motorbike even :)
    I'd rather be scraping the knees at low speed and hammering out than going fast in a straight line... I'm sure everyone feels the same and although I'm not really scraping the knees I still get a great buzz from the hammering out of the corner!
  12. bigfitz52
    It IS. The stock fork springs just plain suck, new or sagged. I took the 7100-mile springs out of my '83 (they measured at spec) and used them to replace the sagged-out (almost an inch short) springs in the '81 when I rebuilt the forks.
    Then I put a set of Progressive Suspension springs in the '83. (Stock specs.) Although the two bikes have different tires (Avons on the '83, Dunlops on the '81) the response I'm talking about is suspension, not tire related. Both bikes have relatively new Progressive Suspension 12-series shocks on the rear.
    I have the advantage of being able to ride the two bikes, back to back, through the same set of corners/bumps at the same speed and under the same conditions (same time of day, same weather, etc.)
    The front end on the '81 feels "uncertain" when you start to push it a bit in the corners; the '83 is on rails. The stock fork can do some interesting "stuttering" just prior to wheel lockup; the upgraded fork will just howl the tire. The Progressive-equipped fork is much better at "soaking up" minor irregularities in the road surface; they're still there but they don't get "transmitted" to nearly the same degree. Some bumps just seem to get the best of the stock Yamaha springs while the same bump, taken at the same speed, is handled quite capably by the upgraded fork. This is most noticeable if the bump is in the middle of a corner.
    I plan to put Progressive Suspension springs in the other bike yet this winter.
    Highly Recommended.
  13. wardlarson
    wardlarson Member
    Wenatchee, WA
    so would you say in general the 1983's front springs are much improved over say 81-82's (on 750 secas, specifically)?
  14. TIMEtoRIDE
    He's saying they were new, and new is better than 27 years old.
  15. wardlarson
    wardlarson Member
    Wenatchee, WA
    yeah but he said he threw the 83 springs in his 81 and they worked better, correct?
  16. theadbrewer
    theadbrewer Member
    Roseville MN
    Another problem with making these bikes handle is the black spaghetti like frame they are made of. I have rubbed foot pegs with mine but it was quite accidental and surprising.
  17. bigfitz52
    Better than the sagged out ones, but they still have all the shortcomings they originally had.
    My point was that the Progressive Suspension springs are superior to even "good" (as in not sagged out) stock springs.
  18. zap2504
    zap2504 Member
    Middletown, PA
    FWIW - the PS springs for the XJ 750 Maxim front fork are 11-1107 (Seca is 11-1101). I'd recommend going with heavy-duty springs if you (and your gear) weigh anywhere upward of 200# (or you ride 2-up). The 12-series PS shocks are 12-1201B with 03-1368 HD springs (same setup for Seca). [Or go with 412-4207 combo shocks/HD springs.]
  19. Kickaha
    New Zealand
    If you want to do it properly you need to measure your sag settings and spring the bike to suit your weight, any new spring will probably be better than an old one but one to suit your weight with the right sag will be better again
    In the front emulators will make a substantial improvement, putting preload spacers and heavy oil in is a band aid fix at best
    Very few bike actually have "spaghetti like" frames most have crapped out rooted suspension that makes it feel like that though
    I've seen "frame flex" fixed on three bikes by fitting new swingarm bushes and upgraded rear shocks
  20. venlis
    venlis Member
    Finland
    kevin you just made my morning! :D
  21. HeWentForItSir
    Wow. I must say. This was a very impressive, thorough and quick response on all your parts. Thank you for all being so receptive and understanding to my first post even though it was a bit of a rant! This really inspires me. It makes me feel all warm and tingly inside to know you all care so much about these bikes!
    I will def look in to a PS spring and change the oil to something thicker up front and replace the rear dampers. My entire riding career has been on 2 and 4 stroke dirt bikes flying through rough rocky terrain on the mtn behind my house in upstate NY, so i consider my bike control and seat-of-the-pants sensor to be in good order. I have adapted my riding style to this bike, i have found the smooth and delicate rhythm of this bike through the corners, i just dislike that i cant make a sudden maneuver with out an extensive setup(which you usually don't have an opp. for in the real world when that 90yo women pulls out infront of you)
    Im thinking that if i also change my riding position into something a bit lower and the bars a bit straighter, that it'll help substantially in quick maneuvers. Its just strange going to a shaft drive from a chain, that whole lift and drop thing being reversed is odd lol
    I assume PODS are related to the carbs? independent air filters? PVC intake?
  22. grinder
    grinder Member
    norfolk,uk
    o dear.here we go again. :lol:
  23. HeWentForItSir
    i searched and didnt find much explaining it but can tell this is some sort of debate
  24. HeWentForItSir
    So, not to open a can of worms....but i assume pods...would be a pvc pipe running to all 4 carb inlets that intakes air thru a single or set of small cone shaped air filters? i also can assume that the argument against them is the extensive carb tuning it takes to get an even and adequate mix to all 4 carbs?
    Wouldnt this net minimal gains without cams and some P&Ping? Ive learned from my VW crowd that have swapped individual carbs to their 4bangers that it is very hard to get them running correctly. Most use CV carbs over Mikuni and hitachi double carb sets.
    As a simple(not really) solution, has anyone tried reducing the size of the inlet pipes and then routing 4 EQUAL length pipes with a oval or square filter on both sides of the bike? thus reducing the air flow to allow for easier tuning and still allowing equal airflow between all carbs?
    personally, it seems like a "I wish it were faster" kinda thing...lol make the motor WANT more air before you force it to have more air...
  25. bigfitz52
    "Pods" are individual air filters, installed directly on the carbs.
    These bikes utilize CV carbs, which do not like an infinite, unrestricted air supply; they work best with a restricted "finite" amount of air.
    The debate is between those who feel that they can make a bike run just fine on pods, without modification; and those who, aware of the science behind it, and based on experience, say it ain't so.
    Just do a forum search on "pods" and read the debate, such that it is. There's a lot of "don't confuse me with the facts when I've already made up my mind" plus often extreme partisanship in regard to the issue. The answer is simple science.
    And you're absolutely right; it does no good to try to force more into a motor than it wants to pull (unless you're turbo or supercharging.)
  26. BillB
    BillB Active Member
    Tulsa Oklahoma
    hilarious... you are trying to insight a riot
  27. theadbrewer
    theadbrewer Member
    Roseville MN
    Pods? I thought this was about cornering not making your bike faster.
  28. bobberaha
    bobberaha Member
    Kentland IN
    Didn't you get the memo everything is about pods on this site.
  29. RoadRash
    RoadRash Member
    Attack Of The Pod People?
    :wink:
  30. cutlass79500
    whats a pod lol I thought it was a sack on a tree that holds seeds lol.
    Ok will the starter of this post change the title to will pods make my bike corner better
  31. theadbrewer
    theadbrewer Member
    Roseville MN
    Pod's do make your bike corner better by reducing weight and increasing HP to assist with tire slide when you really get into it.
  32. bigfitz52
    Don't overlook a good set of racing stripes and an "ACE Cafe" decal.
  33. HeWentForItSir
    Please vote...This is a pressing matter which needs to be addressed immediately.
  34. venlis
    venlis Member
    Finland
    they do, they make the bike suck more air in directly from the sides, thus smoothening the aerodynamics, balancing the bike and making it significantly more stable = better cornering.
    you might want to listen to fitz on this matter also..
    about the racing stripes i mean
  35. HeWentForItSir
    I shall be installing pods and racing stripes, maybe a bent plate too, helps the drag coefficient.
  36. day7a1
    day7a1 Member
    San Diego, CA
    Don't forget to take the baffles out, the extremely loud sound waves part the air in front of you, also reducing drag.
  37. theadbrewer
    theadbrewer Member
    Roseville MN
    A flux capacitor increases the efficiency of the pods ability to increase handling at 88 MPH by 1 gigiwatt.
  38. streetbrawler750
    streetbrawler750 Member
    Minnesota
    Yes indeed by my calculations, the airbox wieght equipt with filter is substantially more to that of the pods, thereby lowering center of gravity, hence forthly, better cornering. Thats why I went with pods.
  39. RoadRash
    RoadRash Member
    (sniff, sniff)........I smell sarcasm..........
  40. grinder
    grinder Member
    norfolk,uk
    i thought it was 1.21 gigawatts?...........or maybe its reduced to 1 gigawatt with pods???
  41. HeWentForItSir
    1 gigawatt, youre thinking of the Delorean....
  42. grinder
    grinder Member
    norfolk,uk
    bet it was running pods tho.......?
  43. theadbrewer
    theadbrewer Member
    Roseville MN
    Most definitely pods. My bike has made me see the future in a corner with pods, also the past when it wasn't as fast and cornered badly from extraneous weight from a plastic air box stifling air to the fuel driven motor.
  44. gennro
    gennro Member
    hhhhhhhhhhhhhhhhhhhh
  45. Alive
    Alive Active Member
    Queensland, Australia
    My 900 handles really well.. both of them have.
    In saying that I have fairly new progressive springs, use 20w fork oil and and a 1 inch preloader in the front forks and decent Koni rear shocks
  46. Polock
    Valentino Rossi
  47. Alive
    Alive Active Member
    Valentino rides an XJ?? Wow :lol:
  48. venlis
    venlis Member
    Finland
    xj with pods to be exact!
  49. amfmtxca
    amfmtxca Member
    God's Country Lubbock Texas
    not to stop the humor I did get a good laugh, does Chacal carry the progressive springs and shocks y'all been breifly talking about? Ilike all the free info and knowledge that is being shared and the humor it is top notch
  50. day7a1
    day7a1 Member
    San Diego, CA
    yes he does. the catalog is reached via the engine picture at the very top right corner of the page. Pg 4 of the catalog is the suspension, IIRC.
    I have the whole thing saved to my hard drive so I can read it offline.
