Beware of aging rubber grommets
Discussion in 'XJ Technical Chat' started by Forgiven, Mar 24, 2011.
  1. Forgiven
    Forgiven Member
    BC, Canada
    My MaximX needed repairs due mostly to the air grommets between the carbs and airbox. I had no idea they had shrunk so much! They had hardened considerably as well. Thus dirt was able to get in for years...causing a loss of compression..If you have an older bike watch for this.....Note the new grommets are on the left.
  2. andrewlong
    andrewlong Member
    Cumming, GA
    Whooee almost as bad as running without an air filter! Amazing seeing them side by side and how much of a difference new ones make.
  3. MiCarl
    Really sorry to hear about your engine damage.
    You've definitely done a service with that picture though. Anyone having trouble getting their carbs back in the bike can clearly see the problem.
  4. Xjmike
    Xjmike Member
    very nice! it's amazing seeing the old ones next the the "fresh" and fully functional new ones.
  5. BillB
    BillB Active Member
    Tulsa Oklahoma
    Time = Shrinkage : )
  6. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    I have the same problem when I swim in cold water!
  7. grunt007
    grunt007 Member
    Very good point. I just went through mine and after taking the carbs off I decided to do away with the airbox and went to pod filters on the carbs. This way I can pull the carbs off much easier. Not sure what problems this is going to cause yet but time will tell. As far as the rubbers you changed I haven't taken that step yet since they are pricey little buggers. Probably will have to change them eventually for sure. grunt007, 81XJ750R Seca, Mi.
  8. macros10
    macros10 Member
    Newport News, Virginia
    Forgiven, are those new ones the OEM replacements or the aftermarket ones? Just curious about what you think about whichever ones they are. Like grunt says, they are pricey, but the aftermarket ones not quite so much, so I'm wondering if they are worth it or if you get what you pay for.
  9. Forgiven
    Forgiven Member
    BC, Canada
    I got the OEM ones. Event though they went bad (in about 15 years), no way for me to know if aftermaket ones will be worse or not......
  10. macros10
    macros10 Member
    Can I assume that they were alot more pliable and flexible than the old ones you had on the bike? Just wondering since I'm having such a hard time working with mine when putting the carbs back on.
  11. Forgiven
    Forgiven Member
    BC, Canada
    Oh yes, the old ones got real hard. I certainly recommend you get new ones. Yours are no doubt becoming or now like my old ones in the picture. Had I know this is what was happening so many years ago I would not be rebuilding my motor now..I tried to force mine in place, but now see why they would not go on...Change them for new ones!
