St Louis 83 750 Maxim build
Discussion in 'XJ Modifications' started by DeMentedToys, Sep 8, 2011.
  1. DeMentedToys
    DeMentedToys Member
    Durango, CO
    About a month ago I picked up a sweet 1983 XJ750 Maxim. I rode it for about a month then just had back surgery so while I'm recovering I think I'll go ahead and start working on my bike. I was going to wait for winter, but since I can't ride for a while I need a project.
    Here's a picture. [​IMG]
  2. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I had no place to put stuff (no storage), so I made a MOLLE gas tank cover. I'm in the military so we use MOLLE to attach pouches and everything else to our body armor, backpacks, and whatever else. Why not use it on my motorcycle too? [​IMG]
  3. interstatejoe
    interstatejoe Member
    Huntington Beach, CA
    That's pretty slick. I'm going to have to track me down one but in black instead of digital camo.
  4. interstatejoe
  5. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I'll probably make another one in multicam, but the digital camo is all I had to work with at the time.
  6. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Put on TC Bros drag bars but the choke hits the tank when turning left. I ordered a 2" adjustable riser. As soon as it arrives I'll post more pictures.
  7. Ledicott96
    Ledicott96 Member
    North west England
    Be careful with the risers they tend to foul the ignition barrel.
    Nice bike.
    Al
  8. DeMentedToys
    DeMentedToys Member
    Durango, CO
    What the heck does that mean??
  9. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Here are the 2" risers I ordered.
  10. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I got the risers today and installed the drag bars. The risers are AWESOME. They allow me to move the bars forward or back and they solved the gas tank clearance issue. They also allow me to lower the triple tree another inch.
  11. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I was going to order a bobber solo seat but decided to make my own instead. I sat down and literally traced the outline of my butt. Haha. Used it to make the pattern, then traced it onto sheet metal. I also cut down the Harley seat that I had on it and I'll see which one works better.
    I also cut the foam down to fit.
  12. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Here it is so far. Need to finish making the seat, lower the front an inch, find a cool tail light, and get new handgrips. :)
  13. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I picked up a set of new 12" Harley scocks for $75. Just needed slight modification to make them fit. On the right side I had to fabricate a new lower mount. [​IMG]
  14. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I got more done on my project. I'm finishing up a spring solo seat too.
    Here are a set of Harley shocks I got for $50. They are adjustable for length. [​IMG]
  15. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Here are a few more pictures. Just need to mount the solo seat and it will be ready to ride for now. [​IMG]
  16. Hasersys
    Hasersys Member
    Sebastian and Tampa Florida / Chicago Il
    Omg, the Molle tank cover is sick! I wish I had one I love it. I want to do the same digi cammo you used, I think that looks sick! It would be nice to cut out the spot for the cap. I would hate to take the idea from you though man, it just looks so nice.
    Check out my bike
    http://s974.photobucket.com/albums/ae22 ... ?start=all
  17. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Building the spring seat mounts, mounting bracket, and mounting the rear fender.[​IMG]
    Solo spring seat mounted. [​IMG]
    Starting on the front. [​IMG]
    Putting fork boots and a headlight stone guard on. [​IMG]
  18. DeMentedToys
    DeMentedToys Member
    Durango, CO
    I got the machine gun grips on with much difficulty. These fit TIGHT!!
    Putting in a new heavy duty clutch and springs.
  19. DeMentedToys
    DeMentedToys Member
    Durango, CO
    Updated pics. Tail lights mounted.
  20. bobbytheblack
    bobbytheblack Member
    Seattle, WA
    DeMentedToys,
    Love the build, just had a few questions...
    How are the risers still working out for you? and can we get a before - after clearance pic? Also why did you pick the Dual Sport risers over the Cruiser risers?
    One more thing, I dont know what branch or if your active, reserve, or NG... So, not sure if you go on post, but if you do where are your decals located?
    I haven't put mine on yet, but my girl put hers on the forks and they lasted about a week before the forks rubbed and tore them off... So just wonder?
