XJBikes.com XJ4Ever
Toggle Content
Toggle Content Advertisement
Toggle Content Donate
Donate with PayPal!
Toggle Content Main Menu
Toggle Content User Info
Nickname
Password
Latest: iamzeplin
New Today: 7
New Yesterday: 17
Overall: 7729
Members: 14
Visitors: 18
Total: 32
Who Is Where:
 Members:
01: brokenxj700 > Forums
02: chacal > My Private Messages
03: FinnogAngela > Forums
04: jt1200r > Forums
05: lopezfr2 > Home
06: mlew > Forums
07: n7xme > Forums
08: Platkeyboy > Forums
09: RefinedXJ > Forums
10: schooter > Forums
11: shnuffy > Forums
12: tcoop > Forums
13: tibor > Forums
14: yeahyeah > Forums
 Visitors:
01: My Account
02: Home
11: News
13: Home
Staff Online:
No staff members are online!
Toggle Content Google Search
Toggle Content Total Hits
We have received
33579846
page views since
August 9, 2005
Forums › XJBikes Talk › XJ FAQ Suggestions › Tools
Tools
FAQ technical writeup. Available to all for discussion
Post new topic   Reply to topic   Printer Friendly Page    Forum Index XJ FAQ Suggestions
Author Message
KiwiXJ750D
Red Liner
PostPosted: Sat Apr 28, 2007 3:08 am    Post subject: Tools Reply with quote
One of the first things anyone working on a XJ (or any other bike) should get is a torque wrench. Not just any wrench will do; indeed you will need two wrenches if you need to open up the motor.
Half inch drive, foot pounds:
The first torque wrench is a general type, like you would use on a car. The half inch drive torque wrench is used on larger bolts. These wrenches are generally designed to be used in the 15 to 150 foot pound range.
Used on: axles, head studs, frame mounts etc.
Three eight drive, inch pounds:
This torque wrench is the one to invest in if you work on engine internals. The force required inside the motor is often far less than 15 foot pounds and settings for these parts are given very precisely in the manual. The range these wrenches are normally used on the XJ is from 30 to 180 inch pounds. The more accurate the wrench, the more they cost. Borrow a known good one if you cannot afford to buy one. Do not attempt to do any engine work if you do not have a good inch pound torque wrench.
Must be used on: any engine work!, oil filter cover, oil drain plug, clutch bolts.
Allen keys:
Buy good quality metric Allen keys. You need a size 4, 5 and 8 mm key. These can also be found in a three eight drive version for use with a torque wrench.
Used on: engine cases, valve cover, passenger foot rests, ignition rotor.
Socket set:
Half inch drive for the larger bolts and three eights for the smaller ones Smile .
Don't buy a cheap no name socket set. Just don't!
OK saying that you do not need to spend a fortune either. I have found Fuller to be inexpensive. The XJ uses metric fittings, thus you need metric sockets. Sockets are used with the torque wrench.
Used on: almost everything.
Ring (box)/open spanners:
Metric once again! Cheap ones work but good spanners are normally thiner making them easier to get on hard to reach bolts and a better fit on the bolt head. I double up on common sizes, can be handy and you need 2 x 12 mm open spanners for clutch cable adjustment. My spanners are a mix of different brands so I know at a glance which size they are Smile .
Used on: items like clutch and break pivot bolts, clutch cable adjustment, body work, anything a socket can not be used on.
Screw drivers:
Well fitting, no broken or worn tips. They are not a punch or a chisel and thus should never be used as such! You will need a number 2 and a number 3 Phillips tip. A rubbish or incorrect size Phillips screw driver will only "drill out" a Phillips head screw. Some grinding paste on the tip can help to stop it slipping. The screws on the crank end covers are number 3 Phillips.
Flat bladed screw drivers are used on the carburetors. Make sure they are a very good fit for mixture adjustment screws. For the jets inside the carburetors you are best to use cabinet makers flat blades. They do not taper out in size on the blade like normal flat blades do and fit the slots in the jets properly.
Used on: body work, bar controls, carburetors.
Others:
Some other tools that are handy are:
linesman pliers,
side (wire) cutters, for installing your new fuse box.
vice grips, unjamming your transmission when a piece of primary chain guide has jammed it.
goose necks,
hammers, normal and soft plastic.
impact driver, the tool that your hammer should hit.
punches and drifts, don't use your screw drivers!
feeler gauges, valve clearances, spark plug gap, bench syncing carburetors.
test lamp, make sure power is getting where it should (Make your own).
multi meter,
soldering iron, installing your new fuse box. Any connections you make I advise soldering not clamping.
General tools most will have anyway.
Specials:
Air Compressor.
Rattle gun (get the clutch basket off the bike!).
Carburetor sync tool. Make your own, clear tube and some 2 stroke oil is all it takes.
YCIS tool. Make your own, biggest thing to note is the sealing part needs to be able to handle high temperatures. Or jam some marvel mystery oil soaked clothes line in there!
Valve clamp. Make your own, G clamp and tube with hole cut in the side to remove the collects through.
Order to use:
First choice a socket,
next a ring spanner,
then a open ender,
then (desperate) a shifter (nut f***er),
then vice grips (oh bugger someone rounded the bolt head with the shifter),
then if you are using a Stiltson (pipe) wrench that is one heck of a bolt!
Hope this can be of help to others. Feel free to add or correct Smile .
_________________
1984 XJ750D EFI Model 22N 134,000 Km Police bike cams n head
Back to top
RickCoMatic
Moderator
PostPosted: Sat Apr 28, 2007 5:47 am    Post subject: Re: Tools Reply with quote
I always speak-up and let the Forum know when the "Basic Mechanics Tool Set" goes on Sale at Sears. It's a GREAT Value of tools for the dough.
Having just the right tool for the job is going to insure that disassembly and reassembly are done efficiently without struggling to make-do with an ill-fitting or improper tool.
You've listed the essentials and explained why it's so important to have those tools in the inventory. I endorse having those tools and more!
I would suggest having some redundant sizes, particularly 10, 12, 14 mm.
When you add these wrenches (spanners) and sockets to your inventory, get the 6-point versions of the Closed-end (Box) wrenches and sockets.
It's good to have a tool that will allow you to apply strong tightening and loosening torque to a fastener without fear of it slipping or damaging the flats on the fastener.
_________________
Rick Massey
Moderator - Tech Writer
Use LOCATION Feature.
Back to top
KiwiXJ750D
Red Liner
PostPosted: Sun Apr 29, 2007 3:55 am    Post subject: Re: Tools Reply with quote
Hi Rick, yeah gotta have the right tool for the job. If I find I do not have the needed gear I buy it. I find that if you need that tool once you will need it again!
Many times I have saved money by getting second hand good quality gear, cost the same as new cheap stuff.
I have many sizes at least doubled up, and in different length and shaped handles to get to the trickey bits.
6 point are more unusual here, but I have a couple of spanners called Metrotech. These don't contact the points of the bolt head, they contact the flats (kind of scalloped shape). They can't round off the bolt and fit both metric and SAE. You can get them in sockets too.
No Sears in NZ. I normally tell people here to go Fuller, though alot of my gear is Sidchrome (made in Aussie). Both have life time warrenty, Sidcrome is alot more expensive. My 3/8 drive is Fuller and my 1/2 drive is Sidchrome.
Have to do a FAQ on US and English names for tools too Wink
Closed-end=Box=Ring
Spanner=wrench Very Happy
_________________
Back to top
RickCoMatic
Moderator
PostPosted: Sun Apr 29, 2007 3:15 pm    Post subject: Re: Tools Reply with quote
I think we should take-up a collection and send all you 'Mates from Down Under a CRAFTSMAN 3/8" Ratchet Handle.
You can lock a socket onto that Ratchet and take it off while somebody pours motor oil on your hands trying to make it difficult ... but, it will still release.
_________________
Rick Massey
Back to top
Metal_Bob
5th gear
5th gear
PostPosted: Tue Jun 15, 2010 7:30 pm    Post subject: Re: Tools Reply with quote
This should be sticked at the top... Not the last page
_________________
1982 Maxim 750 - New to MCs and Carbs/Wrenching - 17k When purchased - 100+ Miles as of 7/8/10 - Still learning to ride/shift - Not really done much yet - Limited funds and tools Sad - Rear brakes checked - Fixed/Rigged Right blinker - Saddle bags installed - Need to work on trunk with 4 lights next
Back to top
Polock
XJ Wizard
PostPosted: Thu Jun 17, 2010 3:43 pm    Post subject: Re: Tools Reply with quote
suggestion, when you get allen keys try to get a ball end set they just make things so much easier
i see now they have holding allen keys too, they might be nice
Back to top
Metal_Bob
5th gear
5th gear
PostPosted: Thu Jun 17, 2010 4:02 pm    Post subject: Re: Tools Reply with quote
Perfect the set of allen keys I bought are ball end and come with a "handle" to get a bit more torque when needed (w/o a ratchet set).
_________________
Back to top
bigfitz52
XJ Wizard
PostPosted: Thu Jun 17, 2010 5:12 pm    Post subject: Re: Tools Reply with quote
You still need a long "L" shaped 5mm for the two valve cover bolts you can't reach otherwise.
LOVE my "T" handle ball-end set.
_________________
'81 XJ550RH Seca- Recommissioned original classic daily rider; 26K miles stock except bars, seat, shocks and SS brake lines.
'83 XJ550RK Seca- "Toxic Asset"; 9K original miles, restored, modernized and personalized (nearly stock)
Wish I hadn't sold my SR500
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
electrics
Last post by jt1200r in XJ Chat on Jul 29, 2010 at 19:53:26
Last post by FinnogAngela in XJ Chat on Jul 29, 2010 at 19:49:43
Fork Rebuild
Last post by venlis in XJ Chat on Jul 29, 2010 at 19:44:48
Dual Discs XJ750 Seca
Last post by Zookie400 in XJ Chat on Jul 29, 2010 at 19:43:17
Stator rectifer questions
Last post by dwmauney in XJ Chat on Jul 29, 2010 at 19:39:30
81 GS = 81 XJ ???
Last post by mlew in Other Motorcycles on Jul 29, 2010 at 19:34:08
it's tire time..
