Homemade synchronizer win
Discussion in 'Hangout Lounge' started by JPaganel, Jun 1, 2013.
  1. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    I didn't really feel like shelling out the money for the actual synchro tool.
    So, I got the following:
    1 aluminum yardstick
    1 roll of clear tubing (smallest size Home Depot sells)
    2 vacuum restrictors by Motormite from a local parts store
    2 lengths of vacuum hose
    Some clear 3M tape
    A little transmission fluid
    The result was this:
    Then I used it to synch the carbs on the FJ. Before I needed lots of fiddling with choke and on a hot day in traffic idle would hit 2000 RPM, or even higher.
    After the synch the idle is this:
    http://www.youtube.com/watch?v=eM6IKrX1CdM
  2. SilentRaven
    SilentRaven Member
    Sioux Falls, SD
    nice job! about how much did all this costs?
  3. JPaganel
    Minneapolis
    1 aluminum yardstick - $2.99
    1 roll of clear tubing (smallest size Home Depot sells) - $2.25
    2 vacuum restrictors by Motormite from a local parts store - $1.99 each
    2 lengths of vacuum hose - $3 or so
    Some clear 3M tape - had laying around
    A little transmission fluid - had laying around
    All in all about $15.
  4. quebecois59
    I did make one of my own for four carbs at a time:
    Of course, every tube has its home made restrictor (Rick's model):
    Haven't had the time to use it though.
  5. quebecois59
    It seems you got a real improvement in you idle speed, does it go down quickly when you give the throttle a twist and then release it?
  6. JPaganel
    Minneapolis
    Yes. The motor is very responsive now, both spinning up and spinning down.
    I also have a lot less vibration overall.
    I actually spent some time in traffic yesterday and after sitting a while it does get a little higher, just a hair over the 1000 mark, but not any more than that.
  7. bigfitz52
    You sure it's not supposed to idle at 1050, or 1100rpm?
    The 550s idle at 1200rpm; the 650/750s at 1050.
  8. jchalo99
    jchalo99 Member
    Connecticut
    so your telling me synced carbs will fix my idle issue?? with it wandering from stalling up to 3krpm?? all over the place
  9. bigfitz52
    Possibly;
    -valves in spec?
    -carbs totally completely clean and rubber parts replaced?
    -float levels accurately wet-set?
    -good accurate bench sync?
    Then yes.
  10. JPaganel
    Minneapolis
    My idle wasn't really wandering, it was steadily climbing and staying high.
    If it wanders, you may have more than one thing going there.
