Flasher relay assembly
Discussion in 'Hangout Lounge' started by Scrape, May 17, 2007.
  1. Scrape
    Scrape Member
    Creedmoor, North Carolina
    Sometimes you win and sometimes you lose...today I won! I replaced my stock turn signals with Motrax micro diamond indicators, pics to follow later. Anyway, my flasher relay went out and it must be from age or incompatability because they use a filament type bulb like the stock ones but are a different type. I looked in Bike Bandit and they wanted almost $73 for it and that doesn't count the shipping. 8O Because of the price and maybe the same kind wouldn't work either, I went to Advance Auto and wanted to try my luck and purchased a Tridon Slant, variable load, heavy duty extended life flasher unit / part# EL13. The prongs fit the connector on my bike perfectly but I had to switch the wiring around because the new flasher configuration was different but...it worked! :D Total cost, Ten bucks!!!! I LOVE IT!!!!!!
  2. Robert
    "Give a man a fish and feed him for a day. Teach him to fish and feed him for life." Knowledge is power!
  3. dragontearz691
    dragontearz691 New Member
    Kansas City, MO
    what wiring code did you use
    i tried that one and i get the nuetral light blinking?
    on relay there is x post p post and l post
    what wire did you put where i have tried all at least i thought
    thanks in advance
  4. PainterD
    I just replaced my machanical flasher with an electronic one last week and it was only a couple bucks at a fleet farm store. Now I can use LED signal lights. No matter what kind of after market lights you run, the flash rate stays the same. It was one of those "what-the-fu<k" moments.
  5. Scrape
    Scrape Member
    I'm working today but will look at what I did when I get home for you.
  6. Scrape
    Scrape Member
    Here are some pics of the flasher unit, for those who may need to spot one on the shelf when ever in need. Seems to be of good quality and heavy duty like the OEM part.
    The wire colors go to the prongs as follows:
    X ----> Br (brown)
    P ----> G/Y (yellow w/ green stripe)
    l -----> Br/W (brown w/ white stripe)
  7. Ease
    Ease Member
    NL, Canada
    Hey man Thanks for the tip!
    My blinkers now work!!!
    Got mine at Canadian Tire, looked exactly the same as the one you have shown and, get this, was the CHEAPEST out of the electronic flashers.
    I bought the most expensive one first, thinking it was safer - but had to return it for that one!
    Very happy.
    Thanks.
  8. MoeSyzlak
    MoeSyzlak New Member
    NYC
    thank god for forums... i was about ready to ghost ride my bike into the river.
    good thing i checked here first...
  9. Lanmanager
    Lanmanager New Member
    Atlanta, Ga
    Fixed mine too. Thanks
  10. dustball
    dustball Member
    Oak Harbor, WA
    It's probably a sealed relay unlike the old ones which are exposed to the elements
  11. Ease
    Ease Member
    NL, Canada
    Why isn't this thread sticky somewhere?
  12. thefox
    thefox Member
    Central NY (@ college in W. PA)
    So with this relay it doesn't matter what size bulbs I run?
  13. Ease
    Ease Member
    NL, Canada
    Nope, big or small they'll blink!
    I'm not using LED's and I have the same relay.
    You just loose the auto-cancel feature... Which I didn't ever notice working before I swapped relays...
    And you can still use the stock connector, just pop the wires out and switch em... plugs right in!
    I just zip-tied the new relay to the frame.
    Why isn't this thread sticky?
  14. Lanmanager
    Atlanta, Ga
    I have a spare canceler. I think I will open it up and find out how it works. Might be able to get it working with the electronic flasher.
  15. Ease
    Ease Member
    NL, Canada
    That would be cool.
    Post up your info here so we can see if it works!
  16. philbrewer
    philbrewer Member
    Livonia, MI
  17. Ease
    Ease Member
    NL, Canada
    ... Just means that it would be available at the top of the forum all the time.
    Sorry... I spend too much time on forums.
    :lol:
  18. thefox
    thefox Member
    I'll bump this for a great replacement!
    I bought a flasher on ebay and had it mailed home. I then made the wire leads and labeled them as Scrape described and mailed them home. My dad plugged in the flasher and my lights worked. Now when I go home to pick up the bike I can get it inspected without worrying about trying to get the lights working first. Thanks Guys!!!!
    Link to ebay seller (mcgreen-sales).... http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... RK:MEWN:IT
  19. philbrewer
    philbrewer Member
    Livonia, MI
    I was just asking if we could make this a sticky... :p
  20. rdbhere2
    rdbhere2 Member
    Thanks for the flasher wiring tip. I was having x-p-l nightmares for weeks!
  21. fonz
    fonz Member
    Philly burbs
    Hey Scrape,
    Thanks for the picture and the wiring description. I bought one relay that didnt work then found one that looked exactly like the one pictured and then that didnt work. Looked at your wiring and saw the brown/white and yellow/green wires were reversed so I switched them and now it works.
  22. Robert
    I'll pass on the request.
  23. bottlecape30
    bottlecape30 Member
    Rochester, NY down by the Bay
    Went to advance auto and picked up the relay flipped the yellow and brown/ white wire and my blinkers work again.
    This should really be a sticky i had to search for a while to find this.
  24. Scrape
    Scrape Member
    Thanks for the thankies everyone! :)
    I don't even have my XJ anymore...with regrets...but an old thread lives on to save others from undue trials with their bikes. I'm glad that I could make a worthy contribution to the forum and also not "ghost ride my bike into the river" either. LOL It's kind of strange that I decided to lurk about this morning and see this thread without having subscribed to it. I came back to this forum to trade some stuff a few weeks ago and by chance just clicked on here and started to read some threads out of boredom. Many things learned here apply to other bikes also and this forum is packed with good info and a helpful membership sharing their experiences. I'm sure that if you made other good info here like this thread a sticky, you'd probably have pages of stickys cluttering up the place. Maybe someone could write up a FAQ sometime to include this information. I made a good title for the thread anyway to help those in the search mode find it easily.
    I credit most of my flasher relay information and results to luck and desperation. Believe me, it was a shot in the dark accomplishing this task and by no means was it done with a vast knowledge of electronics. I'd feel a lot better about this contribution if it was skill that made it possible. I expected to possibly see some smoke trying this stunt. LOL I felt like MacGyver (old TV show) after I got my turn signals to work. MacGyver probably could have done it cheaper by using paper clip or something carried in a womans purse.
  25. blame_the_po
    blame_the_po Member
    Boston
    will this electronic flasher keep led lights on all the time, then flash when necessary? Right now my leds only go in when I flick the switch.
  26. lopezfr2
    lopezfr2 Member
    Point Loma, San Diego, CA
    i dont feel like hunting it down on the wiring diagram, wheres the flasher relay on the bike?
  27. xulf13
    xulf13 Member
    Franklinton, NC USA
    It's right under the tank.
  28. xj750
    xj750 New Member
    alright I just bought my first bike and its an 82 maxim 750. I went to replace the bulbs in the gauges b/c they were burnt out. Afterwards, my turn signals come on but don't flash, but if I play with the wires behind the headlight they will flash which makes me believe the flasher is fine. any ideas? or how about a wiring diagram??
  29. bandreso
    bandreso New Member
    Hey XJ750 did you ever get your issue figured out. From the sounds of it to me I'd bet there's something shorting out in your bucket making the lights just short to always on? Then when you play around you break that short?
    I'm no expert like some of the other guys on here, and have been in and out of this page to work out my own turn signal gremlins as well! BTW that flasher at advanced auto is still 10 bucks 3 yrs later and worked like a charm! Thanks for all the great info Scrape, even if it was just luck. It was a life saver.
  30. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Does anyone know what model bike Scrape did this mod on?
  31. lopezfr2
    lopezfr2 Member
    i cant remember a while ago i tracked down a thread of his tracking all his build progress, but its supposed to work on alot of models it should work on yours
  32. bandreso
    bandreso New Member
    Wesley,
    I'm not sure which bike Scrape used this mod on, but it will work on your 82 650. That's what I'm riding. I had real problems trying to pull the wires from the stock clip with my bobby pin tool... one came out with effort, one ripped :x :roll: , so then I said EFF it and cut them and put on some new female connectors to accept the relay. Wire it up just as described and worked like a charm! :D
  33. XJ750RNEWBIE
    XJ750RNEWBIE New Member
    Alvin, TX
    I just have to say thanks to you Scrape! Part Number EL13 worked great and only cost me $7.99 to get!
  34. sappha58
    sappha58 New Member
    Charlotte, NC
    I have been tearing my hair out for MONTHS trying to figure out where my turn signal flasher was located. One picture shows near the battery, another shows under the tank, but they're all amorphous in saying exactly WHERE the thing is. Now, at least, I know which part to get: an EL13 flasher. Take the tank off, find my old flasher, and replace.
    So far I've repainted the bike (Duplicolor Metallic Blue Flake), rebuilt the starter motor, and now tackling the turn signals. This is a great bike!
  35. SnoSheriff
    MB, CAN
    Added to "Sticky" section
  36. Jumoikin
    Jumoikin New Member
    Brainerd, MN
    This is a great trick. I was working on my blinkers for a couple days now and i joined here last night and now my blinkers work. next step is to strip down my extra wiring harness so i can get rid of my busted up headlight and atari box.
  37. Sandy
    Sandy New Member
    Hey Thank you! I was going to try it before I read this post. But I wasn`t sure if it would work or not. Now, thanks to you, I know it can.Thanks, Sandy. : )
  38. Shleprock
    Shleprock New Member
    Austin TX
  39. Pazalas
    Pazalas Member
    Reading PA
    if it is other signals you want. (prob gonna catch hell for this) go into the flasher and bend the floating contact up and down till it works. Doesn't take much of a bend. Got ninja turn signals on the 550. otherwise great part to know of if i need to replace it.
  40. Shleprock
    Austin TX
  41. cg82
    cg82 Member
    Rossland British Columbia
    New member here, just wanted to say thanks for the info, I was close to losing my mind before i found out that I would need to switch the wiring around a bit. works like a charm now.
  42. raptor8
    raptor8 Member
    Bend OR
    We have had a sharp increase this year in MC/car collisions... I decided to put a 'zero load' flasher on my brake light. cost $12. [basically a variable load flasher] SO now my brake light blinks whenever i use the brakes. Local motorcycle cop stopped me and told me it was a good idea! A steady red light means the same as a flashing red light, at least in Oregon.
    Next project: oscillating headlight
  43. PacNorWestHD
    PacNorWestHD Member
    Woodland Washington
    Sorry to Jump the topic on this thread.
    Alot of these Law's are so outdated and need fixed!
    I myself seem to notice Modulating Headlamp's and Brake lights More then steady Burning ones and the Laws should be fixed to allow such Mod's to be done to our Bikes In my opinion.
    According to the Washington State Patrol (WSP) brake light flashers/modulators are not permitted by federal code. WSP cited the Federal Motor Vehicle Safety Standard 108 (49CFR571.108).
    I think this section
    S5.5.10 The wiring requirements for lighting equipment in use are:
    (a) Turn signal lamps, hazard warning signal lamps, and school bus
    warning lamps shall be wired to flash;
    (b) Headlamps and side marker lamps may be wired to flash for
    signaling purposes;
    (c) A motorcycle headlamp may be wired to allow either its upper
    beam or its lower beam, but not both, to modulate from a higher
    intensity to a lower intensity in accordance with section S5.6;
    (d) ((All other lamps shall be wired to be steady-burning.))
    It's sad Washington state adopted the Federal law. which happens to be the state I reside in.
    Washington State Motorcycle Laws
  44. maverickbr77
    maverickbr77 Member
    Lowville, New York
    I have said it before but a lot of the headlight modulators screw with my eyes and I nearly ran off the road once because of them. I would be happy if they were illegal everywhere.
    I do like the brake lights that flash once or twice then go on solid.
  45. raptor8
    raptor8 Member
    Bend OR
    I'll start a new thread on it. Sorry to steal that one but the flasher theme got me thinking. :)
