colortune mpg's
Discussion in 'XJ Technical Chat' started by capy, May 20, 2007.
  1. capy
    capy Member
    Florida
    I did my colortune adjustment today. OMG. What a difference. The bike has more pep and lets me know now just how bad I need a set of clutch springs. I ended up having to rotate the mixture screws almost all the way counter clockwise. They were set 2 turns from clockwise. They were factory set as I had to remove the caps also.
    I hope this works:
    Idle
    http://s6.photobucket.com/albums/y236/c ... neidle.flv
    3000 rpms
    http://s6.photobucket.com/albums/y236/c ... 000rpm.flv
    Quick throttle snaps
    http://s6.photobucket.com/albums/y236/c ... ction=view¤t=colortunequicksnap.flv
  2. Captainkirk
    Captainkirk Member
    Northeast Illinois
    I don't know, but I'd like to see it!
  3. JimVonBaden
    JimVonBaden Member
    Woodbridge, Virginia
    The site I use it www.photobucket.com
    It is a free site up to 250 megs. I buy the ptofessional upgrade, which gives you unlimited bandwitch, and 2GB of storage.
    One hint, make sure you reduce the size of the files appropriate for mpg online.
    Here is one I did, but I reduced the quality a bit too far.
    Click on the above image to see it.
    Of course it also does a good job with photographs as well.
    Jim 8)
  4. Oblivion
    Oblivion Active Member
    Northeast Illinois
    There's always YouTube or Google Video.
    I thought this thread was going to be about comparing gas mileage before and after :D
  5. capy
    capy Member
    Florida
    I just filled the tank this evening. I will post my results tomorrow as I am taking her on about 100 mile run out of town tomorrow. I was getting about 90 miles to the tank before reserve. The power is a whole bunch better though. The bike isn't even close to as sluggish as it use to be when the old lady rode to work on it tonight. She actually had to hold on once this time.
  6. capy
    capy Member
    Florida
    Well, I went on a 100 mile run Tuesday and as best as I can tell, I lost 10 miles to the gallon by doing my color tune.
    My reserve light came on at 81 miles this time.
    It was approximately 45 miles one way, 16 miles at 90-95 mph,5 miles stop and go rush hour traffic and the rest just normal 60 mph. I had to refill again when I got back and will post again when I refill and see what I get.
  7. bobc
    bobc New Member
    alabama
    before i did my colortune i was gettig around 120 mpg and i was running lean now i get around 100 to 105 mpg depending how i drive her. but she runs so much better. i'll take less mpg for a much better running bike anyday.
  8. JimVonBaden
    JimVonBaden Member
    120 mpg? 8O
    Jim 8)
  9. bobc
    bobc New Member
    alabama
    opps!!! ( sorry) I mean to a tank of gas. I wish it was to a gallon. thanks for correcting me there jimvonbaden.
  10. yamahamaxim1982
    yamahamaxim1982 Member
    minnesota
    cool good info on color tune i was thinking your gas milage would go up after color tuning but oh well.so your looking for a blue spark at idle and high rpms,what do u think about buying a used colortune on ebay,or should i buy new.
  11. capy
    capy Member
    Florida
    I bought mine used from a local here. I got it in great shape. It didn't have the bottle of cleaning solution with it but it was offered, I just didn't need it ( all it contain is alchol). As you can see from my video's, it worked wonderfully. I figured the same thing about mine. When I noticed the mile per tank dropped, I understood thst I had increased the amount of fuel I was burning. I just didn't expect that much of a drop. 5 mpg. I am the same way in my thinki8ng as BOBC though. It runs so much better it is worth it.
  12. ctraugh2005
    ctraugh2005 Member
    Berwick, PA
    I got my colortune off of ebay at a good price, and the thing was only used once or twice. Looks like new. Not bad for $40 US shipped.
    If you are buying off of ebay, just remember to look at the sellers feedback. That will tell a whole bunch about the person.
  13. boostedsupra
    boostedsupra New Member
    stockton, calif
    ok, hers the tard question of the day, "what does the color tune do?" clean deposits in your cyl? :?
  14. gitarzan
    gitarzan Member
    Columbus Ohio
  15. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    One thing a colortune will do is keep you from runing lean. Running lean is great for gas mileage but bad for valves, pistons and cylinders. Lean means hot and hot melts metal. Especially internal parts of the combustion chamber where the hot is hottest. Air cooled engines benefit from a slightly rich of peak mixture to keep the engine cooler. So a drop in gas mileage may be just what you needed.
  16. capy
    capy Member
    Florida
    I put the video of my colortune adjustment in my first post. I have the idle, 300rpm and the quick throttle snap.
    I am much happier with the performance and not too concerned about the 10 mile drop in fuel mileage per tank I got. The idle is smoother, the power delivery better and the cruising vibration smoother. worth the loss.
