Chain cleaning
Discussion in 'XJ Technical Chat' started by Xjrider92117, Mar 8, 2014.
  1. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    After getting new tires and inspecting and cleaning the sprockets which both look good i was looking at my dirty chain.
    I was thinking soap and water with a scrub brush?
    Just wanted to see what others use.
    And to lube?
    Thanks!
  2. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I always cleaned it with engine degreaser and a soft toothbrush, then dry it off with some shop towels. Then apply chain lube, and wipe up the excess. 20 mins tops.
  3. bigfitz52
    Certainly not WATER.
    Good old brake cleaner spray from the auto parts and my Grunge brush; then re-lube. Lots of shop towels.
    Grunge brush:
  4. Xjrider92117
    San Jose Ca
    Ok thanks for the info.
  5. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    WD-40
  6. GFB85
    GFB85 New Member
    Kincardine, Ontario
    Kerosene and a toothbrush. And as Fitz said; lots of shop towels.
    Scrub it. Dry it.
    I take my bike for a quick spin around the block to get a little heat on it and ensure no kerosene is left on it, then apply my lube (or wax)
    Works great on my SV650
  7. Polock
    nobody uses o-ring chains ?
  8. k-moe
    They still need to be cleaned and lubricated. Dirty chains eat sprockets.
  9. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Scrub it, while it, oil (or wax) it. I never used a degreaser for fear it would clean the lubricant out from the innards where it was really needed. Most of my chains last well over 20k.
