Stranger Danger!
Discussion in 'For Sale, Trade/Swap, Wanted' started by ecologito, Jul 28, 2014.
  1. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
  2. hogfiddles
    It still has the rear brake assembly, rod, and pedal....I would assume that's how they stop.
    I wonder why they didn't pull off the front rotor since they pulled the front brake system.
    dave
  3. jcro61
    jcro61 Member
    Massachusetts
    Running no front brake is not as bad as you make it seem.
  4. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    On any vehicle the front brake is 70-80% of your braking. Giving up the vast majority of your braking capacity seems pretty damn bad to me.
    Specifically on a bike you essentially give up the ability to do an effective emergency stop.
    So, tell me, how is it not as bad as that?
  5. mtnbikecrazy55
    plus it'd be goofy to ride a bike with only one lever
  6. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I believe what jc was referring to was the fact that finding and installing the front brake isn't hard to do.
  7. Polock
    " give up the ability to do an effective emergency stop. " all stops are emergency stops
    Fred Flintstone did ok with no front brakes
  8. quebecois59
    I wouldn't pay that kind of money for a bike without front brakes
  9. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    Brakes! Who needs Brakes!! We got throttle...and the high maneuverability of a completely chopped up bike...
    betcha he really misses doing front wheel stands....lol
  10. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Fred was in a cage.
  11. Polock
  12. Xjrider92117
    San Jose Ca
    Well looks like they both rode and had no brakes.
    8O :D :D
  13. jcro61
    jcro61 Member
    Massachusetts
    I have had chops with no front brakes, it is not as bad as you make it seem, to this day I use my rear brake primarily....
  14. Kickaha
    New Zealand
    I personally don't understand why someone would reduce the effectiveness of their bikes stopping power by 70 + % and increase their stopping distance just for fashion/looks
    I guess you'd just have to compenate for it with being more cautious in your riding, if you primarily use your rear brake when you have both front and back brakes then you're doing it wrong
  15. JPaganel
    Minneapolis
    Then you are doing it wrong.
    If you stick to riding in parades it's OK. If you ride on the speedway wrapped in safety gear and contained by crash barriers, it's OK. Riding a bike with three quarters of it's brakes missing on the street is just not very smart.
    The idea that the front brakes are the most of your braking is not something we say. It's a fact.
  16. buzz81mach
    buzz81mach Member
    Crawfordsville, IN
    The few times that I had to slam on my brakes because of some cager not paying attention, I was so glad that I had front brakes. Emergency stops with only a rear brake are impossible. I went out and tried to only use the rear brake to stop on my street. Didn't stop to quickly. I love my rear brake, but only when it is coupled with my wonderul front brake.
  17. jcro61
    jcro61 Member
    Massachusetts
    Come ride with us and you will see
  18. Orange-n-Black
    Personally, I'd rather have a front brake.
    Your original rear brake setting is minimal on a two brake setup. I'm thinking that someone who has a rear brake only, would adjust that brake to work better than the regular setting with a two brake setup. So If you adjusted your rear brake more aggressively, you might find that it can stop your bike quite well.
  19. Polock
    I try to adjust the back brake to work as well as possible, just because I should be.
  20. FtUp
    FtUp Well-Known Member
    pacific northwest
    the problem with this scenario is that if you lock up the rear tire (and you will), you are going for a ride you don't want to take.
    CN
  21. Kickaha
    New Zealand
    see what?
    See that your stopping distances are far longer than they need to be?
  22. jcro61
    jcro61 Member
    Massachusetts
    I am still not convinced I need my front brake....
  23. som1somwhere
    som1somwhere Member
    United States, Illinois
    yeah id prefer a front brake just because i feel far safer with it. but hey isn't there and old saying "To each their own"
  24. Orange-n-Black
    Locking up a wheel is never good, especially the front. That's why you don't "slam on" the brakes. Gradual light to hard pressure for normal stops and pulse braking for emergency stops.
    With a rear brake only bike, you have to find the sweet spot in the adjustment. Not too little and not too much.
    Every style bike is dangerous if you don't know how to ride it properly. You can't ride a hard-tailed, rear brake only bobber like a sport bike. You have to know the limits of the bike your riding, and ride accordingly.
  25. jcro61
    jcro61 Member
    Massachusetts
    What he said :D
  26. FtUp
    pacific northwest
    it's not about knowing your abilities and riding within them. it's about that emergency situation you didn't see coming.
    no question you have to know your and your bikes abilities. what I am saying is that if you only have rear brakes, you are morel likely to end up sideways under the cage that stopped suddenly for some reason you couldn't see. good luck with that.
    CN
  27. JPaganel
    Minneapolis
    No, you won't. A rear brake only will never stop as well as the front brake. And the reason for this has absolutely nothing to do with brake adjustment, it has to do with physics.
    When you brake, inertia carries your mass forward. This "loads" the front wheel and "unloads" the rear. The wheel pressed to the pavement with greater force will stop best. You can apply more braking to the front before it skids, and no brake adjustment will change that.
  28. JPaganel
    Minneapolis
    Well, for a bike with most brakes missing, a 5mph parade seems appropriate. Taking a defective vehicle like that into street traffic is at the very least irresponsible. Sure, it's your life, but the guy whose bumper you will redecorate will have to live with that on his conscience. And that is a crappy thing to do to someone.
  29. Orange-n-Black
    What I'm getting at is, People that use front and rear brakes have a light adjustment to the rear brake and believe that rear only couldn't possibly work well because of that light adjustment.
    80 percent to front and 20 percent to rear, 20 percent wouldn't stop for quite a distance/time. So 100 percent to rear braking would require a great deal of adjustment and different riding skill that someone using both brakes wouldn't be familiar with. Which is why some people perceive and comment on a particular mod as being dangerous simply because they have no idea how to ride with that mod. They can be dangerous if the rider doesn't understand how to ride it.
    A hard brake on the rear can cause slide out, a hard brake on the front can throw you over the handlebars or worse.
    I have ridden both styles and didn't kill myself, and I'm not the best rider in the world. Might be luck!
    For that emergency we didn't see coming, that's something we should all be ready for and know what to do when it happens. So many people don't, then its too late. Part of your riding abilities is always knowing what's going on around you and keeping enough distance between you and them so you have time to react. So if your riding a hard-tail, rear brake only bobber, you wouldn't be zipping through traffic unless your an idiot.
  30. JPaganel
    Minneapolis
    No amount of adjustment and skill will ever get a rear brake to stop a bike as well as a front brake. It will always take longer to stop. Because physics.
    Specifically in the case of the XJ the rear is a smallish drum, and no matter how you adjust it it will never be even close to the front disc.
  31. ecologito
    NASCAR Country, NC
    I never thought this would be so controversial. It seems irresponsible to remove a safety feature and say "adjust your riding style", of course what do I know. If I did the same on a car there is no driving style that could seet me from the unavoidable.
  32. paul.hardy
    paul.hardy Member
    Tasmaina - Australia
    I cant believe people are seriously arguing that it is OK to ride a bike with the front brake removed. Makes you wonder if they have ever seriously rode a motorcycle .
  33. Xjrider92117
    San Jose Ca
    What happens when say a little kid runs into the street as your passing by and you can't stop in time. It could happen to anyone. You stop faster with both of your brakes period.
  34. Orange-n-Black
    I never implied that a rear brake would work as well as a front brake, I said it could work well enough as long as your not acting like an idiot. And yes these XJ's have small drums, a rear disc would be better.
    I used both brakes on my bike when I could ride and think its better to have both in case they're needed rather than needing what you don't have.
    I'm not going to assume that someones bike is unsafe because they prefer rear brakes only. I'm not going to assume that they don't know how to safely ride that way either.
  35. bigfitz52
    It has nothing to do with "knowing how." It's not a matter of "preference."
    It's pure simple inarguable SCIENCE. Physics. A full-size motorcycle, with ONLY a rear brake, is simply incapable of stopping in as short a distance as one equipped with both front and rear brakes. And certainly not capable of hauling down from anything remotely resembling actual speed in any sort of safe distance.
    Proper, safe operation of a street motorcycle involves the use of both brakes every time you stop. The bike doesn't have two sets of brakes so that it has one in "reserve" in case it's needed. They're always needed.
  36. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Agreed, they're is likely nothing wrong with the bike itself.
    I would. I've known numerous riders who feared flipping over the handlebars because they were told the front brakes were "strong!" And so they never used them. Some of these guys would also ride down a hill in third gear with a foot riding the rear brake, then wonder why A) they couldn't slow down toward the bottom of the hill and B) why their bike smelled so bad. So yeah, if someone tells me they don't use their front brake, I assume they are poorly educated regarding how their machine works and tend to keep my distance from them.
  37. JPaganel
    Minneapolis
    "well enough" for what? To stop eventually, after a while? Well, dragging your feet would work well enough for that, too. Certainly not for stopping the bike in the shortest amount of time in the safest way.
    All bikes ever have small and weak rear brakes. This is due to exactly what I described - the fact that the rear wheel can have much less braking applied to it before it skids because it's the "light" wheel.
    Two weeks ago I lost front brakes on my FJ1200 and had to get home with rear only. FJ has a sizable rear disc. It still makes for seriously subpar braking.
    I am not going to assume, either. I will know it's unsafe. A bike larger than a moped without front brakes is broken. And in quite a few places not road legal, and with good reason.
    Yes, there is a way to ride a broken bike somewhat safely. You go slow and figure the extra stopping distance into it. The fact that I am posting here proves it. However, deliberately riding a broken bike and claiming it to be a matter of style is silly. What next, stylish weather-checked tires? Custom figure 8 rims?
  38. patmac6075
    patmac6075 Active Member
    MKE
    3 pages.....Really?
    I've stayed out of the fray, because I (inaccurately) assumed anyone who argued that a rear brake only bike was anything but a dangerous death trap would lose all credibility....I was wrong
    By the way, I know a guy who knows a guy who added pods and straight-pipes to his XJ Rat-Rod...never has adjusted his valves and just cranked the idle screws out...guarantees his bike'll kick yours in the 1/4 mile!
    Let's see how many pages this'll get..... :twisted:
  39. Orange-n-Black
    hahahahahah!
    Well I guess I've lost this discussion sine science and physics joined in and the bike in question is now "BROKEN".
    Since all the new bikes are scientifically better than your outdated XJ, I guess all of ya'll are being dangerous and unsafe. Your XJ couldn't possible stop as fast as an R1, so we will now assume that you guys are wrong according to science and physics. Oh, and all your bike are broken too.
  40. Orange-n-Black
    Now to the OP, If you have a mod in mind, you probable don't want to post it on this site since people here want to popo any deviation from the original form. To them, you might as well be holding a pair of scissors in each hand while riding.
  41. patmac6075
    MKE
    Not really what I meant Orange....BTW, I do respect the work you've done and the contributions you've made to this forum.....BUT
    There is no doubt and many real world examples of people riding for years on virtual death-traps in shorts, flip-flops, and helmetless....with nary a bug stuck in their hair. Does that make it safe? The first safety course I took taught us "There are two kinds of riders, those that have gone down, and those that are going to go down."
    IMHO, any advantage you can give yourself, whether it's a properly maintained bike, safety gear, proper riding instruction, hell....properly inflated tires, could lengthen that time before you ride the asphalt.
  42. JPaganel
    Minneapolis
    I'm guessing this is because you don't have any actual arguments left?
    An XJ should stop as fast as an XJ, not as fast as an R1. A functional XJ is just fine. Removing the front brake makes it not functional. If it worked before, and it doesn't work now, it's called broken. What is that called in your dictionary? The rear brake alone is not sufficient to stop an XJ safely.
    When was it that the last bike came out of the factory with just the rear brake? If I remember correctly, that was some time in the 1930's. Why do you think that is? I bet it's because the bikes with no front brakes made back then didn't go particularly fast. If it doesn't go very fast, you can have crappy brakes and not get in trouble. Which is what I've been saying all along.
    You don't have to like science. However, facts are facts, and gravity will still put your ass on the pavement, and inertia will drag you along it, no matter what you believe. To quote Vince Masuka, science is a cold hard bitch.
    Incidentally, I'm not an unreasonable man. If I am wrong, I would be totally willing to admit it. Show me one of those RBO bikes with that perfect adjustment and skill with a stopping distance even remotely comparable to a similar bike with normal brakes, and I will make a public announcement to that effect.
  43. Orange-n-Black
    I know that front/back brake combo works better than a single rear. The question is whether a rear brake only will stop you in time? If you haven't been on a bike like that, how can you say it won't stop in time? Someone says they can, but you and others say no because of science and physics. You also have to consider responsible riding style and skill in the equation.
    Any vehicle can be dangerous if the operator doesn't know and respect it's limits.
    Dear old Great Grand Dad had a 1908 Harley, only suspension it had was the air in the tires and no front brake. He lived into his 70's.
    I didn't want to go any further with this because its not going anywhere.
    BTW I'm not trying to be nasty about this stuff, all that I've said is like what would be said between brothers.
  44. BruceB
    brakes? these bikes come with brakes? lol
    I sorta go with the original designers and engineers...
    There is a reason for front and rear brakes, just as there is a reason for handlebars and not a pull back rudder type of lever.
    But that's what I think...could be wrong though..
  45. patmac6075
    MKE
    I'm still not getting the logic here?
    Just because of some combination of skill, luck, and circumstance you're not a trunk ornament on a Buick, does not make it safe....there is a reason every bike made has front brakes...BECAUSE THEY WORK. They don't look better or save gas, THEY STOP A MOTORCYCLE FASTER. If you remove them, your stopping distance increases exponentially...no amount of skill or luck will save you when you life depends on stopping within 40 feet and your bike needs 90.
  46. JPaganel
    Minneapolis
    We aren't talking about respecting limits. We are talking about intentionally increasing these limits to a pretty significant degree.
    A 1908 Harley had about 7 horsepower. That's comparable to a scooter, except a scooter weighs less.
    The smallest XJ puts out about 50 horse or so. Bigger ones, more. This ain't your Grandpa's Harley.
    And, to counter an example with an example, back in the day T.E. Lawrence, the "of Arabia" Lawrence, died because he flew off his bike and landed with his head on a rock. He had all kinds of motorcycle skill and knew the limitations of his Brough Superior, but there were these kids who ran out into the road after a ball...
  47. Orange-n-Black
    Lawrence was also going very fast which is why I mentioned limits.
    The braking ability is less than the front/back combo, but not as bad as you suppose. When I mentioned limits, I was talking about adjusting your speed and distance between vehicles in traffic. It's not hard to figure that out.
    Since you guys are still fixated on the assumption that rear only is so dangerous, why don't you try it out for yourselves. Adjust your rear brake accordingly, ride with appropriate speed and distance between you and others and just use the rear brake in the correct manner.
  48. Polock
    Is this a conventional rear brake or full floating and would this bike have rear suspension?
  49. JPaganel
    Minneapolis
    I did. As I said, the fact that I'm posting here proves it can be done.
    "can be done" =/= "good idea"
    There isn't any adjustment on a disk, though.
  50. Orange-n-Black
    Well there you go, it can be done. Good idea, maybe not.
    Disk is definitely better. No adjustment, that's where the MC/caliper pressure comes into play. An anemic MC/caliper won't cut it.
    We've seen a rear wheel to front conversion with a disk brake, so converting the rear brake to disc could be done. Maybe using a 650 front disk and MC? I think that would work much better.
    Gotta remember that the rear brake only mod is mostly for looks and those bikes are usually taken for short rides at lower speeds.
    As far as hard tails are concerned, they look better in my opinion and can be ridden safely, but very hard on the tail and back. Wish I could've done my soft tail mod on my bike.
