 Latest: iamzeplin
 New Today: 7
 New Yesterday: 17
 Overall: 7729
 Members: 6
 Visitors: 19
 Total: 25
Who Is Where: Members:01: brokenxj700 > Forums
02: dbikers > Forums
03: dwmauney > My Account
04: johno8 > Forums
05: Kylew11 > Forums
16: Home
19: Forums
Hidden: 1
We have received 33581243page views since August 9, 2005
Forums › XJBikes Talk › XJ Chat › What did you do to your Yamaha today?
What did you do to your Yamaha today?Technical discussion ONLY for XJ Maxim/Seca...
Go to page Previous 1, 2, 3 ... 124, 125, 126 ... 132, 133, 134 Next
dustinb 2nd gear
Joined: Feb 24, 2010 Posts: 45 Location: Victoria, BC Canada
Posted: Sat Mar 06, 2010 8:13 pm Post subject: Re: What did you do to your Yamaha today? |
Replaced the rear drum brakes.
Strick 3rd gear
Joined: Mar 05, 2009 Posts: 83 Location: Ft. Eustis, Va
Posted: Sat Mar 06, 2010 11:23 pm Post subject: Re: What did you do to your Yamaha today? |
set float hight, bench synched, polished engine side covers, replaced throttle cable, installed new signal lights and took her for a 30 minute ride
_________________ 1985 XJ700 Maxim
Previous bikes
1981 XJ55O MAXIM
1981 850 SPECIAL
1989 EX500 KAW
1997 ZX600R KAW |
pirok 2nd gear
schooter XJ Wizard
Joined: Aug 29, 2008 Posts: 2447 Location: Elkton, Michigan (its in the thumb)
markie Red Liner
Joined: Jul 21, 2009 Posts: 569 Location: Suffolk, England
Posted: Sun Mar 07, 2010 5:49 pm Post subject: Re: What did you do to your Yamaha today? |
Started it, tested the lights, back light not working, stripped out ignition switch, tank, bars, instrument cluster.
It's the ignition switch.
_________________ Previous rides: Suzuki AP50, Suzuki GT250 (X2), Suzuki GT550, Honda 125T, Suzuki GT200, Honda CB500T, Yamaha RD250 Yamaha XJ 600 |
Bigdaddy 1st gear
Posted: Mon Mar 08, 2010 5:39 am Post subject: Re: What did you do to your Yamaha today? |
finished painting tank and it looks nice, Going to clear coat it today and tommorrow. Tore off triple tree, valve cover and am waiting for gasket and new ignition switch to arrive. Other than that, it time to clean and reassemble. Getting closer to riding.
_________________ Brian "Big Daddy" Henderson |
taboo365 2nd gear
Posted: Mon Mar 08, 2010 9:32 am Post subject: Re: What did you do to your Yamaha today? |
Put on new Headlight retainer ring.
Took off extra lights previous owner had on.
Cleaned out front master cylinder return hole
with a .012 guitar string(this worked great BTW)
Then warmed her up and road around the
nieghborhood for about a 1/2 hour in the
30 degree weather, to make sure front brakes are
working good. Everything is fine
Now just need some spit & polish and she's
good to go.
_________________ NOW- 2010 V STAR 950 TOURER
WHEN JOINED- 1982 XJ650J MAXIM |
KrS14 Red Liner
Joined: Aug 10, 2008 Posts: 624 Location: Tavistock, Ontario
Posted: Mon Mar 08, 2010 3:11 pm Post subject: Re: What did you do to your Yamaha today? |
Went for a 30 km ride, then she started missing on the left cylinder, i'll have to check my plugs tomorrow and see what they look like. It's about time for new ones, and nothing has changed from last season.
_________________ 1982 Yamaha Seca 750 (XJ750RK) 60,000+ km
1983 Yamaha Maxim 400 (XS400K) 50,000+ km
LED Turn signals
LED Instrument Cluster Lights
Spitfire Windshield
Royal Purple 20W-50
̿̿̿ ̿ ̿̿'̿'\̵͇̿̿\з==(•̪●)==ε/̵͇̿̿/'̿'̿ ̿ ̿̿ |
brianf408 2nd gear
Posted: Mon Mar 08, 2010 6:29 pm Post subject: Re: What did you do to your Yamaha today? |
Mounted and balanced my new rear tire, started measuring and marking where I'm going to chop and re-weld my Sportster mufflers.
KrS14 Red Liner
Posted: Tue Mar 09, 2010 5:26 pm Post subject: Re: What did you do to your Yamaha today? |
Fixed my TCi so it wasn't occasionally dropping one cylinder. After 20 years of soldering you'd think i wouldn't miss something like a cold solder joint.. Then again, the board is 26 years old lol.
Sucks i didn't get to ride today more than 5 mins  The bikes driving past, while i was fixing, were pissing me off lol
LED Turn signals
Spitfire Windshield
Royal Purple 20W-50
padre 4th gear
Joined: Dec 08, 2009 Posts: 134 Location: I44 Texoma (by way of LA-Vegas)
Posted: Tue Mar 09, 2010 6:28 pm Post subject: Re: What did you do to your Yamaha today? |
Worked on my left side cover again, did a little fabricating to re- install the turn blinkers where they won't get sideswiped, agian.
_________________ The bobber is the true essence of the chopper, a no frills stripped down street racer.
81 XJ750rh, rejetted, 75mm air inlet, open pipes, tank lift, chopped fenders & solo seat. |
markie Red Liner
Posted: Tue Mar 09, 2010 6:35 pm Post subject: Re: What did you do to your Yamaha today? |
I refitted my repaired ignition barrel, Got the airfilter to carb boots on better and greased the taper roller head bearings. When I went to test the lights (Which is why the ignition switch came off) the fuse blew.....Need to bring my digital meter home from work tomorrow.
ZaGhost Red Liner
Joined: Jan 19, 2007 Posts: 758 Location: Dartmouth, Nova Scotia
Posted: Tue Mar 09, 2010 7:45 pm Post subject: Re: What did you do to your Yamaha today? |
Nothing today, ... Yesterday got a coat of paint on 1 exhaust , need another nice day ( and more time ) Looking good so far, think I'm going to like it
Lot's on the todo for the weekend.....
_________________ 1983 XS400K Maxim |
85MaximXX Red Liner
Joined: May 20, 2008 Posts: 755 Location: S.W. michigan
Posted: Tue Mar 09, 2010 9:42 pm Post subject: Re: What did you do to your Yamaha today? |
well yesterday I put in a new battery its had the same one since I bought it and it was getting weak. Then I started it and drove to work. Took it to work again today 28*F out was a brisk morning ride but it is suppose to rain the rest of the week. rain + 50* weather makes for a sucky ride lol.
_________________ 85' MaximX 700 26k Miles and climbing daily driver. Painted sunburst orange pearl. |
KrS14 Red Liner
Posted: Wed Mar 10, 2010 5:33 pm Post subject: Re: What did you do to your Yamaha today? |
Put about 50 km on her, and ordered some front brake pads, asked about steel braided brake lines, damn they're expensive, about 60 bux!
LED Turn signals
Spitfire Windshield
Royal Purple 20W-50
