Connectors
Discussion in 'XJ Technical Chat' started by OpaJim, Jun 6, 2007.
  1. OpaJim
    OpaJim New Member
    Mena, AR
    I need to reconfigure the Run/Stop and the Start wires in the
    female connector. Does anyone know if the metal sockets can
    be pushed out and put back without destroying the plastic housing?
    It is probably easier just to cut the wires leaving a stub and solder
    them in the new location, but why do it the easy way? 8O
    Thanks,
    Jim
    XJ650LH
  2. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    They can be removed but you can also get the connectors from z1enterprises.com. They also have a tool for removing the pins but it can be done with a set of jewelers screwdrivers. It depends on the type of pin but most have a clip on the back that needs to be pushed down flat against the pin and then can be removed. Others have the clips on the side of the pins.
  3. MiCarl
    One of THESE should do the trick.
