YICS tool suggestion
Discussion in 'XJ Technical Chat' started by kzttdavid, Jun 9, 2007.
  1. kzttdavid
    kzttdavid New Member
    tennessee
    Bought latex tubing at Lowes. Stretched it through YICS passage. Clamped one end and used a pencil type air nozzle onthe other. Inflated it with a small amount of air and synced the carbs. Bike idles very well. Used a big fan to keep things cool. No problem with melting of the latex. Even touched the tubing to the head and did not melt.
  2. slickonline
    slickonline New Member
    Grimsby UK
    mmmm will have to try that one
  3. stereomind
    stereomind Active Member
    Tulsa, OK
    man, neat idea!
    hmmmm... why not use rubber fuel line? maybe it could be a bit more heat resistant?
  4. RickCoMatic
    That's some fine ingenuity.
    Once you get the YICS Passage sealed ... however you do it; you can get a real feel for what's happening -- Mixture wise -- and tweak-it-up nice.
    Great work.
    Thanks for sharing the technique and idea; too.
  5. RcPriest
    RcPriest Member
    Iowa City IA
    DOH! Why did i not think of something that easy.
    Great mind there!!
    Rob
  6. kzttdavid
    tennessee
    The clamped end may blow up like a balloon. I left mine that way. Figured it would help hold the pressure inside the YICS passage.
  7. Robert
    Very ingenious! Glad we have you on board, your paying your way rather nicely!
