XJ what???
Discussion in 'XJ Technical Chat' started by triump, Jun 11, 2007.
  1. triump
    triump Member
    Mississauga, Ontario
    How do I know what my 82 XJ 650 is. Is it a j k l g? I can't find anything on the3 bike anywhere.
  2. MiCarl
    1982 XJ 650 (Maxim) is model XJ650J. The SECA is XJ650RJ.
    The J indicates the year. The 1980 is XJ650G, 81 XJ650H (no I used), and the 83 is the XJ650H.
  3. triump
    triump Member
    so which is the 82.
    I read that the first three characters of the serial number tells you also. Mine is 5N9. b ut I can not find any thing to cross that with.
  4. Robert
    I'm going to suggest that perhaps your is a later model of the 82 line which started with 5N8. The next numeral in the sequense would of course be 9. Just a thought. How about a closer picture of the bike?
  5. Nick
    Nick Member
    Vernon, BC Canada
    Here's the listings from the XJCD on the "5N9" model.
    Frame # 5N9-000101 listed as 1982 XJ650J European model.
    Frame # 5N9-010101 listed as 1983 XJ650K Canadian model.
    Frame # 5N9-100101 listed as 1984 XJ650 with no other information!
  6. Altus
    Altus Active Member
    London, Ontario
    Sounds like you've got an early run 83 model 650K, but someone registered it as an 82.
