Restoring an xj650- Need the most complete carb kit
Discussion in 'XJ Technical Chat' started by xj650maxim82, Apr 5, 2006.
  1. xj650maxim82
    xj650maxim82 Member
    Georgia
    Hey I recently bought an 82 xj650 maxim and when i pulled off the carbs all kinds of crap came puring out. I took off the bottom section and it looks like the floats are rusted into one position and basically a ton of stuff needs fixing.
    So where can i find the most complete carb rebuild kit? Basically everything but the diaphrams and stuff.
  2. hoobatech
    hoobatech New Member
    Cedar Rapids, IA
  3. jdrich48
    jdrich48 Member
    Smithfield, North Carolina
    Partsnmore.com $12.00
    Be sure to check the throttle shaft seals as well, they will not come in the kit. But you can get them at mcmaster.com
    They will be a different type seal than what you took out.
    You'll need QR011 quad rings.
    Good luck
